Old 09-02-2010, 05:39 PM   #121
Bundy_Bear's Avatar
Originally Posted by GREGORY! View Post
i can't see their page.i don't know why!
Gregory:
If it is the JPM Website you are talking about, it doesn't work for me either!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-02-2010, 06:00 PM   #122
Originally Posted by Bundy_Bear View Post
Gregory:
Hi Guys the JPM website is down at the moment changing host provider and rebuilding site. Joe and Brad apologize for any inconvienence.
Cheers,
Michael
Mike 78 is offline   Reply With Quote
Old 09-02-2010, 06:04 PM   #123
Hi Mike
Thank you sir, how did you end up going at the Qld titles? The final was a good race to watch between Jeff Hamon and Janovic (spelling unsure...)
Hi Andrew,
i had an absolute shocker was on a decent qualifier in the 5th round and was taken out, only made the quarter and my own mistake i put to much ride height in and cut the tyres to big so she kept rolling everywhere also the engine went lean found the middle adjustment o'ring to have leaked. Very dissapointing but there is always next year. Awsome track and facilaties though.
Awesome final between Stevie J and Jeff Hamon and lets not forget that Jesse Davis bought his Edam home in third position with a very consistant race. Can't weight till next year.
Cheers,
Michael
Old 09-03-2010, 03:32 AM   #124
Bundy_Bear's Avatar
Originally Posted by Mike 78 View Post
Hi Andrew,
Cheers,
Michael
Hi Mike
Sorry to hear about your misfortune, Jesse did well he just couldn't keep up with Jeff and Steve, but he stayed out of trouble and ran his own race
MissMooRC Racing
Old 09-09-2010, 12:20 PM   #125
Send a message via Yahoo to Speedy Gun
no the one way now runs on an independent shaft and is now 8mm rather than the old 6mm. ran the gearbox all weekend with only one little hickup (my own fault) other than that the car was great.
Does the 2nd gear bell houseing roll truer than the last design?
edamhobby.com/teammarketingamerica.com/gqamerica.com/eteamhobbyplex.com
Speedy Gun is offline   Reply With Quote
Old 09-09-2010, 07:15 PM   #126
Everything now in the gearbox area is lot better and runs alot truer. the only thing now that need to be in my mind is better setup for the shoes to make the change a lot more consistent.
Old 09-14-2010, 11:56 AM   #127
Has any one ever run kick up with the front upper mount being angled with a shim/shims in the front, less or no shims in the rear? Going to give it a shot this weekend and see how it works out.
Old 09-14-2010, 02:51 PM   #128
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
First race ever on Spirit 981.
TQed the event with almost 1 second faster than the following guy, ended second place on A-Main due to some heavy problems of finger/brain coordination
Very nice chassis, very reliable, predictable car, loved it ...
cya !
Pat
Tabushi is offline   Reply With Quote
Old 09-15-2010, 04:30 PM   #129
Thumbs up
cya !
Pat
Nice job Pat, what shore where you useing down there and how long was your main?
Old 09-15-2010, 07:46 PM   #130
Tabushi's Avatar
Used 40 front and 40 rear (Matrix), A-Main is a 2 x 20 minutes format.
cya !
Pat
Old 09-16-2010, 02:08 PM   #131
cya !
Pat
Cool in that format do you get to do any repairs or changes in between the two mains? That format in the states would save a lot of headaches I would think,in terms of your own main. It probably could make a longer race day unpleasent in the time it would all end, so I dont think it would work here.
Old 11-19-2010, 12:24 PM   #132
Hi Guys,
I ordered the new 2 speed upgrade. What difference should i expect from the old one?
Regrads
Matthew from Malta
Teamcastagna is offline   Reply With Quote
Old 11-20-2010, 04:21 PM   #133
Originally Posted by Teamcastagna View Post
Hi Guys,
Regrads
Matthew from Malta
Hello Matthew, I cant say anything on the upgrade, havent done it yet. Mike 78 can probably answer that best.
Old 11-22-2010, 04:50 PM   #134
Hi Guys,
Regrads
Matthew from Malta
Hi Matthew,
the main thing you will find once set correct is a more consitent change. I think this is due to everything through the 2 speed no runs a lot more truer. i also replace my 2 speed springs a lot more often now to help with the consistency roughly every 3rd to 4th race meeting. other advantage is also it is light weight so it will help with evry thing spooling up alot quicker. i also have lightened my spur gears as well by drilling them out equally around the outside diameter.
So by rights the 2 main things you will find is the 2 speed will run truer and you ahould have a little more punch out of corners due to the lightness.
i hope this helps Matthew and apologizes for the late reply.
Cheers Michael
Old 11-24-2010, 12:04 AM   #135
Bishop's Avatar
Anyone know if the Edam receiver box fits the MTX4?, I loathe exposed radio gear, but I'm hoping to graft on a Edam or Shepard box, though I have no idea where to get Edam gear from?.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
JustHobby 1/10 Onroad GP Challenge Race 7, 08 Nov'2009 justhobby Singapore R/C Racers 24 11-09-2009 01:12 AM
Recommendation for onroad newb under $400 TheWired Nitro On-Road 11 09-18-2009 12:41 PM
Bundy's End Of Financial Year Sale!!! Bundy_Bear Australia For Sale/Trade 7 06-27-2009 01:03 AM
