-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Problem with my inferno GT (https://www.rctech.net/forum/nitro-road/362227-problem-my-inferno-gt.html)
RCADDICT94 01-19-2010 08:13 PM
Hey, new to this forum, so.. Anyway, I've been trying to restore my Inferno GT (the first version, not the new one) because It's been sitting in my basement for a few years. The engine works fine, and I'm planning on getting new servos for it soon, but a problem I've noticed is that it doesn't shift into second gear. The gears are new, just replaced them, and I put the transmission back together just as the manual says. In a way, I'm new to nitros cuz i sorta forgot what to do, and there's really no LHS nearby me. Can anybody tell me if i'm missing something here?:(
RANDY SMOOTH 01-19-2010 08:23 PM
go to gt buggy base onroad thread they will help you :nod:
CurveTracer 01-19-2010 09:43 PM
Sounds like you need to adjust the 2nd gear shift point. But make sure that the transmission is not shifting into 2nd as soon as the clutch engages.
I recommend the Proboards Kyosho Inferno GT site, http://infernogt.proboards.com/
there is lots of information you can read related to setting up the pawl type transmission to shift.
Timmo 01-19-2010 10:11 PM
Check if your 2 speed clutch/changer is working properly.If it is,then you have to adjust it by screwing in the set-screw on it.In your situation,try screwing in the set-screw more,clockwise,it will make the clutch/changer shift later in the powerband enabling you to hear the shift.
Or check your 2nd gear spur,it has the little pin notched in the gear for engagement.Sometimes that pin wears out and the clutch/changer cannot engage/contact the pin.
Check the manual on page 8 for the clutch/changer adjustment.
Hope this helps a little.
Zootcapri 01-20-2010 09:58 AM
When assembling the tranmission it is easy to flip the second gear clutch.... errr... or so I have heard... :rolleyes:
Make sure that the little arm is going the right direction...
RCADDICT94 01-20-2010 07:45 PM
thanks guys! it's a little late to go out now, so I'll try it out tomorow. hopefully i can get it to shift into second gear tomorow. got the rest of the car fixed up though, new servos, wheels and tires, glow plug, exhaust, etc.
Timmo 01-20-2010 08:34 PM
These cars are a lot of fun.I love mine.
RCADDICT94 01-21-2010 05:32 PM
oh by the way, do any of u guys know the stock engine setting on the inferno gt engine? It's the stock one, GXR.28 i think it's called. just want to get the engine set at factory settings before I try tuning it.
RCADDICT94 01-22-2010 12:41 PM
ran my inferno gt today for the first time in a LONG time, and it was a beast! really happy with how well it works after being left alone for so long. As i was driving it though, I still couldn't hear it shift into second, but i think it does shift. While doing some full throttle runs up and down my street, I can see a great increase in performance after about 3 seconds, but now my question is, is it easy to hear the inferno gt shift?:confused:
Winner's Circle 01-23-2010 06:24 AM
I once put the shift mechanism in BACKWARDS and it would not shift. Check to see if you have it put in the correct way.
Lee
RCADDICT94 01-23-2010 02:22 PM
Lee
I assembled the transmission EXACTLY as it says to in the instruction manual and took a good amount of time to make sure I had everything correct, spent a good hour on that. I'm going to take it to my nearest hobby shop (30 mins away) and see if they can help me out with it. thanks though.
*1speedy 01-23-2010 03:33 PM
Try holding the car with the wheels suspended then give it slowly 1/4-1/2 throttle you should be able to feel the shift even if you don't really hear it.
In my exp with the stock 2-speed there is a good chance it is shifting very early instead of not shifting at all or basically starting out in second gear which is a common occurrence with the stock 2-speed.
To adjust for a later shift turn the adjustment screw clockwise at 1/2 turn increments. (Check your manual for directions how) Keep in mind that because the car sat for a couple of years the spring that is in the 2 speed has been very compressed for a quite some time and has become weaker and could easily be the reason for the problem. You may have to replace the spring if the adjustment bottoms out and it still shifts to early.
Ipanema sells a near bullet proof 2-speed conversion for the Inferno GT you may want to go in that direction.:nod:
Take a look at www.Ipanemasports.com
Hope this helps GL ;)
