Old 12-26-2009, 10:00 PM   #16
Toh WL's Avatar
True also but none of our LHS has this unit on sale. Already tried looking around.
Yeah racing regulator is very commonly used nowadays so far so good. Easy to find as it became common item.
Toh WL is offline   Reply With Quote
Old 12-27-2009, 09:15 PM   #17
Wow, thanks. I always through the vz is a digital servo. But I am running another VZ in my 1/8 now with spektrum, 2S lipo and regulator for almost a year now without any issue.....
Originally Posted by asw7576 View Post
Sorry.... maybe your sanwa got burned because sanwa erg-vz is analog servo. When you connect analog servo to spektrum receiver, analog servo's FET will get hot..... so hot until it burned itself. Please check your spektrum receiver manual regarding using analog servos.
Futaba HRS receivers also don't work with analog servos.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 12-28-2009, 01:26 AM   #18
asw7576's Avatar
I don't use spektrum receiver.... I use futaba receiver, so I dont know about spektrum.
If you already use the combo for almost a year without overheating problem, I guess the combo are fine to combine.
Old 12-28-2009, 07:05 AM   #19
RayJ's Avatar
In my book there are several advantages to running a regulator on Lipos or even LIFE batteries.
1) The servo's and receiver sees a regulated voltage. This gives consistant and more predictable throttle and servo response throughout the batteries usage.
2) When fully charged....I have found my Lipo's produce almost 8volts at peak charge. I don't want to risk damaging $100.00 + electronics to save a little space.
3)After using regulated lipo's for over a year, I have found far less problems with burned out or broken servos.
4) I haven't tried the Life batteries yet, but they from what I have read are a more stable power source. However.... they are rated at 6.6volts...but is the peak voltage when fully charged in the mid to high 7's? I still would run a regulator with it.
RayJ is offline   Reply With Quote
Old 12-28-2009, 07:51 AM   #20
Toh WL's Avatar
Btw I also get 6.6V with my NiMH pack at full charge using Voltmeter to test. So far no issues... Since LiFe is still new. I was hoping if someone who tried would share their opinion.
Old 12-28-2009, 10:03 PM   #21
new3's Avatar
i am running life at 6.6 volts in 1/8 and 1/5 th they work great and no reg needed. i know they will fit in serpent , Shepard, montonica i believe a mugan. i use the big one in the 1/5th scale. they are reasonable. and they don't blow up like lipo and they last longer than lipos. for a very good reg at an inexpensive price that i have used for years. common sense r/c has one that you get bang for buck
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 12-28-2009, 10:13 PM   #22
Toh WL's Avatar
Besides that any difference in run time for LiFe comparision with NiMH of same mAH rating. Will I get more with LiFe other than weight.
Old 12-29-2009, 03:08 AM   #23
Any different charger for Lithium Ferrite or is it the same as LiPo's ?
Cobra zz
Cobra zz is offline   Reply With Quote
Old 12-29-2009, 03:20 AM   #24
SteveP's Avatar
Originally Posted by Toh WL View Post
I am using Spekrum SR3500 previously. Although the supported voltage is 3.2 - 9V. I still stick to NiMH at 6V. Reason is when u input 6V to the RX. The output is the same as input. Higher volts will kill the servos. Else you may consider a regular to be safe.. But I seen ppl got both servo's toasted when their regulator mulfunctions..
To date no servo manufacturer produces servo to operate at 7.4V for this case.
Just to add to the point that this isn't correct, all current KO Propo radio gear is compatible with an unregulated Li-Po receiver pack. I've also been running the Orion/Peak servos with an unregulated lipo pack and have not had any issues. Rest assured that most radio manufacturers are already moving in the direction of making their radio gear compatible with the voltage levels common with a LiPo pack.
SteveP is offline   Reply With Quote
Old 12-29-2009, 06:49 AM   #25
Toh WL's Avatar
I do agree the receiver can support more than 7.4V. However I am using Sanwa ERG-VX for 1/8 GP. The documented spec is 6V.. However from what I was told there are servo supporting 7.4V too.
Speed: 0.10sec/60deg
Torque: 13kg.cm (6.0V)
Size: 39.0 x 20.0 x 37.4mm
Weight: 61g
Old 12-29-2009, 09:05 AM   #26
YmeBP's Avatar
Trader Rating: 32 (100%+)
LiFe technically isn't new. The electric airplane guys have been running them for a couple years or more now. I have a couple different manufacturers that I've tested and I resell Hyperion cells under my own brand and directly. There are quite a few nitro guys around I've sold them to and they are very happy with them for the reasons stated above. I use NiMh because it's cheaper.
You will get a weight reduction and a reduction in maintenance. Even with high quality Nimh cells it is recommended to discharge them once a month and store them charged. Honestly even I (I sell these things for a living) don't go through the hassle. I just charge run and put the car away when I'm done.
LiFe offers you that kind of maintenance without degradation to the battery. It will hold a charge for FAR longer than a NiMH will so you can charge put your car away for the winter, then bring your car out in the summer and not have to worry about charging it. You can't do that with NiMH.
Technically yes, I've seen people charge LiFe with LiPO chargers. I wouldn't suggest it though because of the chemistry difference and how each type of battery peaks. There are very low cost chargers available that will do both, and if you can afford to run nitro you can afford a 50$ or 100$ charger . I would suggest being safe.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-29-2009, 03:01 PM   #27
Any suggestion on charger brand and model ?
Cobra zz
Old 12-29-2009, 03:46 PM   #28
YmeBP's Avatar
There are a couple that i normally suggest to nitro guys:
1) Hyperion EOS 0606i AC/DC easy to use, does every chemistry battery and doesn't require an additional power supply, well constructed etc etc etc . You can charge your starter box and everything else with this charger. I own and use the 606's big brother the duo 3.
2) Turnigy Accucell-6 really really cheap, you need an external power supply and you get what you pay for BUT it's cheap!! There are a couple guys at the track that run these things, and they seem to like them. They feel a little light and flimsy but for 40$ you really can't beat them with a stick. Power supply for this charger. You can charge your starter box and everything else with this charger too.
3) Hyperion Duo III if you've got a decent sized budget and you want the best, this is it. It remembers everything, can charge 2 batteries at once, makes coffee and if you push it's buttons just right there is a happy ending . Power supply for this charger.
There are a bunch of other chargers on the market but to keep things simple these are what i'd suggest. I've used all three, and own and use the Duo 3 for my electric and nitro racing.
Be careful with the Duratrax Onyx line, they can only do 3s lipo so you won't be able to charge your starter boxes.
Old 12-29-2009, 04:50 PM   #29
Thanks for the advice.
Best raegards.
Cobra zz
Old 12-29-2009, 10:25 PM   #30
Toh WL's Avatar
I aware the brushless & Lipo are in use by electric airplane or heli long before. On road electrics still using NiMH & stock motor. Until later sometime they tansition to LiPo & brushless technologies.
ACE 1015 on unregulated lipo? WingWrecker Nitro Off-Road 35 09-21-2009 01:40 PM
