Old 03-21-2004, 08:55 AM   #1
Default failsafe problems
All my radio equipment is kopropo as well as the failsafe.When I plug in the failsafe the light goes on right away. throttle servo will not move with radio and reciever switched in the on postion.I am using the serpent pro battery pak 720mah which should be enough power........help
fasteddie d is offline   Reply With Quote
Old 03-21-2004, 09:00 AM   #2
By the way I have the EX-10 helios with ditigal servos.I didn't know where else is post this question
Old 03-21-2004, 09:06 AM   #3
d.a.d.d.4's Avatar
Post
plug in the fail safe first, w/o any of the servos plugged in, or just the throttle if u have to, and then plug one in at a time, could be one of your servos or the failsafe itself...........but that should show u whats bad, if it goes on before you have anything pulgged up to it, i would say u have found your prblem....you could also switch the throttle and steering servos around just to check........you've probably already done these, but thats the only way i know how to check em........just a thought, have you tried resetting the failsafe?
d.a.d.d.4 is offline   Reply With Quote
Old 03-21-2004, 10:12 AM   #4
Send a message via ICQ to Cartman
Try reading the instructions the Helios will not work with fail safes!when advanced high mode is on! and i would suggest you only use the KO fail safe, only one i found to work 100% with the mars r
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 03-21-2004, 10:47 AM   #5
Boy do I feel like a fool.looked through the manual again and look what I found right before my eye's My friends would say blind in one eye and can't see out the other.Thanks guys.
WOW! He Needs A FailSafe!!! xsxracing Electric Off-Road 1 02-11-2008 09:39 AM
WTB Failsafe Verhalas R/C Items: Wanted to Buy 3 04-24-2006 09:28 PM
having problems with the failsafe classic xl Monster Trucks 5 10-18-2005 05:14 PM
Failsafe Vmax R/C Items: Wanted to Buy 6 02-10-2004 01:16 PM
