Old 01-23-2010, 09:01 PM   #1
Exclamation HELP WITH HPI RC4 Racer
Hi,i got this RS4 Racer,and i want to make it fast,is all stock and finelly tuned,i want to get the best gears combinations,the better tires,clutch,belts,or all good tricks to make it Faster,so any help ?? Thanks
OFNA_Rookie is offline   Reply With Quote
Old 01-23-2010, 10:28 PM   #2
Hello i have a Nitro RS4, How can i make it faster ? what upgrades do i need ..,ITS all stock and Finally tuned,i want to get the best gear combination, better tires,clutch,belts,or all good tricks to make it Faster,so any help ?? Thanks
So people may maybe understand u more.. Lol sorry
Clairvoyant16 is offline   Reply With Quote
Old 01-24-2010, 06:49 AM   #3
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Tips
Are you using faom tires if not get them,2nd if you can find them, when i had the car about 11 years ago, i was using the 2spd gears and clutch from the cen car ,it had better gear combos back then.Also check ebay from alot of the aftermaket parts,for the car is discontinued, so this may be the best route to follow.Hope this helps.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-20-2010, 03:21 PM   #4
LeeLockhart's Avatar
http://www.rctech.net/forum/r-c-item...ight=rs4+racer
KO PROPO. ORION. THUNDER POWER.
LeeLockhart is offline   Reply With Quote
