Old 01-17-2010, 12:56 AM   #1
Default Ntc3 tires arents moving
so i was riding my tc3 and after i did a burnout the car wouldnt move so i turned it off and when i went to spin the tires they are hard to rotate on the front and back...is it the diffs
salabarria is offline   Reply With Quote
Old 01-17-2010, 01:06 AM   #2
Bizkt Racing's Avatar
it could be the diffs but make sure the car is really clean it could also be the bearings as well but i wouldnt count on it being that it mostef could be the diffs but just make sure the car is clean first
~Team Losi~Alpha Engins~Sidewinder Racing fules~dynamite pipes
~GEttin Big GAps**Bizkt Racing**www.freewebs.com/bizktracing
~www.youtube.com/juggaloryda66
~Canyon Vista R/C~Car #07
~I rather be at the track then with a cheap hooker!!!!
Bizkt Racing is offline   Reply With Quote
Old 01-17-2010, 01:08 AM   #3
oh make sure nothing is binding up on it ether it could be the nuts are to tight cause i cant crank mine down like i would do.see if there is any crunching in the diffs...somthing could be bent in the diff or somthing is binding it up theres a lot that could keep a tc3 from rolling
Old 01-17-2010, 01:13 AM   #4
yea ill have to see cause when i rotate the tires it doesnt make any noise at all it just hard to move it might be that i have to clean it but i think it might be the diffs cause right when i finished doin a burnout like a dumbass it locked up
Old 01-17-2010, 12:24 PM   #5
clod_fan_101's Avatar
Trader Rating: 51 (100%+)
Default when you turn the wheels
see if the motor is turning over . could be a busted clutch shoe hanging up
keep us updated as i m curious
thanks
austin powers # 1 fan
clod_fan_101 is offline   Reply With Quote
Old 01-17-2010, 03:18 PM   #6
i just checked and the clutch is moving but the tires are now a little more loose after rotating them for a while.....could it be that there dirt thats clogging it up or something.....cause if the diffs where stripped the the wheels wouldnt turn,,,,i think lol
Old 01-18-2010, 10:39 PM   #7
LG_4g63's Avatar
Give it a good cleaning and let us know!
LG_4g63 is offline   Reply With Quote
Old 01-18-2010, 10:57 PM   #8
i just used some that compressed air on it and the tires are still a bit tight i think so i might as well take it to my lhs
