Old 11-22-2012, 11:33 PM   #1786
BBQboy's Avatar
Hey guys I own a picco torque .12 in my CO2 and was just wandering what are clutch settings because i found this engine in this car has a very small tuning window. Also im having inconsistency throughout a final where clutch tends to slip. Just wondering if its the red clutch shoe i've being using.
Walter RC Hobby. Team picco Australia
Serpent 747 | Podified race fuel | Utli-rc | Zac Project |Picco | Reds Racing
Western Sydney Race Centre
ARC R10 | Orca | Ride
BBQboy is offline   Reply With Quote
Old 11-23-2012, 03:00 AM   #1787
barg's Avatar
Send a message via Yahoo to barg
BBQ been running the exact same setup for most of the year. Never had a problem with tuning or with the clutch slipping. Are you sure your not just going to aggressive with the clutch to start with????
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 11-23-2012, 04:46 AM   #1788
DS Motorsport's Avatar
Rebuild the clutch using the 'WCE Clutch Manual' found here:
http://www.capricornrc.nl/downloads
This will give you a good basic setting. Depending on the engine you can adjust the spring pretension until the clutch starts slipping. When it starts to slip reduce the preload by a quarter turn and you should have an excellent clutch.
The highest value of preload I ever used was 1,1mm.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-23-2012, 04:54 AM   #1789
djiewie's Avatar
i,ve been using this engine the 2011 version this year and have had some problems with low end power. Untill the last clubrace on the RACO i gave it some turns on the preload. That transformed the engine into a rocket
Had a lot of fun with it in the final, the car with exploding excellaration out off the turns. BIG FUN GREAT ENGINE.
Too bad i didn`t try it during the nationals. And the tire wear was the same though.
djiewie is offline   Reply With Quote
Old 11-23-2012, 09:40 AM   #1790
el salvador's Avatar
Lightbulb "Speaking of Clutches".........
Out of Curiosity, has anyone tried using the Xray NT1 #338583 conical clutch washer spring set on the LAB C01 ? These washers do fit and I started playing with them back in September however, our outdoor season suddenly ended due to lack of interest before I could get the car on the Track and "Dail it In".....Oh Well.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 11-23-2012, 05:02 PM   #1791
Chickentrader's Avatar
We've tried it in the Gas Tourer class that we run here in Queensland (max 1 hp engines), but the clutch kept on slipping with the engine that doesn't rev very hard (O.S.12TG). We have never tried it in the unlimited horsepower Tourer class, as we are very happy with standard black spring, red shoe & steel bell. We tried conical spring in the other class because cars with optimum clutch settings can have nearly 20 percent more speed in the class. There is also an option to turn fly-weights leading or trailing if you use the 2 hole weights. Perhaps Daan from DS Motorsports might know more about how conical springs perform in faster engines.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 11-23-2012, 05:48 PM   #1792
Kindest regards,
Lars.
Thanks for your input Lars, what it suggest to me is that I could be "Barking up the Wrong Tree"......I mostly race on a medium (at best) to low traction parking lot Track, where run time is more important than Horsepower. Having a softer hitting clutch that is less likely to "Unsettle the Car", usually works better. I'll probably go back to the Kit spring then.
Old 11-23-2012, 10:31 PM   #1793
Didn't your clutch worked well at the Nats in September Joel? I thought you were happy with it? I don't believe the engine is making the clutch slip, if the clutch works well with other engines; Taynton is running that engine without trouble; and he is very fussy about clutch settings. Don't know if have already tried it, but perhaps it would be worth trying a new (red) clutch shoe.
Kindest regards,
Lars.
Old 11-24-2012, 04:50 AM   #1794
BBQboy's Avatar
Kindest regards,
Lars.
I have that so I've ended up using a harder shoe to get more consistency Lars but at night the clutch went well I know it's cooler that everything. But I was wandering if u could send me a pm about how u set ur clutch Lars if you want too
Old 11-24-2012, 06:32 AM   #1795
rc carnage's Avatar
Ygpm
rc carnage is offline   Reply With Quote
Old 11-24-2012, 02:42 PM   #1796
You won't go wrong if you listen to advice from Daan and Taynton!
As far as Chance and I go; we use 0.5mm Clutch gap, 0.2 - 0.3mm end play, standard black clutch spring and Peter Snr. has told us to set the pre-load at 0.5mm (to start with). We have one clutch with standard fly-weights, an another with 2 hole fly-weights which we use the same direction that standard flyweights allow. We used 0.7mm preload in Bangkok with a new spring (springs lose some tension when they're get old), for the SQR engine that Chance liked best. The fly weights blow out with bigger clutch gaps, or if end play gets bigger than 0.3mm.
Probably no interest to you, but the clutch that we use for the Gas Tourer class is different with modified parts from other manufacturers.
Make sure that you don't have a pre-load nut from your old NT1 in your clutch, they're different.
Kindest regards,
Lars.
Old 11-24-2012, 09:04 PM   #1797
blis's Avatar
Default A fun video...
http://capricornrc.com.au/latest-video/
https://www.youtube.com/watch?v=ue2BGnaL1jA
I've scraped the bottom of the barrel of video clips to put together a CapricornRC video for the Worlds in Thailand.
We apologise that there is very little footage of the team on track as Luke was limited with his assistant role and the camera fogged up badly in the humidity and a lot of footage was unusable.
I would like to also apologise to anyone that was driving a capricorn rc car that I havent creditted, the myrcm results had no sponsor information. If anyone knows of drivers please send me a PM with their names and I'll update the video.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 11-24-2012, 09:22 PM   #1798
Bundy_Bear's Avatar
h
Well done, audio was very well themed
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-26-2012, 02:54 AM   #1799
Bundy_Bear's Avatar
Doh... obsolete already
http://www.redrc.net/2012/11/caprico...02-wc-edition/
MissMooRC Racing
Old 11-29-2012, 12:54 PM   #1800
RC-Netshop.dk's Avatar
Default C02 Worlds Edition
Hi everybody,
Just wanted to say the C02 Worlds Edition is ready, Cap will probeably announce it one of these days officially.
Only 100pcs is produced.
Upgrades are:
All suspension parts in hard plastic version
New belts
New spring pipe support
Weight under tank
F1 sway bar
New 2speed shaft
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
