Old 04-10-2010, 09:35 PM   #196
I had all the right parts in my kit. Its a nice kit but it's not xray quality. I had to do alot of hand fitting for the suspension parts. The arms will bind and the front lower arms needed alot of work. Get a 3mm reamer it helped me alot. I would not recommend this kit for a 1st time builder.
The finished product is beautiful.
PhatPat is offline   Reply With Quote
Old 04-12-2010, 05:17 PM   #197
ltrdude's Avatar
Trader Rating: 29 (100%+)
Default capricorn
What motor and pipe combo are people running in there capricorn car
ltrdude is offline   Reply With Quote
Old 04-12-2010, 06:15 PM   #198
GMartinez's Avatar
Trader Rating: 85 (100%+)
Parts lot on the 4 sale thread if anyone is interested
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-13-2010, 02:36 AM   #199
The choice to make arms with very thiny tollerance on arm pin is a choice.
The builder can choose the PRECISION of the ARM PIN TOLLERANCE.
This is make to have the max precision... not couse we are not able to make a larger hole..
Wider tollerances help the buildings but the resulting precision is reduced and then require decimal shims to correct it.
All can be imporroved but when we talk about plastic is better to have a tight arm to ream than a wider to shim.. or in some cases... glue the pin on the arm as we saw in some cases.
for any more info's.. do not hesitate to write us.
Regards
Capricorn RC
CapricornRC is offline   Reply With Quote
Old 04-13-2010, 05:18 AM   #200
Default ok
hi
I add a 0.1 or 0.2 mm shim CAP-96641 between Cap16082 and Cap16084
and i remove M3x3 pin
to have a free lower arm work
little hyperstatic between Cap14025 and Cap16077 but freely to resolve.
best car i have..
G
georges972 is offline   Reply With Quote
Old 04-19-2010, 04:38 PM   #201
RC MARKET's Avatar
Regards
Capricorn RC
how to input Front suspension arm to Front bulkhead ?
RC MARKET is offline   Reply With Quote
Old 04-19-2010, 05:43 PM   #202
Maddin21's Avatar
take off some material from the FRONT of the arm...then you will not need to twist it in under pressure.
The space is needed for clearance and free running of the arm as Capricorn wrote befor.
With the correct lenght it is still thight but much easier.
Regards...MARTIN
Maddin21 is offline   Reply With Quote
Old 04-21-2010, 06:11 PM   #203
RC MARKET's Avatar
Do you have gear ratio ?
Old 04-21-2010, 06:24 PM   #204
Maddin21's Avatar
Stock: 7,24 / 4,92
Shortest: 7,91 / 5,18
Longest: 7,11 / 4,82
Old 04-21-2010, 10:57 PM   #205
Default parts fit
Im sorry but when you are paying almost 600.00 for a kit you should not have to sand cut or any of the above i just don't get it.it looks like a great car but what happens if you are at a big race and you break.just my two cents
TQ-1 is offline   Reply With Quote
Old 04-22-2010, 01:19 AM   #206
RC MARKET's Avatar
Originally Posted by Maddin21 View Post
Stock: 7,24 / 4,92
Thanks reply !
Do you have final gear ratio table ?
Old 04-22-2010, 02:56 AM   #207
musti72's Avatar
Nobody said that shaving the inner hole of the suspension parts leads to failure at a race...
You should see this as a driver preference, some people like their arms to move a bit, some people want it free moving but as tight as possible. To achieve both, Capricorn makes the parts a little tighter, so you can shave the holes as much as you want.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 04-22-2010, 07:19 AM   #208
I think he means if your at a big race and you break a arm. You grab a new arm and you have to sand it down before you install it. The solution would be to pre-sand and pre-ream your arms.
Old 04-22-2010, 08:26 AM   #209
lil-bump's Avatar
Trader Rating: 83 (100%+)
Stock: 7,24 / 4,92
Can someone confirm the LAB uses 1.0 module gears or .8 module
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-22-2010, 11:11 AM   #210
musti72's Avatar
Oh, I didnt think that way, he's right then...
Mustafa Alp
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
