Old 03-08-2010, 02:57 AM   #61
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Edam Racer View Post
Went out with spirit yesterday and i don't know whats happened but it was handling like a pig, NO REAR grip and very little front. My setup is pretty basic. 30wt oil in rear shocks 50wt in front. 50,000 in front diff and 30,000 in rear. 6.5mm ride height front 7 rear (I would lower this but its as low as it will go) Camber is so tyres wear flat. -1 toe out at front +2 toe in at back. Roll bars were semi-hard.
What is wrong with that setup, my track is a low grip track, with fast bits and some tight bits.
Any help would be helpful
Luke
Hi Luke
See below for a base line low grip setup for the Edam. Let me know how you get on, if you have any questions don't hesitate to ask.
Edam Spirit Base Setup Low Traction
Front:
Front Width: 199mm
Ride Height: 5.5mm
Upper Suspension Holder: Middle
Upper Arm Mount 2 shims
Roll Bar: 45 Deg
Toe: .5 Toe Out/Side
Droop: -1mm
Bump Stop: Nil
Castor: 2mm in front of arm
Shock Oil: 1000 cst
Shock Piston: 2 hole
Shock Spring: 33 Lb/In
Shock Position: Middle hole
Front Axle: Spool
Rear:
Rear Width: 200mm
Ride Height: 6 mm
Lower Suspension Mount: Middle Hole
Camber Link: Lowest Hole
Roll Bar: 0 Deg
Toe: 3 deg Toe In/Side
Droop: 3 mm
Shock Oil: 1000 cst
Shock Piston: 3 hole
Shock Spring: 23.5 Lb/In
Shock Position: 3rd Hole Up
Rear Diff: 30,000 wt
Side Pully: 23T
Body:
Blitz Altis 2.3
Regards
Kyle
ARC R8 RB - Blitz Kronos Tyres - Futaba
Kyle Hazell is offline   Reply With Quote
Old 03-08-2010, 11:26 AM   #62
Originally Posted by Kyle Hazell View Post
Hi Luke
Front:
Front Width: 199mm
Ride Height: 5.5mm
Roll Bar: 45 Deg
Droop: -1mm
Bump Stop: Nil
Shock Oil: 1000 cst
Front Axle: Spool
Rear:
Rear Width: 200mm
Ride Height: 6 mm
Roll Bar: 0 Deg
Droop: 3 mm
Shock Oil: 1000 cst
Side Pully: 23T
Body:
Blitz Altis 2.3
Regards
Kyle
Thank you, i will put that setup on my car and see how it goes. With ride height, with my serpent 720 i could get 6mm all over with 65mm foam tyres, but now with the spirit i can hardly get 6mm with 58mm foam tyres. Any ideas?
Cheers
Luke
rc-direct.co.uk ,Team Titan ARC R10, Edam Spirit and Razor, Enneti tyres, Blitz bodyshells
Edam Racer is offline   Reply With Quote
Old 03-08-2010, 12:54 PM   #63
Cheers
Luke
Hi Luke,
I have not an issue like that, optimum tyre size is 57F/59R. I used that size on the weekend with 6mm ride height.
Will send you though a pm with my email address, send me a pic when you get a chance and I will take a look.
Regards
Kyle
Old 03-08-2010, 01:05 PM   #64
Send a message via AIM to jeff whiting
Hey everyone. I won a EDAM Spirit 981 Kit at a resent race. It seems like a pretty cool car but due to sponsorship commitments I just can't use it. PM me if you are interested. Oh and one more thing I really appreciate EDAM being a race sponsor and providing the kit.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 03-09-2010, 02:14 PM   #65
Cheers
Luke
the rear shock springs are too long for the car. they could have made the bottom shock seat flatter to help but really you just need different springs.
I'm still running the kyosho shocks at the moment, the length and bladder are not ideal for me yet so I am hoping for some kind of change.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 03-19-2010, 04:03 PM   #66
Whats going on out there in SPIRIT land been very quiet here ?????????
I know in Aus that Edam finish 1st and 3rd at SORMCC last week good drives from Kyle & Craig (lucky i wasn't there ) any reports from either what setup they ran did you guy's try anything different ?????????
The NSW champs are coming up in a couple of weeks and there is a great number of Edams running there Edam have Jesse Davis from Vic coming up Kyle Hazell NSW and Craig Hawkins NSW in Pro Tourer then in Pull Start there is Steve Valletta NSW and Joe Patane NSW (the Edam importer) and Adrian Vella from Vic as well.
GOOD LUCK boys hope all goes well.
Cheers Michael
Mike 78 is offline   Reply With Quote
Old 03-19-2010, 11:52 PM   #67
Ballistik Mods's Avatar
Cheers Michael
Hey lance nunn also:
Ballistik Mods is offline   Reply With Quote
Old 03-21-2010, 03:37 AM   #68
Default edam wins again
EDAM wins at moorebank race way sydney australia powered by RB
Old 03-25-2010, 09:26 PM   #69
Hey guys been playing around with my Edam during the week thought i would post some pictures and breif description on what i have done -
Fitted Titanium lay shaft
Titanium screws under chassis and in front and rear bulk head sections
Alloy screws through redio plate and rear shock tower
New front layshaft aluminium carrier
Front Diff
Weight 1698grams no fuel and with transponder (hidden in receiver box) 57mm fronts and 59mm rears
I will be giving it a run on sunday we will see how it performs. I have put the base setup that Kyle Hazell used as posted above here except i'm using front diff not spool(if only i could drive like him who knows what might happen).
Does anyone know if you can get a brass battery holder for the Spirit at all ?
Cheers Michael
Old 03-26-2010, 06:44 AM   #70
ma racer's Avatar
Good lookin car...as for the brass battery tray. I have test fitted the YBslow tray for the NT1 and it fits well. http://www.ybslowinc.com/
A word of caution though...be careful using aluminum screws on the stress points on the car. ie. bulkhead, shocks etc...might want to keep those steel or titanium
I am working on a two piece radio tray mount where the lower section is brass and the upper is plastic to help with lowering the cg.
It's not a hobby.....It's a passion!!
ma racer is offline   Reply With Quote
Old 04-18-2010, 05:46 AM   #71
Default VICTORY AGAIN
EDAM & RB WIN AGAIN AT MOOREBANK
Old 04-19-2010, 03:37 AM   #72
Yes Sean, another great win by Kyle and his trusty mechanic Corey and the JPM Racing team.
Old 04-20-2010, 10:58 AM   #73
Hello guys,
Well if you like the Spirit 1/10th Nitro Car, and you like "Gold", then Edam's new release of the Spirit Gold Edition ARTR 1/10th Touring Car just may fill your niche!!
This car is Gold! Featuring all the Optional parts like upper A arm hangers in gold, Golf Titanium layshaft, middle bracket, adjustable steering servo saver, Edam Engine (P30) with Gold Head, and Gold Exhaust System. Of course a beautiful gold chassis sitting on Edam's new foam racing tires with rims colored to match nicely with this Gold package.
Not sure if you actually race this car or build it and place it on the shelf for display??! However the Spirit Gold Edition is a complete Almost Ready To Run kit. Just add your radio system and go play.
I have pictures for all below.
Edam Spirit 10th Scale-edam-racing-spirit-981-gold.jpg   Edam Spirit 10th Scale-edam-racing-spirit-981gold-2.jpg
TM America is offline   Reply With Quote
Old 05-03-2010, 12:59 AM   #74
gunna do's Avatar
well done on the win in the south australian state titles Jessie Daves
and by 3 laps
cheers brett
BLITZ BODIES,FUTABA 4PK,CAPRICORN LAB C02,ATS TYRES,CAPRICORN SQR ENGINES,PROTOFORM SRS N BODIES.
gunna do is offline   Reply With Quote
Old 05-03-2010, 02:24 AM   #75
Default EDAM
It was a great weekend for Edam/RB and JPM Racing. At the SA titles you had - 1st Jesse Davis (Edam/RB) only missing TQ slightly then at Moorebank you had Kyle Hazell (Edam/RB) TQ with fellow JPM Racing driver Craig Hawkins (Edam/RB) in 2nd spot after qualifing then in the finals Kyle won, unfortunatley Craig made a mistake and that led to him finishing in 5th.
Great result for Edam over the weekend, well done to the boys
JustHobby 1/10 Onroad GP Challenge Race 7, 08 Nov'2009 justhobby Singapore R/C Racers 24 11-09-2009 01:12 AM
Recommendation for onroad newb under $400 TheWired Nitro On-Road 11 09-18-2009 12:41 PM
Bundy's End Of Financial Year Sale!!! Bundy_Bear Australia For Sale/Trade 7 06-27-2009 01:03 AM
