Old 01-05-2011, 02:29 PM   #151
Originally Posted by Teamcastagna View Post
Hi Mike,
Hope you are good. Yeah I raced the car 2 times from last time and took 2 victories homes, 1 = 2nd place and the other 3 rd place. I was leading to the 2 races but then at the last lap I paniced and flip over the car with the last corner
I have another small problem. The car is simply not getting free when youmove it. The bearings are superb , new belts all round , brake free
Can you give me an advice on how to get the car more free?
Try looking at the belt tension on all the belts for starters and just make sure that your brakes arnt binding either mechanically or through your radio settings.
Let us know what you find.
Mike 78 is offline   Reply With Quote
Old 01-12-2011, 01:03 PM   #152
Default set up spec
hi have just bought one of these cars and was wondering if anyone has any set specs for whalan and also penrith for pull start class
baldy is offline   Reply With Quote
Old 04-26-2011, 10:28 PM   #153
Send a message via MSN to CameronMADOG
how you guys going with these? I starting racing again after a 7 year break, (1/10th 235 and 1/8th, And all i can say is i love this car! easy to drive and setup.
CameronMADOG is offline   Reply With Quote
Old 04-27-2011, 01:15 AM   #154
Just starting to get the hang of it going to moorebank on the weekend for the first time. so i will let you know after the weekend. I usually run the car at whalan and penrith i have only been driving for 4 months and the times are finally starting to come down.
Old 04-27-2011, 07:54 AM   #155
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
There is any place in USA to locate parts for Spirit and Razor cars ?
thanks
Pat
Tabushi is offline   Reply With Quote
Old 04-27-2011, 03:40 PM   #156
thanks
Pat
search for Pursuit SPT1 they are marketed in america under that name.
Old 04-28-2011, 04:58 AM   #157
Bundy_Bear's Avatar
I was under the impression Edam had stopped dealing with Pursuit as well. But i haven't heard anything from Terry in a long time.
Tabushi:
Didn't you drive an Edam for Pursuit Racing last year before switching to the Team Magic G4RS 09?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 04-28-2011, 11:51 AM   #158
Tabushi's Avatar
Tabushi:
Yes, but that was part of a "test drive" from the importer i race for ... i loved the car, but EDAM policies didnt matched the reality of our small southamerican market, so at the end the importer didnt finished the deal.
I need to locate an EDAM dealer, first to buy small parts to put the spirit back to race mode just for fun of it, and to buy new rear end of razor 1/8 as i got mine finished but with old OS1 type of rear end ...
thanks for any info ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Old 04-28-2011, 02:52 PM   #159
If you can't find any one try Joe from jpmracing.com.au/ and i'm sure he will send you the parts.
Old 04-01-2012, 03:50 AM   #160
Bundy_Bear's Avatar
Hi
I have been helping my brother with his Edam Spirit, just wondered if anyone has had issues with the front steering servo holder flexing under the movement of the servo. The servo will jump forward causing the servo horn to rub on the radio tray. A little quick dremel work by Blis at the track and Friday night as it was alot better.
Another issue is the brake arm flexes causing the brakes to come on. Watch this with your radio linkage setup and make sure the brakes aren't on with WOT.
Andrew
MissMooRC Racing
Old 04-25-2012, 06:15 AM   #161
Bundy_Bear's Avatar
Some further track time today and we are little by little lowering the lap times everytime out. We are running a Jammin .12 in the clubs Gas Tourers class and seem to lacking the punch off the OS .12TG is it in the clutch setup?
This said my brother is just starting out and i think he will have issues with too much more power at the moment.
Any thought would be appreciated though....
Thanks,
Andrew
MissMooRC Racing
Old 04-25-2012, 11:20 AM   #162
ma racer's Avatar
Well,
several things can be associated with acceleration. Clutch is certainly one of the more important one's. Other things you might look at is :
tire size
gear ratio's
tuning of the motor/how new the motor might be
suspension set up/ how soft or firm the springs are.
droop settings
All of these things play their own little part of acceleration
It's not a hobby.....It's a passion!!
ma racer is offline   Reply With Quote
Old 04-25-2012, 11:08 PM   #163
Bundy_Bear's Avatar
Originally Posted by ma racer View Post
Well,
tire size
gear ratio's
droop settings
Hi
Thank you for your prompt reply, we are running the standard gearing, tires are trued to 60mm front and 62mm rear...
We have been working on the suspension and droop settings, this is in combination with weight of diff oils and the sway bar settings have made the car easier for my brother to drive and lowered his lap times.
Gearing i am not sure about, maybe it's not right for this .70hp engine, but when the clutch engages it just seems to bog down rather then leap the car forward like we are seeing with the OS .12TG powered Mugens etc.
Thanks again
Andrew
MissMooRC Racing
Old 04-26-2012, 08:47 AM   #164
ma racer's Avatar
You might try one of these. Lower the first gear pinion by a tooth. Another option is to raise the the first gear spur by a tooth. And also you might try to tighten the clutch spring a little bit in order to engage it a bit later so that the motor is in a better power range. Just a few thoughts.
Old 04-26-2012, 07:31 PM   #165
Bundy_Bear's Avatar
Red face
Thanks, will try that tonight weather pending. Would great to see some discussion happening for this great car.
Andrew
MissMooRC Racing
JustHobby 1/10 Onroad GP Challenge Race 7, 08 Nov'2009 justhobby Singapore R/C Racers 24 11-09-2009 01:12 AM
Recommendation for onroad newb under $400 TheWired Nitro On-Road 11 09-18-2009 12:41 PM
Bundy's End Of Financial Year Sale!!! Bundy_Bear Australia For Sale/Trade 7 06-27-2009 01:03 AM
