Old 04-27-2010, 01:55 AM   #106
blown sv's Avatar
yeh forgot that bit
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 04-27-2010, 04:20 AM   #107
ah k, i get it now.
so how does the shimo clutch compare to the sirio or capricorn?
LiL_JaSoN is offline   Reply With Quote
Old 04-28-2010, 12:52 AM   #108
blown sv's Avatar
not much differance really, i use sirio clutches which ive used for a while now, and the shimo feels very similar to sirio, use the shimo if thats what you have.
Old 04-28-2010, 07:16 AM   #109
has anybody seen the velvet shocks (fm529v i believe) for sale anywhere?
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 04-28-2010, 11:05 AM   #110
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Wrong part number... I had the same problem. The manual has a different part number than what is on the header card.
Try W5301V
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-28-2010, 04:04 PM   #111
RC MARKET's Avatar
Yes W5301V
RC MARKET is offline   Reply With Quote
Old 04-28-2010, 05:28 PM   #112
Originally Posted by RC MARKET View Post
Yes W5301V
you need to make your site faster!.. it's too slow and annoys me and i always end up ordering somewhere else cause it takes too long to load up and look for everything.
you have good products, but if it was faster.. id defently order from u.
Old 05-01-2010, 02:42 PM   #113
RC MARKET's Avatar
ok thanks !
Old 05-09-2010, 04:36 AM   #114
what diff oil are you guys running in the front/rear?
im thinking of running 80 or 100k at the front.. no idea at the rear?
Old 05-09-2010, 11:23 AM   #115
Depends on the track. 100k in the front and 30k in the rear is a good starting point.
I can tell you I have 3 rear diffs. 20k,30k, and 50k.
I have two front diffs, but am going to build a third. I will have 50k,80k and 100k. I have run 120k but didn't like that. Too much like a spool at that time I tried it.
Old 05-09-2010, 06:05 PM   #116
i got 2 rear diffs.
a 20k & 30k.
i got 2 front diff cases, so i might build a 50k and 100k.
Old 05-10-2010, 02:45 AM   #117
blown sv's Avatar
i found the same, on a medium /high grip i run a 100k front and 30k rear , and a bit lighter front will give you a little more turn in, a friend that i know through racing went overseas and spoke to shimo himself and apparently he likes to run a 30k split, hence the 20-50 kit oils.
i also have 20,30, 50 rears and 50,80,100 front really all you need.
chad
Old 05-10-2010, 05:57 AM   #118
might try running 50 in the front first as i already have 30k in the rear,
the track im running on is small and tight with alot of hairpins. never hit 2nd gear besides the straight.
one way - found the car was way too loose.. slid out every corner
spool - traction is alot better but have to slow right down into the hairpins..
Old 05-11-2010, 02:00 AM   #119
blown sv's Avatar
hows the traction , i mean the track surface?, probably 30k will be to heavy, run 20k rear and 50 front to start, its not to bad on a number of track styles.
and start off with kit setup .
Old 05-11-2010, 03:06 AM   #120
sorry, already have 20k in the rear i mean.
traction is low/med id say.
