Old 03-21-2004, 09:48 PM   #1
Ducati-Rider's Avatar
Unhappy Fly Wheel Puller Tool - Sources??
Guys
How do you loosen the flywheel from the motor shaft? Does anyone use or know of a source for a gear puller tool; that pulls the flywheel by a screw pressure on the end of the shaft?
I used to have a tiny one to pull the pinion gear off slot car motors. Now with multiple cars and motors I want to swap motors around and need to easily pull the flywheel.
I did a search and could not find anything?
Ducati-Rider is offline   Reply With Quote
Old 03-21-2004, 09:58 PM   #2
DickemDown's Avatar
kyosho makes a flywheel puller. i 've also found a car battery terminal puller @ sears for around $9 bucks - it'll do the job as well. by the way, the kyosho is around $39 bucks.
DickemDown is offline   Reply With Quote
Old 03-21-2004, 11:48 PM   #3
mckrooz's Avatar
Send a message via AIM to mckrooz
Go to Autozone or any automotive parts store and get the battery terminal puller. It's pretty much the same thing as a "flywheel puller".
mckrooz is offline   Reply With Quote
Old 03-22-2004, 11:02 AM   #4
Default Thanks
Thanks for the advice
guess I don't need some $50 tool for a $5 solution.
Old 03-22-2004, 12:54 PM   #5
1fastdude's Avatar
Trader Rating: 15 (100%+)
There really is not a need for a puller. Just tap the flywheel with a rubber hammer..... it should pop off!
1fastdude is offline   Reply With Quote
Old 03-22-2004, 01:35 PM   #6
Roger's Avatar
Yups, I have a rubber mallat that does the trick
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Huge RC Tool lot! Soldering station, wheel balancer, hex wrenches, & more! 80+ tools HoustonAreaRC R/C Items: For Sale/Trade 3 06-07-2008 06:22 AM
Sources of Entertainment......! prince007 Chat Lounge 30 10-12-2006 05:29 AM
Motor Tools - Sources? Ducati-Rider Electric On-Road 3 12-06-2004 05:26 AM
M18 Ball Diffs - Sources? Ducati-Rider Electric On-Road 3 10-20-2004 09:44 PM
New Tool, Flywheel puller microRCshop Nitro On-Road 2 07-14-2004 10:31 AM
