Old 05-05-2010, 02:01 AM   #76
Good weekend for Edam in the UK. At round 2 of national series, Luke Longley took 2nd in the 200mm 'foam' class, and Ian Billett 2nd in the 200mm 'rubber' class. This was the Spirits first national race meeting in the UK, so well done to both drivers.
rc-direct.co.uk ,Team Titan ARC R10, Edam Spirit and Razor, Enneti tyres, Blitz bodyshells
Edam Racer is offline   Reply With Quote
Old 05-09-2010, 10:17 PM   #77
hi.im just new to the rc scene.i bought an edam kit and just started playing around with it now.
wat r the best springs to run on it?ive heard people talking bout using kyosho springs,if so which model are they from?
weve had a 2speed spring prob as well but have the update on the way for that.
also what are the best brand of tyres to use?
any other suggestions on the car would be much appreciated
trevor hunt is offline   Reply With Quote
Old 05-09-2010, 10:59 PM   #78
Most people are using kyosho v-one rrr spring. But I am using x-rays as I had lot of them from my nt1. For tires any big brands like ATS, exceed, Edam, etc should work fine. Depend on where you run it try front/rear 37/40 or 35/37 should be a good starting pt.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 05-09-2010, 11:06 PM   #79
Hi Trevor,
Where are you from ? what condition is the track you are running on ? which engine did you choose to run in the car ? i myself use the kyosho light springs alround i'm still using the standard 2 speed with no real major issues all i done was take the anodize off the hub and i rounded the 2 speed shoes a little more than standard. tyre wise i have found the likes 37 all round i usually use ats tyres but am trying a set of capricorn as i have heard the wear is a lot better and better traction. if the heat comes up i normally swap to 40's all round.
Anyway i hope this helps,
Mike 78 is offline   Reply With Quote
Old 05-10-2010, 12:10 AM   #80
im from western sydney.ive been playing around with it atthe whalan track.
but ill prob run in the penrith comp once i have an idea of what im doing.
ive only just ordered a set up station so hopefully that will help a bit.
i was running ats but i bought a pair of enneti tyres and they seem pretty good for daytime.im running 40s all around
ill give the kyosho springs a go.have heard its like a diff car when u change them
theres so much 2learn
im running the rb matrix with the gold edam exhaust
theres so much 2learn and adjust on these.i had no idea.
Old 05-10-2010, 03:00 AM   #81
if you are running around whalen on 40s and the track hasnt been cleaned the car will be an absolute handfull try 35s front and rear for there especially now that the colder weather is coming.
Trevor more than happy to try and help you out, i have sent you a pm.
Old 05-10-2010, 03:38 AM   #82
yeah i had 35s on but couldnt keep the car straight but it was a warm day.
didnt help that the car isnt set up at all.lol
Old 05-10-2010, 04:34 AM   #83
Bundy_Bear's Avatar
What about me, it isn't fair.... It's okay i get the no Edam love picture!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-10-2010, 04:50 AM   #84
Come on Andrew you gave up on the Pursuits and went back to a team magic
Old 05-11-2010, 04:14 AM   #85
Bundy_Bear's Avatar
Mike:
This is true i did... but it is because you don't love me anymore!
I am now trying to play VRC instead and i am somehow rubbish at that too
MissMooRC Racing
Old 05-18-2010, 05:54 AM   #86
C'mon guy's what's been happening out in Edam world ??????????
Old 08-18-2010, 01:40 PM   #87
Send a message via Yahoo to Speedy Gun
Has any one had a over flow problem with the tank where you tilt the car a little and it wants to die at idle . Adjust the bottom end very little change, checked the tank for air leaks checks out fine. Changed pipe only thing not changed is the motor. If any body has an anwers or ideas thanks.
edamhobby.com/teammarketingamerica.com/gqamerica.com/eteamhobbyplex.com
Speedy Gun is offline   Reply With Quote
Old 08-19-2010, 01:23 PM   #88
probably tuning, i usually pick my car up and shake it once or twice vertically and the car dies.
btw, no news for the edam world from here. there were a couple of drivers at the worlds but I don't think I saw anything anything revolutionary.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-20-2010, 02:11 PM   #89
Brian or others, has anybody ever ran the with car with the 2.5 upper deck compared to the 2.0 & if so any difference?
Old 08-20-2010, 02:59 PM   #90
I wasn't aware of a different top deck but I cut mine a while back to do the same thing as what a thinner plate would do, create flex.
flex creates steering with low traction. the thicker plate would be better for higher traction
JustHobby 1/10 Onroad GP Challenge Race 7, 08 Nov'2009 justhobby Singapore R/C Racers 24 11-09-2009 01:12 AM
Recommendation for onroad newb under $400 TheWired Nitro On-Road 11 09-18-2009 12:41 PM
Bundy's End Of Financial Year Sale!!! Bundy_Bear Australia For Sale/Trade 7 06-27-2009 01:03 AM
