Old 05-11-2010, 09:23 PM   #121
Send a message via Skype™ to Calito
Questions?? Rear Bulk Shimo Edition
Hello, I have looked online and I found signs up to follow the theme of Shimo Edition. Question when I went to replace the Rear Bulk saw that there is a difference between the Shimo Edition and above. The current is the KY-VZ209C and the former was B. I've looked and can not find the difference someone has noticed .
Sorry but my English is not the best and prefer to use a translator .
Thank you. Carlos
Calito is offline   Reply With Quote
Old 05-11-2010, 09:45 PM   #122
Thank you. Carlos
It is a change in plastic. I think it a stiffer plastic.
https://www.gofundme.com/ncontrol
Joe Maxey is online now   Reply With Quote
Old 05-11-2010, 11:39 PM   #123
blown sv's Avatar
the bulk head is the same , what the differance is is the shimo camber link has an extra hole in it , where the VZ209B has the original evo2 5 hole setup , either one will do
i have the 5 hole one on at the moment as i have a few setup ready to go for quick changes (have the camber links on and all, makes it a heap easier)
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 05-12-2010, 02:26 AM   #124
rcabj's Avatar
changing camber links position causes what effect?? ..thks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-12-2010, 03:11 AM   #125
blown sv's Avatar
it depends on what you want or what the cars doing, but to make it easy running it say short low will allow the car to roll more on the rear, short high will stiffen the car up and make it sit flatter , but it depends on the track and grip really to how you would run it
Old 05-12-2010, 08:17 PM   #126
If you want more info you can do a search on "roll center" as that is the technical term for is getting changed, e.g. see this link
http://home.scarlet.be/~be067749/58/c2/index.htm
Ace Hobbies | Associated B44.1 | Team Orion
doc101 is offline   Reply With Quote
Old 05-13-2010, 02:20 AM   #127
blown sv's Avatar
havnt i taught you well enough doc?, you resorting to using setup tips off the web!
Old 07-05-2010, 06:28 PM   #128
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default clutch shoe
which clutch shoe are most of you using with this clutch, vzw229-03 or vzw229-04 which one comes with the clutch? and also are the capricorn and exceed shoes compatible with this clutch?
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 07-05-2010, 06:34 PM   #129
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
VZW229-04 is not a clutch shoe. Its the backing plate.
The sirio clutch shoes fit as well. I did run a blue sirio shoe at the nats for a while.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-06-2010, 09:25 PM   #130
Default shoe
thanks Scott pm'd you
Old 07-10-2010, 01:01 PM   #131
I dusted off my old V-One R. This chassis has come a long way!
gotspeed? is offline   Reply With Quote
Old 07-11-2010, 06:33 PM   #132
kyosho_ken's Avatar
Cool v one r
I still have one myself, It can still get the job done.
kyosho_ken is offline   Reply With Quote
Old 07-12-2010, 08:01 PM   #133
Default diff or no diff
I see guys mostley run diffs in the front now... iam going to GLC in Aug would you still run diff in front there or switch to solid front since track is high bite?
younghovaa is offline   Reply With Quote
Old 07-12-2010, 08:18 PM   #134
Default diff or solid
I personally run solid but i will try diff at the worlds and see the difference. you should have both and try them
Old 07-13-2010, 07:59 AM   #135
I preferred the spool at Toledo, it doesn't have the tight high speed chicanes that would make me choose a diff. If I ran a diff, it would have been in the 200k+ range so you should just save the weight and go spool.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
