Old 12-23-2012, 01:35 PM   #1816
Default Experiment with impressive results
Since i still didn't manage to get the off power steering necessary for all the tight chicanes with the springs we started looking into other stuff.
Today we tested a rear diff with 10,000 and i was blown out of how more turn in i had in the chicanes and the accelaration tail happy issue i had got solved
I will try 5,000 and see what happens.
Any comments would be greatly appreciated
speed6 is offline   Reply With Quote
Old 12-23-2012, 02:29 PM   #1817
Chickentrader's Avatar
You could try more toe out, lower rear roll centre (take spacers of top of rear camber link, move lower arm pins down or upper arm pins higher). You would probably know, but less caster helps on tracks with tight corners, but reduces straight line stability.
Also check tire wear to make sure that your front camber is set right (too little front camber will make cars understeer off-power) and it is perhaps also worth noting that initial steering response will be more direct with less Ackermann ( steering will react faster).
Shorter wheel base will give the car more overall traction.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 12-23-2012, 03:53 PM   #1818
Kindest regards,
Lars.
Hey Lars,
That's practically the setup I am running.
Tried less caster but didn't get to much in the chicanes and lost way to many steering in the fast section.
Old 12-24-2012, 02:52 PM   #1819
blis's Avatar
Default Xmas Greetings
Be careful to keep the wheels on the ground in the corners, if the inside wheel lifts with 5000 it could spin up and smash the diff..
But I really came to wish all the Capricorn RC family an Early Merry Christmas from downunder!
Cheers to all...
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-24-2012, 03:26 PM   #1820
Hey Lars,
I forgot to mention; but we've been using small SC-1251MG steering servos, and we've only recently realised that they don't work as well as full size servos in nitro cars with foam tires. Changing to a bigger SC-1257TG made a significant improvement to the steering in our car. We will now change to JR DS8915 servos for steering before the next event we go to.
Also; I have more than once seen hard to identify problems with not enough steering on the track; with servos that seem to operate faultlessly, fast with heaps of torque in the pits. We also had such problem in a final in the last event we raced in, and perhaps you should try another servo if nothing else works.
Kindest regards,
Lars.
Old 12-25-2012, 02:04 AM   #1821
Kindest regards,
Lars.
Thanks god to my great eye sight I can see the wheel quite easily at a certain angle at an almost full lock so the servo looks ok but will try another one to be sure.
I would also like to comment that with the light rear diff made the car much easier to drive. Will start taking some timing and see if we improved a bit and check consistency.
All the best people! 2013 looks like we are going to kick some ass much harder than usual!
Old 12-25-2012, 07:01 AM   #1822
GREGORY!'s Avatar
does anyone know the spring rates in lb or gf/mm or lb/in for the capricorn springs?
thanks in advice!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-26-2012, 07:21 AM   #1823
Default Servo Horn
Hello
I'm actually building the LAB C-01 and I was surprised not finding the servo horns in the kit
What kind of horns did you use for your steering and throttle servos?
Which servos do you use for this kit?
Low profile or standart size?
Thank you very much for your help.
Best regards
Italboy is offline   Reply With Quote
Old 12-27-2012, 01:48 AM   #1824
nikoskar's Avatar
Originally Posted by Italboy View Post
Hello
Best regards
You can use Low profile servo for gas/break and a normal servo for steering for better balance.
You can use the alu servo horns that Capricorn sells of use plastic ones.
Notice: Good plastic servo horns are from Team Magic that don't break. (Have for Sanwa & Futaba Servos). Check Capri servo horns width.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 12-27-2012, 08:29 AM   #1825
RC-Netshop.dk's Avatar
Hello
Best regards
I would go for the ones 3Racing produce, please see link:
http://os.3racing.hk/products_list.p..._key=81&page=2
It looks a lot like the ones as those Capricorn sells and they are cheaper
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 12-27-2012, 08:39 AM   #1826
I WOULD GO FOR HUDY!!!!
nickiphorosn is offline   Reply With Quote
Old 12-27-2012, 08:43 AM   #1827
Hey nikoskar , where have you been for the last 12 or so months? Wellcome back....we are waiting for your comeback? are you gonna have your new Capri ready for 2014????
Old 12-27-2012, 09:59 AM   #1828
Thank you very much!
Which servo (Savox) would you recommend?
For the horns I will have a look on both, TM and 3Racing.
Old 12-27-2012, 10:00 AM   #1829
Thanks Nico!
I will have a look at 3Racing!
Old 12-27-2012, 10:40 AM   #1830
DS Motorsport's Avatar
Hello
Best regards
The 3racing horns look nice (almost same red) but are quite weak, they are made of cheap aluminum.
Capricorn now offers a complete set of plastic servo horns:
http://www.capricornrc.com/capricorn...d_product=1828
For servos I would recommend anything but Savox, the Savox servos are cheaply made and they don't fit very well, especially the low profile ones.
Personally I use the RSX One10 from KoPropo, but any servo from Sanwa, Futaba or Kopropo should do.
P1-RC.com
DS Motorsport is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
