Old 04-22-2010, 04:07 PM   #211
Maddin21's Avatar
Do you have final gear ratio table ?
Actually not yet...but I can try to manage to create one out of my Overdrive-Calculator...that includes gear ratios.
Maybe after this weekend's race...
Or do you mean a rollout-chart?? ...as this is ready
what happens if you are at a big race and you break
Esspecially at big races you have more time compared to other events...so this should be the smallest problem to rebuild and set-up your car for the next run.
And by the way...the Capricorn cars suspension parts are extremely stable...not seen a car taking that hard hits without damage.
So broken plastics are not an issue as to other cars ;-)
So 600 bucks are a good investment...I think.
But if you want you can prepare a set of 8 arms while watching TV, reading at RCTECH, talking to your girl at the phone...
Not really that much work if your reamer is good enough to modify Capricorn composite-plastics with only a few movements.
Can someone confirm the LAB uses 1.0 module gears or .8 module
Gears are 0.8 !!!
Maddin21 is offline   Reply With Quote
Old 04-22-2010, 11:49 PM   #212
RC MARKET's Avatar
Gears are 0.8 !!!
I'm want Final gear ratio !
1st , 2nd gear & pinion table
RC MARKET is offline   Reply With Quote
Old 04-23-2010, 03:52 AM   #213
Here is a excel program for LAB-C01 where u can find all the tech data
gear ratio... engine rpm .. tyre diameter... and so on...
hope will hel you all on set-up process
P.S. may be necessary to add the .xls extention after decompression
CapricornRC is offline   Reply With Quote
Old 04-23-2010, 05:15 AM   #214
thanks..
Here french version
G
georges972 is offline   Reply With Quote
Old 04-23-2010, 05:30 AM   #215
the more i look at this car the more i want one but i have a few question what do you actually get with kit hop up wise,also what are people finding is breaking common or wearing out etc cheers
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 04-23-2010, 06:19 AM   #216
lil-bump's Avatar
Trader Rating: 83 (100%+)
I can not open either zip file?????
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-23-2010, 10:42 AM   #217
el salvador's Avatar
Exclamation LAB-C01 Brakes
To any out there runnung this car that have had problems with the Brake Pad screws staying in adjustment, (where you want them set), I recommend using 20X3mm screws, (long enough to extend through the bulkhead), then add a Nylock-Nut to secure the screws on the outside of the bulkhead, there is plenty of room to clear the 2nd gear assembly.
I also note that Xray NT1 Pads will fit this car, I had my brake assembly disassemble itself so quickly that the expensive Capricorn Pads "Trashed" themselves before I knew it, (in less than 1 Lap). Just thought they needed to be readjusted!
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 04-23-2010, 12:26 PM   #218
Thanks for the tip. I was concerned with the brakes after assembling them.
PhatPat is offline   Reply With Quote
Old 04-23-2010, 04:46 PM   #219
can u do an english one ??
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 04-26-2010, 03:14 PM   #220
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Chris are you racing this weekend at Chaplin..weather looks good.
www.controlfreakz.com
Cheers
Jamie
J.Gonzalez is offline   Reply With Quote
Old 04-26-2010, 04:03 PM   #221
Cheers
Jamie
Chris was at the Ft. Myers track last Sat. testing on the new pavement
DESOTO RACING--SERPENT-977 EVO- 2010/2017 FORGASS -PRES.
RED CUP RACING - -BYRONS FUEL -NUGGETS RACING- RC AMERICA
PICCO RACING ENGINES - SANWA RADIOS - - -http://winternats.blogspot.com
FORT MYERS R/C CAR CLUB MEMBER 1983-2017--FLORIDA WINTERNATS 1988-2017
jrice is offline   Reply With Quote
Old 04-26-2010, 04:09 PM   #222
Just wondering if anyone can anwser my questions. cheers
BRCCC
Old 04-26-2010, 05:57 PM   #223
Serpent-Dan's Avatar
Cheers
Jamie
He's in Miami so I don't think so
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-26-2010, 10:42 PM   #224
Android's Avatar
I heard Capricorn is Doomed! R.I.P.
Android is offline   Reply With Quote
Old 04-26-2010, 10:56 PM   #225
dougday's Avatar
will Tose continue to drive this car?
dougday is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
