Old 06-01-2010, 12:52 PM   #286
musti72's Avatar
Originally Posted by DS Motorsport View Post
I will wait until they have the Front ARB kit in stock and then I will order a Lab C01.
I really want a car with a front wire type ARB, so finally this is available.
Good choice, you wont be disappointed.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 06-01-2010, 01:06 PM   #287
DS Motorsport's Avatar
I hope so, it is quite an investment.
Btw, do you know if the entire NT1 diffs fit in the Lab, because they look almost identical to me?.
Same thing for the fueltank, does it fit?.
Ow and does a body cut for the NT1 fit the Lab?
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-01-2010, 02:05 PM   #288
musti72's Avatar
-Diffs fit directly, and diff cases seem to be same geometry. Btw, Nt1 diff:37grams, lab c01 diff:25 grams!!
-You'll receive an xray tank in the kit
-capricorn has a wider rear shock tower so wont fit rear, will fit front.
Other same parts I can mention: Pullies, belts, uprights, front upper and rear lower arms, Universal shafts, axles, front shock tower, front bumper assembly, roll center eccentrics, bearings, and of course turnbuckle rods. Btw, capricorn uses 4mm turnbuckles, be aware.
Mustafa Alp
Old 06-01-2010, 03:11 PM   #289
Thanks for the great reply, seems like I can keep a lot of my spares just in case something would break.
Now I only have to wait till the Fr ARB set comes available.
P1-RC.com
Old 06-02-2010, 05:25 PM   #290
blackyblackman's Avatar
Hi!
Here is a picture with the similar parts!
You can use all XRAY NT1 parts which are marked with a red arrow!
The arrows at the shocks and diff mean the whole assembled part!
And of course fits all small, standart parts like screws, servo mount, etc.!
I do not check all items!
If i found some more, i will post it here!
You can use from NT1:
- front and rear belt
- all pulleys (except the 20T brake pulley!)
- front and rear diff
- bumper, body posts, bumper support
- front hub
- rear lower arms
- front upper arms
- swing shafts
- shocks and springs
- fuel tank
- brake pad
- pivot balls, pivot screws
- roll bar
- servo linkage
Here the same picture as .pdf in higher resolution:
XRAY NT1 Similar Parts PDF
Regards,
Michael
blackyblackman is offline   Reply With Quote
Old 06-06-2010, 07:03 PM   #291
Bundy_Bear's Avatar
Default What the?
A few questions for you:
Does the LAB-C01 come with the diff oils or shock oils?
No WCE Capricorn clutch? It appears you have to cut the clutch shoes yourself???
Thanks in advance guys!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 06-06-2010, 07:35 PM   #292
It does come with oils.
PhatPat is offline   Reply With Quote
Old 06-07-2010, 01:33 PM   #293
Ericroc's Avatar
Hello,
i just ran with the car, and i'm just impressive with it. I tested it with the box setup, and the car is really easy to drive and really fast.
Really better than the Serpent 733 which was much difficult to setup. Also i drove during 8 or 9 tank with not any problem which was not the case with the Serpent.
Will try some other setups to be faster and faster.
La révolution n'aurait pas eut lieue si ils ne l'avaient pas faite!
Ericroc is offline   Reply With Quote
Old 06-08-2010, 09:55 AM   #294
musti72's Avatar
It comes with shock and diff oils in 50ml bottles.
It includes the wce clutch, except the inner 3 clutch shoes in front of the flywheel, and they are pre cut, they just need to be seperated from each other like from a part tree.
Mustafa Alp
Old 06-09-2010, 08:48 PM   #295
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by blackyblackman View Post
Hi!
- front hub
- rear lower arms
- front upper arms
- swing shafts
- fuel tank
- brake pad
- roll bar
- servo linkage
Regards,
Michael
Hmm, that's not an xray copy at all LMAO
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 06-09-2010, 08:48 PM   #296
rx7ttlm's Avatar
hey, so whats the internal drive ratio of this thing? and how much overdrive?
Old 06-09-2010, 09:42 PM   #297
PDX-Spike's Avatar
Xtreme RC Cars has a review on the LAB-CO1 in the July issue, page 82. Just received it in the mail today.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 06-09-2010, 10:20 PM   #298
PDX-Spike's Avatar
2.4:1
Old 06-13-2010, 12:47 PM   #299
musti72's Avatar
I have tested my car for the first time today, after long time raining over here... It was wonderful! First, I had to break in my new Rb engine, so had couple tanks very slow on the track, which was low to low-mid traction during the day.
Car had no problems whatsoever, and felt very stable and consistent right from the start. Before running the car, I had some anticipation about the handling because susp. arms were still a little tight on the pins even after reaming. Anyways it was good, and only problems I ran across were clutch spring being little too tight for break in, and rear anti roll screw loosened.
At the end of the day I was running at %85-%90 of the motors potential, and setup felt really similar to Nt1. Lab c01 was more direct at the corner entry, accelerating faster, and more stable when fast, those were my feelings.
Equipment:
RB R3 engine with 2064 exhaust, 5 fin manifolt
Savöx SC-1251 MG low profile servos both st and throttle.
Spektrum Sr3001 receiver, intellect 1600mah Nimh battery
Dodge stratus 3.1 body
Grp tires
Xray front hard bumper
Mustafa Alp
Old 06-15-2010, 03:43 PM   #300
Sounds great i cant wait mine should be here thursday
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
