Old 03-18-2004, 06:59 PM   #46
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I've seen these tires run (hard to miss those bright orange rims). They look like they drip pretty well. I prefer Take Off tires though.
Nrctc3 is offline   Reply With Quote
Old 03-18-2004, 08:42 PM   #47
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Originally posted by BaxterC
What are there Airfilter's like? anygood... I will not put on a piece of phooey on my $280 motor... it must filter... you dont want to know what I've seen.
it's good, used it in my Novamega and Hyper engines, in a very dusty and sandy environment, the thing you'd have to look for is the oil on it,.. not too much or it'll clog, and your engine'll bog...
it uses a honeycomb foam for its filter (same like full scale HKS filter)
price-wise,... around 12 US bucks for two w/ oil
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 03-18-2004, 09:25 PM   #48
Thunder racer's Avatar
CHUNK CHUNK CHUNK is all i can say. i was running 40s on the rear of my Mtx-3 and if i didnt true them down to like 56mm or lower they would just CHUNK to bits.
Thunder racer is offline   Reply With Quote
Old 03-19-2004, 02:10 AM   #49
Taylor-Racing's Avatar
I think Japanese rubber tends to chunk more than GRP for some reason.
We bevel the sides of the tyres (Active) to about 80 and this effectively fixes the problem.
Your more at risk of chunking a tyre if using more suspension movement, say, on a bumpy track.
. . . and going sideways across ripple strips is just asking for it.
Taylor-Racing is offline   Reply With Quote
Old 03-19-2004, 04:13 PM   #50
GQ tires are also available in Marvin's hobbies and Speedway. They usually stock Mugens and Serpents, 1/8 and 1/10 on-road.
manokgt4 is offline   Reply With Quote
Old 03-19-2004, 05:34 PM   #51
modellor's Avatar
I find the opposite. GRP foam is really bad for chunking here. Japanese rubber is far better on our surfaces than GRP. We even prefer the Swiss rubber better than GRP (UFRA, ARROWS, etc).
Some people think that UFRAs etc are GRP but its not. They are made using Swiss rubber.
modellor is offline   Reply With Quote
Old 03-19-2004, 09:40 PM   #52
Well, there you go, then - different strokes for different folks.
I dare say with so many variables between cars, tracks, conditions, drivers etc. that it's practically impossible to establish what constitutes a good tyre.
At our home track, the Japanese rubber seems better on the sometimes dusty and medium traction surface, but at another track with better traction and higher speeds the GRP's seem maybe a bit more stable. Stability, more than ultimate traction, is a factor, there.
It sure is difficult to figure out who's-who where foam is concerned, but I thought Arrows were GRP.
Have a look HERE
Old 03-19-2004, 10:44 PM   #53
Pyramid's Avatar
Originally posted by InitialD
I would not really know about the first observation but I have very good experience with Speedmind and Sato tires. To me at least, they provide constant traction. Of course traction changes when track and weather changes.
Anyway, contrary to what you mention, their tires do not chunk easy even with the 37 and 35 shore ratings. Especially the sides. As far as I know, they are the most chunking resistant tires out there (if there was any category for this ! ).
Actually my observation is based on 3 different brands: Ellegy, Speedmind, and GQ which I've been using for at least 10 sets of car of each brand on the same track and layout, on the same car and engine, with the same driver (me actually). Plus, what our both retail and wholesale customer have to say
Attahed is the orange nuance painting to fit GQ tires, just for example to share..
Pyramid is offline   Reply With Quote
Old 03-19-2004, 10:49 PM   #54
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default nice body
Pyramid: hey I am really liking that new body of yours. did you paint it yourself?
jscamry is offline   Reply With Quote
Old 03-19-2004, 11:01 PM   #55
Pyramid's Avatar
Default Re: nice body
Local airbrusher did that job for me... It's actually one of that Tamiya TRF Japan driver design but the painter do it in orange to fit the GQ tires.
Old 03-20-2004, 12:36 AM   #56
cox049's Avatar
Hey Pyramid I see you use your tires till the last drop
I got My first 10 sets of GQ's yesterday , The orange color and BBS type wheel is the coolest thing I've seen so far!!! Really worth it to match a body to them!!
cox049 is offline   Reply With Quote
Old 03-20-2004, 02:18 AM   #57
Pyramid's Avatar
I choose the wrong tires shore for 45minutes final.. thats the end result of the tires but chassis already hitting the gound on 25 minutes mark.
Attaached is bottom chassis after final.. it was a brand new car
Good choice on buying GQ.. but the best part is using it so that you know what you've been missing let us know how it turns out for you
Old 03-20-2004, 02:19 AM   #58
Car looks really good Pyramid.
. . . now, please fix the wing.
Old 03-20-2004, 02:26 AM   #59
Originally posted by Pyramid
I choose the wrong tires shore for 45minutes final.. thats the end result of the tires . . . . . .<SNIP>
Tyre wear timed to perfection.
So, when do the overdrive pulleys arrive?
Old 03-23-2004, 01:56 PM   #60
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Thumbs up tires
These tires are awsome!Wear was great, traction was great, and no chunks or ungluing from the rim. When you get the car set right you dont loose excessive tire due to sliding,.
These tires are a great deal also $11.00 a pair straight to the public
Here is the paint I came up with to run with these wheels, I made my own decals too!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
