EDS Racing Tools
EDS Racing Tools
How is the quality of their tools? How does it compare to Hudy? Are there any other options I should be looking at?
I am thinking about buying one of their big tool bundles where they let you pick the tools which is better for me as a Losi owner. Brands like Hudy don't have any packages that really fit Losi cars, so it gets super expensive VERY fast.
They are excellent, my second favorite tools.
My favorite are MIP but if you need everything, EDS sets are hard to beat.
Are there any specific tools that they make that are sub-par? Like should I avoid their Flywheel Tool or anything along those lines? I am outfitting a 25 piece set and I am already over the 25 tool limit....so if there is anything that I might get superior tools elsewhere for a specific job it would be awesome to know.
Also since I plan to race a Losi 8ight are there any obvious tools that I am missing? I picked some extra metric tools in case I ever switch to a different brand buggy too. And yeah I know I posted this in the wrong forum since it should be in off road...my 2nd time doing that.
Right now I have these on my list (so I am two over the limit):
27 Part numbers listed below
Nut Drivers (7)
3/16 EDS-150247
1/4 EDS-150263
5/16 EDS-150279
11/32 EDS-150287
5.0mm EDS-150150
5.5mm EDS-150155
7.0mm EDS-150170
Allen Wrenches (8)
.05 in EDS-110256
1/16 EDS-110263
5/64 EDS-110278
3/32 EDS-110293
1.5mm EDS-110115
2.5mm EDS-110125
2.0mm EDS-110120
3.0mm EDS-110130
Screwdrivers (6)
3.0 x 120mm Slotted EDS-130130
5.0 x 120mm Slotted EDS-130150
3.5 x 120 Phillips EDS-140135
4.0 x 120 Phillips EDS-140140
5.0 x 120 Phillips EDS-140150
5.8 x 120 Phillips EDS-140159
Special Purpose (6)
Flywheel Remover (.21+) EDS-190007
Arm Reamer 4.0 EDS-190023
Reamer for Lexan EDS-190003
Turnbuckle Wrench 5mm EDS-190010
Glowplug Wrench EDS-190002
Exhaust Spring Tool EDS-190001
Nut Drivers (7)
3/16 EDS-150247
1/4 EDS-150263
5/16 EDS-150279
11/32 EDS-150287
5.0mm EDS-150150
5.5mm EDS-150155
7.0mm EDS-150170
Allen Wrenches (8)
.05 in EDS-110256
1/16 EDS-110263
5/64 EDS-110278
3/32 EDS-110293
1.5mm EDS-110115
2.5mm EDS-110125
2.0mm EDS-110120
3.0mm EDS-110130
Screwdrivers (6)
Special Purpose (6)
Nut Drivers (7)
3/16 EDS-150247
1/4 EDS-150263
5/16 EDS-150279
11/32 EDS-150287
5.0mm EDS-150150
5.5mm EDS-150155
7.0mm EDS-150170
For nut drivers, I just use a cheap, 1/4 drive socket set from craftsmen and an ancient snap-on handle. But if you race pan cars, the 1/4 nut driver is a near must.
Allen Wrenches (8)
.05 in EDS-110256
1/16 EDS-110263
5/64 EDS-110278
3/32 EDS-110293
1.5mm EDS-110115
2.5mm EDS-110125
2.0mm EDS-110120
3.0mm EDS-110130
You need all of those.
Screwdrivers (6)
Some people prefer the RC screwdrivers, some people like me just use hardware store screwdrivers.
Special Purpose (6)
Flywheel Remover (.21+) EDS-190007 Not needed but nice.
Arm Reamer 4.0 EDS-190023 Never needed them myself
Reamer for Lexan EDS-190003 Fantastic. Very quick and clean.
Turnbuckle Wrench 5mm EDS-190010 I use pliers but they are nice.
Glowplug Wrench EDS-190002 I prefer my modified OS wrench
Exhaust Spring Tool EDS-190001[/QUOTE] Great on those caster clips. How did I live without this for so long?
3/16 EDS-150247
1/4 EDS-150263
5/16 EDS-150279
11/32 EDS-150287
5.0mm EDS-150150
5.5mm EDS-150155
7.0mm EDS-150170
Allen Wrenches (8)
.05 in EDS-110256
1/16 EDS-110263
5/64 EDS-110278
3/32 EDS-110293
1.5mm EDS-110115
2.5mm EDS-110125
2.0mm EDS-110120
3.0mm EDS-110130
Screwdrivers (6)
Special Purpose (6)
In addition, you may want to look into getting the power tool allen drivers. A cheap cordless screwdriver and a set of those can make building a new car MUCH more enjoyable.
I really want the screwdrivers since I have nightmares of my original RC10's alloy screws stripping back in the day.
I have a huge set of Craftsman tools that I use on my real car, but I figured I should get a good set for the RC car that I can carry with me to the track.
But maybe I will review my list. I might swap the Nut Drivers for a powered set. I am just really nervous about stripping stuff with a power set.
No, he is saying get a power screwdriver with a clutch. They are available.
Do not use a drill, way too strong and fast. I use a real cheap POS cordless screwdriver from the hardware store. It's so cheap, it doesn't have the power to strip a screw if your careful. Better ones have a clutch on them to prevent stripping.
This is what I use. I only use it for dis-assembly, I use the hand drivers for assembly, this way its harder to strip a thread.
http://www.blackanddecker.com/Produc...ProductID=5483
EDS are very nice tools. Haven't found a no need tool from EDS yet. I really like their clutch adjusment tool. It has more adjustment than the Hudy. For drivers I use the MIP's. MIP's are ground harden drill shanks(extremely hard stuff).the hardest tips I've ever used. MIP does not offer replacement tips but you can send them in for re-sharpening(Never had to use this service in 2 + years of use).
If you use a cordless driver make sure it does not spin to fast. It's the speed of the screw that melts the plastic this will strip the your plastic faster than over tighting.
Pass you soon...
Pass you soon...
If you do use the 1.5mm, I would buy an extra bit. Being only 1.5mm, it is easy to break off the tip. I think they were only a couple bucks. Having your name engraved is a great idea also. Because someone will accidentally pick up one of your tools. A+ for EDS Tools
The EDS hex screw drivers are fine with me... but bear in mind don't use it on Tamiya hex screws cause they surely strip..
