Old 03-12-2013, 09:44 AM   #1996
el salvador's Avatar
Originally Posted by 1evo RRR Driver View Post
Can anyone confirm if the middle pulley shaft is the same as nt1? Or not
No, that is, if you're refering to CAP16002
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 03-12-2013, 05:09 PM   #1997
DS Motorsport's Avatar
Originally Posted by blis View Post
Yes please Daan, one that's compatible for spektrum 3100 receivers which are a little bigger than sanwa's and futaba I think.
Dimensions (WxLxH): .85x1.30x.48(in) 21.6x33.1x12.35(mm)
So, I would like to have the receiver in the horzontal position to allow the wiring inside the box to connect top down.
I need two please for a standard C02
Ok, I will get started on them after I received the prototypes. When I've received the proto versions I can decide which changes I need to make and what will be the minimal wall thickness.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-12-2013, 05:17 PM   #1998
Almost done with my co2 wc.......changed the rear camber link! One off design
I've tested such a rear upper link last year and didn't like it. It gives the car more rear traction but it also slows down the car's reaction.
Personally I prefer the wishbone type upper link.
If you want to post bigger pictures and post multiple in the same post pleas register at www.photobucket.com
Upload your images and then copy the [IMG]example code[/IMG]
in to your post.
It's not the same, the NT1's is longer and a different design.
Originally Posted by speed6 View Post
any one tried the new chassis
http://www.capricornrc.com/capricorn...d_product=2031
some feedback please.
Haven't tried it yet but I doubt whether it makes a noticeable difference. It should make the flex a bit more symmetrical but since the motor mounting points are still offset I don't think it will make a difference.
However when it's time to replace a chassis I would replace it with the optional one.
P1-RC.com
Old 03-12-2013, 06:25 PM   #1999
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Thanks for the input, i actually only did this because my car was missing the parts to complete the stock wishbone link, so i got creative and made a new one, will try it out, back to back n see if i to will prefer the wishbone link.......
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is online now   Reply With Quote
Old 03-13-2013, 09:11 AM   #2000
capricorn middle pulley shaft is shorter
CapricornRC is offline   Reply With Quote
Old 03-23-2013, 03:29 PM   #2001
Low profile shocktowers for the C02, by DS Motorsport:
New. low profile shocks will be available soon!
P1-RC.com
Old 03-23-2013, 08:54 PM   #2002
Bundy_Bear's Avatar
Daan
Did you borrow this idea from Xray
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 03-24-2013, 04:50 AM   #2003
if this works, why not^^
Radiopost TS401
SebO is offline   Reply With Quote
Old 03-25-2013, 03:39 PM   #2004
Default Diff gears and diff pins??
Fellas quick question, Can u use the metal gears inside the Kevlar diffs (rear). Also if u can use the metal gears, can u use the lightweight pins that came with the Kevlar diffs in the WC kit??
Old 03-26-2013, 08:53 AM   #2005
Default X-RAY SERVO SAVER???
Fellas have any of you used or witnessed someone using a complete X-ray steering servo saver in a lab co2? I asked cause that part is cheaper n much easier to get than the cap part..........
Also on the ankerman positions, (10,11,12,13) can someone explain how Capricorn just change the distance of the holes, But X-ray pills seem to move the holes forward and back. Are they achieving the samething but in a different way??
Old 03-26-2013, 09:13 AM   #2006
Originally Posted by Bundy_Bear View Post
Daan
Nope, had the idea when I bought a Tamiya M05 last year and saw the small shocks those use. Kind a sucks Xray beat me to it with the T4.
Since the idea of low towers and short shocks on a IC car is out in the open now (NT1'13) I figured I post the ones I made.
Yes, not a issue.
But the question is why would you want that?
I've seen some use the NT1 servosaver in the C01/C02 so it should fit without an issue.
Both methods have the same effect, personally I think moving the holes further or closer apart is the better method since it keeps the steering more linear throughout the different positions.
P1-RC.com
Old 03-27-2013, 03:19 AM   #2007
I asked only cause I broke the plastic gears in the wc rear diff in only 2races! I thought maybe the oil was low, but after inspection I think i destroyed the gears from a hard impact to the side of the right rear tire so I'll sacrifice a little weight for a little strength
Old 03-27-2013, 11:12 AM   #2008
gsxr0311's Avatar
Trader Rating: 19 (100%+)
i use the kevlar diffs with nt1 metal gears and had no issues since the kevlar diffs were released.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-27-2013, 05:29 PM   #2009
trickd122's Avatar
Yes, not a issue.
Xray didn't beat you to it they "borrowed" the idea from the BD7 on their T4
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 03-27-2013, 05:29 PM   #2010
gsxr0311's Avatar
Angry
Hay da motorsports, when do you think those radio boxes will hit the streets? I lost a receiver over the weekend I could have used one
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
