Old 03-06-2013, 03:36 PM   #1981
Originally Posted by djiewie View Post
Step 2 on turn in;
rear toe-in less try 1,5
just what nico said, forgot that, first less caster , all the shims in the rear.
sorry Nico its the other way to get turnin clips in the rear instead of front moves the upper arm to the front and this has less caster, more upright.
the front of cap use a brace, the cap is less firm there compared with the nt1, but it has a effect on high speed turns only and depends an the amout of bumpsteer you have.
Ohh thats right, remove any bump steer in and get bump steer out.
use one piece motormount
ackerman full. thats the links straight and nog angled, but thats with the nt1 with the cap look in the manual
front toe-out more , say 2mm
more weight in the rear of the car, weight balance rearward
Have fun with the try-out and remember settings always effect each other.
SO ONE AT A TIME, let the car handling grow on you, take your time to adjust to the car responceness. a twitchy car is scary at first untill you get used to it, then the speed will show
Show us some pictures of the car front and rear to look at the settings. Pictures are always nice.
ackerman full you mean to use the 13?
speed6 is offline   Reply With Quote
Old 03-06-2013, 03:58 PM   #1982
djiewie's Avatar
yes the 13.
i`ve seen on the thread that you`ve been having lots off advice by many.
i could tell you something on ride height but i think its too much info for you.
better to go step by step on the track preferably with fellow racers to guide you.
Haven fun, thats what its all about.
And your welcome for more advise if needed.
djiewie is offline   Reply With Quote
Old 03-07-2013, 04:37 AM   #1983
trickd122's Avatar
Originally Posted by blis View Post
They all used an extra-ordinary super soft setup, there was so much traction that if they used "stiff and low" the cars would snap into traction rolls.
I'll ask our aussie team boss what they used and see if we can get some setups posted. Marc Rheinhard, Peter Jovanovic, and Tironi, will keep you posted.
Thanks for the response. True I may not ever run at those traction levels but the goal is to study the changes they make in conditions that they have. I am sure we all could learn something from their expierences
Thanks again
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 03-07-2013, 04:50 AM   #1984
yes the 13.
What about the ride height as you got me curious
Saw some images from a friend of mine which was racing in italy and apparently some top CAP guy was running Reds springs on rear and white springs upfront. Was very surprised.
Old 03-07-2013, 06:32 AM   #1985
djiewie's Avatar
Speed,
With ride height lower or higher you get more or less weight on it.
So its also a tune option.
Greetz
Old 03-07-2013, 06:47 AM   #1986
Speed,
Greetz
Thanks DJ already use it to aid the steering, i run 1mm less up front
Old 03-08-2013, 04:26 AM   #1987
Suspended
Very nice car, good pictures as well.
Man every time I see one, I really want one.
Too bad I bought a NT1 EC for this year.
sid8 is offline   Reply With Quote
Old 03-08-2013, 04:27 AM   #1988
Suspended
Old 03-08-2013, 06:04 AM   #1989
DS Motorsport's Avatar
Originally Posted by trickd122 View Post
Strangely I can't seem to find any setups from the recent worlds
Jilles, Reinhard etc zero zip zilch
Does anyone have any links
I'm 99% sure Jilles used the following setup, only difference will be the shock springs which were Ride EP springs, and the body, Jilles used a P37 in Thailand.
http://www.capricornrc.nl/ExportBest...ssino&Type=pdf
http://www.capricornrc.nl/downloads
But I don't think you will be using the Ride springs at any other track since the extreme amount of traction they had during the worlds. For a normal track the red springs work really well, and for a bit more steering you can use red rear springs on the front as well.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-08-2013, 04:36 PM   #1990
blis's Avatar
Originally Posted by DS Motorsport View Post
I've designed a receiver box for my car:
This one has been designed around the Sanwa RX-471 receiver and has been made to fit my version of the C02.
If you guys are interested I can come up with a version which fits the original C02 radiotray and a bigger variety of receivers.
The whole box will be 3D printed so I can even make different designs for different receivers. I will also incorporate a mount for the antenna.
Yes please Daan, one that's compatible for spektrum 3100 receivers which are a little bigger than sanwa's and futaba I think.
Dimensions (WxLxH): .85x1.30x.48(in) 21.6x33.1x12.35(mm)
So, I would like to have the receiver in the horzontal position to allow the wiring inside the box to connect top down.
I need two please for a standard C02
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 03-10-2013, 11:21 PM   #1991
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Almost done with my co2 wc.......changed the rear camber link! One off design
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 03-10-2013, 11:23 PM   #1992
Another pic
Old 03-10-2013, 11:27 PM   #1993
Sorry don't kno how to put multiple pics on one post!
Old 03-12-2013, 05:43 AM   #1994
Can anyone confirm if the middle pulley shaft is the same as nt1? Or not
Old 03-12-2013, 08:11 AM   #1995
Default New chassis
any one tried the new chassis
http://www.capricornrc.com/capricorn...d_product=2031
some feedback please.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
