Old 03-11-2004, 07:53 AM   #1
Send a message via AIM to Profoxcg
Thumbs up roll centers
hi guys, can someone please explain what the roll centers do and does changing them do to the cars handling?
Profoxcg is offline   Reply With Quote
Old 03-11-2004, 09:48 AM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
in a nut shell lowering the front roll center gives you more on throttle steering, car is less responsive, bewtter on smooth high grip tracks with long fast corners.
Raising the front roll center gives you less on-throttle sterring, car is more responsive ,use on high grip conditions to avoid traction rolling, use on tracks with quick direction changes.
lowering the reqar center gives you more on-throttle grip, less grip under braking,use to avoid traction rilling at corner entry, use under low traction conditions , increases traction and reduces rear tire wear.
raising the rear roll center , use to avoid traction rolling mid-corner and corner exit, reduces rear traction.
(from 710 set-up book)
Old 03-11-2004, 10:29 AM   #3
Unhappy
hi, yeah I read the book and I still didnt get it,
can you give me an example for when I would change my roll center in the front for instance? ->> wouln't changing springs do the same??
I need to go to 1/10 racing school, is there such thing ??
Old 03-11-2004, 10:41 AM   #4
ziggy12345's Avatar
Check the tech help on my website
www.ashby-ic.com
Everything is there you would need to know about setups and engine tuning
Cheers
ziggy12345 is offline   Reply With Quote
Old 03-11-2004, 01:08 PM   #5
thanks ziggiy, ill check it out.
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 01:32 AM
is my roll out right little man Australian Racing 4 12-22-2007 04:43 PM
roll out 3808larry Electric On-Road 2 12-13-2006 05:25 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 05:12 PM
xxxs aluminum low roll centers trinity BillyCaldwell R/C Items: For Sale/Trade 9 12-18-2003 08:26 AM
