Old 03-23-2010, 01:59 PM   #166
RC MARKET's Avatar
Originally Posted by el salvador View Post
As KMW said, there is plenty of clearence with the front belt and the steering linkage to "Shim", either inner, or outer linkage geometry. If you mean Ackerman, there are 3 different plates included in the kit for this. This car seems to have about the same level of adjustment as say, the VoneRRR does.
Ackerman can't direct control in rolling outside wheel steering .
RC MARKET is offline   Reply With Quote
Old 03-24-2010, 05:06 AM   #167
Originally Posted by PhatPat View Post
Whats going on with the springs? I only see the progressive hard springs that come with the car. Are we to use Xrays or kyosho if we want to change or is Capricorn gonna produce a variety of springs.
Stock springs are perfect for the manual initial settings and by the way they are the springs used by Toso in the warm up race.
Shortly we will release a softer springs.
The progressive springs are very similar to the stock spring but with softer initial reaction.
The harder type is the "CHROME" color spring.
CapricornRC is offline   Reply With Quote
Old 03-24-2010, 05:15 AM   #168
Originally Posted by RC MARKET View Post
this car can setup wheelbase & bump steering ?
The LAB-C01 has the wheelbase setup adjustment.
The lower rear arm has a 2mm shim that can be moved in front or rear of the arm itself. In rear position we lower the wheel base ... but u need to turn (180) the upper arm as well.
Old 03-24-2010, 05:23 AM   #169
Originally Posted by juki View Post
is anyone had a problem with the included kit centax clutch?mine was constantly slipping..even with the basic setup.after checking the clutch bell, it seems that the inner bearing housing wasn't deep enough to seat the inner bearing on the clutch bell..i've tried placing the bell without the bearing to check the gap between the bell and the shoes and it's there's to much gap between them...can anyone help?oh and tosso, i was using 31,8mm flywheel...
Hi.
Usually a well registered clutch need from 1,3 to 1,5 mm shim.
If u have gap from shoe even without shims then of course the bell shud have a problem or (we just wonder) the bearing house is busy from something that may avoid the bearing to place in it correctly.
Feel free to contact the dealer where u bought the car to ask the bell replacement.
As for thge flywheel .. yes we used the 31,8 mm
Old 03-24-2010, 11:23 PM   #170
dougday's Avatar
Originally Posted by Chris Tosolini View Post
Um what is wrong with the clutch bells????????? please tell me for as I have built about 100 of them and never had a problem....
Chris,
I think he must be using the wrong bearings
dougday is offline   Reply With Quote
Old 03-26-2010, 05:48 AM   #171
nikoskar's Avatar
We creating a video assembly of the car for Greek RC Modelers.
If you like you can view the first 2 parts (click here)
The following will be shorter.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 03-26-2010, 12:56 PM   #172
hi to everyone, i hope you could answer me this question and i hope this is the right place to ask it, do any of you know where can i get the capricorn clutch wc 2010 for the nt1 in any site of the us?
thanx
mc_chofo is offline   Reply With Quote
Old 03-26-2010, 01:20 PM   #173
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
where do I sign up to get the Capricorn 70,000 weight oil? Tired of mixing my own
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-26-2010, 02:37 PM   #174
RC MARKET's Avatar
mixing 60K & 80K
Old 03-26-2010, 05:39 PM   #175
chris, i saw the clutch at team epic, but the one they have is the 08 version, do any of you know what is the difference between the 08 and 2010 nt1 version?
thanx
Old 03-26-2010, 06:14 PM   #176
Fuin's Avatar
Hello
What is the Capricorn Humid tire for?
Fuin is offline   Reply With Quote
Old 03-26-2010, 06:34 PM   #177
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Can anyone with the lab do a side to side comparison with the car they use to run......i.e what u think it does or doesn't do better!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 03-26-2010, 10:03 PM   #178
YmeBP's Avatar
Trader Rating: 32 (100%+)
I think Epic might have some....
I would think that you could get the clutch from Trinity, or team Epic.
thanx
I'll have some in stock early next week.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 03-27-2010, 11:40 AM   #179
juki's Avatar
Originally Posted by dougday View Post
Chris,
i'm using the included clutch bell bearings from the kit and followed the manual...and still had a problem..I've builded two kits and the result is the same..when i'm using the sirio's clutch bell, no problem at all...no more slipping..
juki is offline   Reply With Quote
Old 03-27-2010, 02:55 PM   #180
Quick question just finished building the Capricorn car and was wonder what i a good starting point for the 2 speed? I ran my mugen for years 3 turns out from bottom. Any recommendations or suggestion would be great.
Brad
bradley70 is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
