Old 01-17-2013, 11:00 AM   #1891
Any updates for 2013 on this car, LAB C03?
Sti2 is offline   Reply With Quote
Old 01-17-2013, 03:11 PM   #1892
Originally Posted by DS Motorsport View Post
First of all go to the 0,9mm front anti rollbar.
2 degrees rear toe-in
Go back to 1 degree of front toe
More front camber
Rear upper arm to inner lower hole
But the whole setup looks a bit weird to me, maybe this is what the track needs but judging from the video it looks pretty normal.
It's not weird for the handling to change when the amount of grip increases. If the car has been understeering slightly in low grip most of the time it will only get worse when the amount of grip increases.
If the changes listed above don't make the car better I would suggest trying the 'Mach' setup from my site:
http://www.capricornrc.nl/ExportBest...stede&Type=pdf
This setup seems to work for most drivers and most tracks. Like every setup you should copy it exactly with every single setting the same.
The setup also works with the SRS body but I personally prefer the RS4. The SRS has more turn in but washes out mid corner. The RS4 also feels a lot smoother.
Thanks DS checked the setup sheet and couldn't understand well the following
Rear Lower Roll Center is at lowest, would that be -0.5
MM on shims on the Uprights is 6mm ( never saw something like that )
Regarding rear toe in, once i go less than 2.5 my car spins out of control in certain sections of the track very badly off power entry steering.
But will try it out
Ackerman 13 gives more ackerman effect or less?
Thanks once again
speed6 is offline   Reply With Quote
Old 01-17-2013, 05:00 PM   #1893
DS Motorsport's Avatar
I've been told the car will remain the same for the 2013 season.
But will try it out
Thanks once again
Lowest rollcentre is -1.5 I think. Other settings are 0 and 0.75
The low lower insert and 6mm shims on the upright is something Jilles came up with. It gives the car more rotation without making it loose rear traction. It works on most tracks.
Ok, that's probably because it's a bumpy track. Try adding front end grip and keep the rear toe settings the same.
The least amount of Ackermann will be with the 12 insert or the new 13 servosaver.
And yes less Ackermann will give the car more off power steering, if the Ackermann is set wrong at the moment.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-19-2013, 11:45 PM   #1894
Does the nt1 side belt fit this car? I know both rear and front do but I have no idea about the side one!
7rac3r3 is offline   Reply With Quote
Old 01-21-2013, 05:16 PM   #1895
No, the Capricorn side belt is shorter. It's 390mm versus 396mm for the NT1 belt.
P1-RC.com
Old 01-21-2013, 06:33 PM   #1896
Thanks .
By the way does the side belt need to be replaced frequently? I mean from race to race or within 2 races!
I'm kinda getting ready because I think I'm going to race Capricorn this year I'm really looking forward to it .
Old 01-21-2013, 07:32 PM   #1897
It depends on which belt you're running.
For the original low-friction belts I would recommend replacing them after 2-3 races.
The new types should last longer but don't know how long exactly, only ran them during the euros.
Don't know how long the long-life belts last since I've never tried them, prefer the drivetrain efficiency provided by the low-friction belts.
P1-RC.com
Old 01-22-2013, 03:42 AM   #1898
2-3 races is enough since i usually replace the low friction from race to race including practices!
Old 01-22-2013, 02:14 PM   #1899
Default Kevlar diffs
I received questions from various drivers about what's the difference between the standard diffs and the Kevlar diffs.
So here it goes:
Besides the obvious difference in material between the two diffs is the biggest difference the amount of oil the diffs can hold. The Kevlar diff is able to hold more oil compared to the standard diff. Because it can hold more oil it will be more consistent and smoother. It might take some testing to get the same feel compared to the standard diffs. Because they hold more oil you might need to use a slightly thicker oil to have the same amount of diff action.
The Kevlar diffs also might be a bit lighter, they look lighter, but haven't weighed them so this is just a guess.
P1-RC.com
Old 01-24-2013, 05:30 PM   #1900
Default Shocks
any one know of better shocks maybe metal , I have been use the Capricorn ones for the last 3 races and they work well for about a day but then they get air or leak and I have replace all parts with same result??
jorge858 is offline   Reply With Quote
Old 01-24-2013, 05:34 PM   #1901
Get the KM Racing H-K1 shocks, i fill them once a year.
They are pretty good, good enough for a WC.
rbakker is offline   Reply With Quote
Old 01-24-2013, 06:00 PM   #1902
Trader Rating: 13 (93%+)
The km that won the worlds used mugen shocks
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-24-2013, 06:05 PM   #1903
Hahahahaha, just a little joke and spam for KM!!! (WC)
Old 01-24-2013, 11:06 PM   #1904
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Oh you was joking! Didn't see that at 1st!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is online now   Reply With Quote
Old 01-25-2013, 11:48 PM   #1905
Bundy_Bear's Avatar
Why post crap like this, people who are none the wiser might base their purchasing on things that are not true. I know my Evo II isn't the same car that was the one that Meen V used to win WC last year
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
