Old 04-06-2004, 11:53 AM   #46
Send a message via ICQ to Cartman
where you at the mendip nats on sunday?
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 04-06-2004, 12:42 PM   #47
Diesel Racer's Avatar
No mate not good enough for that.
Diesel Racer is offline   Reply With Quote
Old 04-09-2004, 05:26 AM   #48
does not matter how good you are!!
the UK nationals are open to ANY one!
oh and i qualified 5th and finished 3rd!!
http://www.brcascalerubber.org.uk/
Old 04-18-2004, 08:03 AM   #49
Default Kent IC Club
Were running the 3rd round of the summer series on Sunday 25th April at the Brooklands Circuit, as usual members and non-members are welcome to come along and race.
We're allowing both foam and rubber to race together using touring car shells as the EFRA rules for those that prefer to race foam.
Old 04-18-2004, 08:14 AM   #50
ziggy12345's Avatar
Can you use pesonnal transponders at Brooklands yet?
What about Lola bodies?
ziggy12345 is offline   Reply With Quote
Old 04-18-2004, 10:06 AM   #51
Default Re: Kent IC Club
that may cause problem as foasm and rubber use diff lines and styles!
Old 04-18-2004, 10:34 AM   #52
ziggy12345's Avatar
Its never been a problem at Ashby. Foams and rubber run all the time together.
Old 04-18-2004, 11:17 AM   #53
J3st3r's Avatar
Send a message via ICQ to J3st3r
Default UK Nitro Racers
Does any one know af any club int Blackpool or Preston area.
Any contact information would be gratfully recived.
Thankyou in advance.
J3st3r is offline   Reply With Quote
Old 04-18-2004, 11:39 AM   #54
try looking here www.rcracechat.com
Old 04-18-2004, 12:43 PM   #55
No personnal transponders at the moment ziggy, but I believe they're on the horizon.
When there has been enough guys running foam they have been in a seperate foam class with lola bodies, the meeting before last only one guy turned up with foams and lola body so he ran in the rubber class. No one will be denied a drive if they take the trouble to turn up.
Old 04-18-2004, 12:50 PM   #56
Default Re: Re: Kent IC Club
I only believe the lines will be different if they using lola bodies and front one-ways. Having said that they also run foams and rubber together at LRRC.
Old 04-18-2004, 02:40 PM   #57
ok did not know you did not run lola, as brca is foam/lola
Old 04-19-2004, 01:09 PM   #58
No problems Cartman, I know from the RCChat Forum that a lot of guys stated they would prefer to run foam if they used touring shells instead of lola, I ran foam at the last meeting with a touring shell and solid front axle and definately preferred it myself, thats why at club meetings its quite nice to give the racers a choice, once the numbers increase then we can look to seperate the 2 classes again. Hopefully it might help to increase club membership which is gradually increasing.
Old 05-06-2004, 01:42 PM   #59
Default 4th round summer series
Kent I/C Club is holding the 4th round of the summer series this Sunday 9th May, we will welcome any new members and non-members can race as well, the only requirement is BRCA membership. Racing starts at about 10am with practice from about 8am.
As the title says, the club is for I/C cars only and caters for 1/10th, 1/8th and 1/6th.
Hope to see you there.
Mark
Old 05-06-2004, 01:59 PM   #60
ziggy12345's Avatar
Ashby is also got a summer series round so I'll be attending that. We will get down to your club one day!!
Tucson AZ Nitro Racers C Branch Arizona-New Mexico Racing 3325 05-31-2012 12:49 PM
Help from experience Nitro racers FastHound Nitro On-Road 8 02-22-2005 09:24 AM
nitro pan racers LOOK HERE rcfoolz Oval, Larger Scales and More 0 11-09-2003 01:49 AM
We Cater to Nitro Racers! Jpilone Florida Racing 0 11-18-2002 12:16 PM
Ofna OB4 Nitro Racers! WeatherB Nitro On-Road 49 05-18-2002 03:04 AM
