Old 05-14-2012, 05:21 PM   #1606
DS Motorsport's Avatar
Originally Posted by djiewie View Post
Looks good Daan, this will sure help at Rucphen.
A idea for next year; shift the lipo to the side (serpent way) and redesign the fueltank flat on the chassis. it will have a Cap tank then wich is also nice.
or put the lipo in front and the tank wider also flat on the chassis.
Great improvements on a already improved car.
I'm not really a fan of the lipo on the outside, it will move weight out of the center which is a bad thing.
Since you're not able to completely lower the tank on to chassis level because it needs a lower fuel pickup point you will end up with an empty space which you can either place weight or a battery.
Designing my own tank is out of the question unfortunately because of costs. First thing in line is a new chassis.
Originally Posted by Chickentrader View Post
Very impressive work Daan!
Could I pre-order 2 sets of Carbon fibre wheel discs (for 2 cars) to beat the rush when you put them on the market? Lay down servos is a good way to lower CG; and it has been tried used by some manufacturers in some models, but we won't try this option just yet.
How much do the disks weigh? And do you epoxy a threaded plastic tube to the uprights to fix them to the car?
Keep the good work going!
Kindest regards,
Lars.
Thank you Lars.
No problem, I hope to start on the production parts end of this week or early next week.
One disk plus mounting hardware weighs 3 grams.
Yes, I used superglue to glue the threaded tubes to the uprights.
Originally Posted by speed6 View Post
Shock oil help
If i use 50wt in 2 hole what do you guys recommend in the following
4 hole and 6 hole
4 holes 1000-1200cst depending on springs and track
6 holes 1500-2000cst depending on springs and track
Originally Posted by British Menace View Post
On the subject of Silicone oil ..... are the Capricorn diff oils supplied in CPS or in WT?
BM
Capricorn oil is rated in cps as far as I know. So when a bottle says 55 it's 500cst oil.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-14-2012, 05:27 PM   #1607
This weekend I tested the new DS Motorsport parts and tests were very successful.
I ended up winning the race and setting a new track record.
The wheel discs and front bumper gave the car more grip in the high speed corners so I could turn in faster and hit the throttle earlier.
The new radio tray made the car change direction quicker and I think it had a tiny amount more steering entering the corner.
All parts were tested independently and back to back to give a true indication.
Here you can find the setup I used:
http://dsmotorsport.nl/http://dsmoto...H_BC3_2012.pdf
P1-RC.com
Old 05-14-2012, 06:55 PM   #1608
British Menace's Avatar
Congratulations Daan .... An excellent achievement
Any word on my car yet?
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 05-14-2012, 07:16 PM   #1609
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Lets not got there.....
Michael_T is offline   Reply With Quote
Old 05-15-2012, 04:49 AM   #1610
I'm sorry but, do I know you?
DS Motorsport
Its good to see your developing the car like this.
If you could PM me I would greatly appreciate it .... thanks Daan
BM
Old 05-15-2012, 08:59 AM   #1611
DS Motorsport
BM
Send you an email, car is on the way.
P1-RC.com
Old 05-15-2012, 12:14 PM   #1612
Congratulations Daan!
Well done and the new parts look good.
By the time I will receive My car I will try some special carbon products and maybe I will design some new carbon fibre parts.
s.i.jerefos is offline   Reply With Quote
Old 05-15-2012, 01:31 PM   #1613
djiewie's Avatar
i meant like this. Is it worth a try you think? Say next winter project for me?
Capricorn LAB-C01-2012-05-15-21.14.56-2-.jpg   Capricorn LAB-C01-2012-05-15-21.15.14-2-.jpg
djiewie is offline   Reply With Quote
Old 05-15-2012, 02:53 PM   #1614
Nice overflow for the fuel tank, is that a mod? Really wish to do soming like that to the CAP Tank as on race days since pitting is a bit aggressive fuel makes a big mess
speed6 is offline   Reply With Quote
Old 05-15-2012, 03:08 PM   #1615
Default lab c01
Lab c01 for sale w/ almost another car kit in parts , plus bags of parts. Spare clutches,one ways, diff oils. Pm if interested. Will give the run down on additional parts. At least $500 in parts.
JOSEPH WRIGHT, 2015 FUEL ONROAD NATIONALS FINALIST
SPONSORS: DESOTO RACING , MATRIX TIRES , PUMPKIN PITS ,
upncoming is offline   Reply With Quote
Old 05-15-2012, 03:14 PM   #1616
Originally Posted by DS Motorsport View Post
Ok, hereby some pics of the first prototype parts I've designed for the C02.
-New radio tray design which has a lower and more centralized CoG compared to the original tray.
-Carbon fiber wheel discs which prevent turbulent air to enter the rims which causes lift.
-New front bumper/ body post for more downforce.
The radio tray is a very slim design which has been designed to be fully symmetrical in terms of flex. On throttle the design uses a low profile servo which gives the car a lower and more centralized CoG. For steering you can use both type of servo.
The entire weight of the radio tray is also lowered compared to the stock tray.
Also the entire electronic unit can be removed by just taking out 3 screws, you don't even have to remove the radio tray itself to remove the electronics.
As an extra tuning option you can move the electronics unit forward or backward to change the car's static weight balance. This is a great tuning option to set the car up for either high speed or low speed tracks.
The production version comes with a revised receiver mount which places the receiver 5mm higher. With the current design the receiver could hit the ground when you cut the corners too much.
The carbon fiber wheel discs are almost fully closed and have a very small gap to the inside of the rim. This causes a high pressure area to develop on the outside of the rim and a low pressure area on the inside. This causes an increase in grip which is especially noticeable on high speed corners.
The front body post mounting plate is designed to work together with the Mugen MTX-5 front bumper/splitter. This design gives an increase in front downforce compared to the original front bumper design. The entire assembly also takes away quite some weight in front of the front axle which will help the car to change direction quicker.
I'm also working on a new chassis design which will give the car more front end grip and fully symmetrical flex.
I'm planning on having an official press release posted on redrc at the end of next week.
Pre Order
Carbon Fibre Wheel Disc
Front bumber post mod
Old 05-16-2012, 02:48 AM   #1617
djiewie's Avatar
yes, it was made by me for the same reason. Just a piece of lexan and using the heatgun. The tank has an fuel outlet though on wich i put a piece of tubing to lead the excess fuel beneath the car.
Old 05-16-2012, 01:59 PM   #1618
Nice work sir...... and very practical too!
BM
Old 05-16-2012, 02:57 PM   #1619
MrHistory's Avatar
Does the car feel ok with full size servos or do I need to drop 300 to get ko propo rsx one10 servos? For a club racer...or how about ko 2413's?
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 05-16-2012, 04:11 PM   #1620
IMO you would really only go to the low profile servos to save weight. Since the Cap is obviously a very light car out of the box there really isnt any disadvantage to going to full size servos.
Again just my opinion.
Simon
Team_Krusty is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
