Old 09-08-2010, 02:44 PM   #421
HI
DS Motorsport
Continue your good work ..
what can I expect from this car?
have many differences from the NT1?
How is the handling of this car?
itīs better wait and by the NT1 WC that will come out in end of September?
T.Senna is offline   Reply With Quote
Old 09-08-2010, 03:53 PM   #422
DS Motorsport's Avatar
Originally Posted by T.Senna View Post
HI
DS Motorsport
Hi,
Thanks.
Some of the strongpoints about the car according to me:
-Exceptional quality, the machining, carbon and plastics are of the best quality I've seen thus far.
-Aluminium bulkheads.
-Ultra lightweight from the start, most have reported to be around the 1600 grams with the stock kit.
-Comes with every optional part already in the kit, so no more paying for the stock heavy parts most of us dedicated racers don't use anyway.
-Kit comes with the best clutch available, the Capricorn WCE clutch.
-Low CG, might be the lowest of all cars.
-Lightest drivetrain of all cars, aluminum driveshafts, graphite diff gears, lightweight outdrives, it's all standard in the kit.
One of the main differences to the NT1 are the aluminum bulkheads compared to the plastic ones used on the NT1. Gives a lot nicer construction and less chance on stripping threads.
Geometry wise both cars are quite similar, the Lab has a nimbler, direct feel compared to the NT1 because of it's construction.
I hope to tell you more about the handling this saturday, after I've driven it.
Can't comment about the NT1 WC, don't know what the price of the kit is going to be. One thing is for certain, it won't have the Capricorn clutch, lightweight drivetrain or brake system. All of these parts are a massive improvement to the NT1 I've experienced. Add all these parts to the price of the WC kit and I'm pretty certain the Lab C01 will be the cheaper option.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 09-08-2010, 06:31 PM   #423
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by DS Motorsport View Post
Hi,
Thanks.
Congrats on the new car DS!
Did you ever break the composite gears? Or did you change them regularly?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-09-2010, 03:24 AM   #424
gfilos's Avatar
The 2010 car features all the parts which are available separately in the 2010 upgrade kit, this consists of the following parts:
- 2010 rear and front shock tower
- New bel tensioner plate
- Steel pivot balls for increased steering angle
- Single shock oring kit for smoother shocks.
- Titanium nitride coated shock shafts
- Brass battery plate, because the car is far below legal weight.
I ordered my kit today, hope to have it this friday, practice on saturday and race it on sunday.
Will do a little report on the building process.
I'm also planning to post setups regularly since there aren't much setups available yet.
So anyone who has questions regarding the Lab C01, Lab E01 or Hardlight tires don't hesitate sending me a PM or email.
hoow, build the hole kit in one day? you have a lot of work to do! Waiting days to pass for the new kit to arrive must be very hard Waiting for the report, i like this car alot and if the quality is like you say, well time to save money...
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 09-09-2010, 05:39 AM   #425
musti72's Avatar
i think lab c01 is a massive improvement over nt1(used to run it last year) in terms of easiness of maintanence, better drivetrain, and stronger parts. It is hard to believe but I crashed the car full throttle several times but nothing ever damaged. We also have about 35C air temp and 60C track temp in turkey, so its very hard on car but no problems, every part is from kit after 4 gallons except belts. You buy the kit and dont pay anymore, simple
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 09-09-2010, 08:23 AM   #426
Thanks.
Never changed them, have been running the same set since march this year.
If you change to the composite gears it is important to start with a fresh diff.
So outdrives which are still good and more importantly the little pin which goes through the outdrive and blocks the planetary diff gear.
If this little pin has been worn already by the steel gears the composite gear will wear out very quickly and breaks because of the play it develops.
Also fill the diff with enough oil and change regularly. I see a lot of people with diffs which haven't been rebuild for 3-4 months, with a lack of oil the gears will have less lubrication and damping from the oil.
Building a kit in one day isn't a problem, takes me about 5 hours. Then 2 hours for setup and another hour for painting the body.
Some other brand I ran before the NT1 took a little longer, the dremelling to make everything fit alone was good enough for 5 hours.
The build report I will probably post sunday evening or after the weekend, don't think I will have the time between practice and racing.
P1-RC.com
Old 09-09-2010, 09:56 AM   #427
He DS,
One comment, i think the car is very expencive.
It`s about 180Euro more expensive then a 733, or NT1.
Normaly you by serveral kit`s on a begin of the year, so that make a difference.
And you does the spare parts costs in compare to others?
But if the car is faster (i wonder) than other brands than it`s worth every bit of money of course
But i am very curious to see the car (and you of course ) on saterday.
petertjes is offline   Reply With Quote
Old 09-09-2010, 10:39 AM   #428
Originally Posted by petertjes View Post
He DS,
I have to admit, the starting cost's of a Lab are higher compared to a 733 or NT1.
But most drivers will buy various optional parts for their cars, in my case I have 300+ euros worth of optionals on my NT1.
The same thing goes for the 733, this car is very heavy in stock form, 1800+gr isn't an exception.
If you buy the TiNi shock shafts, optional brakedisk, composite diff gears and low friction belts I think this 180 euro gap will be a lot smaller.
And then you still have a car which is a lot heavier as a lab, and doesn't have the Capricorn clutch.
Spares are priced similar to the NT1 parts (using the Capricorn site as a source) but are tougher and last longer according to Musti72.
I'm very curious as well, I'm convinced the car will be faster.
I'm aiming for a 16.0-16.3 at the end of saturday.
See you saturday
P1-RC.com
Old 09-10-2010, 02:47 AM   #429
djiewie's Avatar
Daan,
I`m also there on saturday, and see the LAb that you are using.
Curious what it will do on the track also.
Greetz JW
djiewie is offline   Reply With Quote
Old 09-10-2010, 05:16 AM   #430
It's here:
Hope to be back within 6-8 hours with the end result.
P1-RC.com
Old 09-11-2010, 09:59 AM   #431
Unfortunately I wasn't able to complete the build, one of the rear eccenters for the diff bearings was faulty. The hole for the bearing was 2mm too high compared to the other side.
The build itself has been really good thus far, parts quality is outstanding, too bad about the eccenter but stuff like that can happen.
P1-RC.com
Old 09-11-2010, 10:22 AM   #432
u got rid of the nt1?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 09-11-2010, 11:44 AM   #433
Riketsu's Avatar
Doesn't happen with XRAY...
J/k..
That sucks... Not being able to drive your dream car while its in your hands.
The Xray's Eccenter dont work there?? And no one in the track has that car or spare parts?
Old 09-11-2010, 03:41 PM   #434
djiewie's Avatar
J/k..
In the netherlands i have not seen the lab on racetracks or anywhere. So i was curious to see the car in real time. But if Ds is going to be faster with this car in stead of the NT1 i am sure more people are going to buy this car, and its also an pretty car so that helps. i wish it wasn,t that expensive though
greetz JW
Old 09-11-2010, 04:37 PM   #435
Still have them, they will be on sale pretty soon though.
J/k..
Actually it does happen with Xray,on my last NT1 kit and my T3 kit several parts were missing.
The difference is, when it happens with Xray they tell you 'bad luck, this is the part number' so you can order it at a shop.
With Capricorn they will send it out immediatly with DHL express and you have it the next day before 12:00.
I was just unlucky it was friday already, now I will have the new part this tuesday.
Unfortunately the Xray eccenter doesn't fit, the Capricorn ones have a hexagonal shape.
At first I was planning to draw one in Cad and have it made at the nearest machine shop but they weren't able to have it done before the end of the day.
P1-RC.com
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
