Old 03-15-2010, 02:10 PM   #46
92GTA's Avatar
Originally Posted by Scott Fisher View Post
I assume you are talking about the set screw that goes into the aluminum brake pulley. The manual shows it to be a 4x4.
Perfect! I'll get it ordered right now!
http://www.TheFOAT.com/92GTA
Kyosho V-One RRR "Shimo Edition"/Pagani Zonda Body
O.S. .18 TZ(P) Turbo w/11K Slide Carb/O.S. T-1040 Pipe
Futaba BLS451 Digital Brushless High Torque/Speed Servos
Futaba 3PM-X 3-Channel 2.4Ghz FASST Radio System w/R603FF Receiver
92GTA is offline   Reply With Quote
Old 03-16-2010, 01:42 AM   #47
RC MARKET's Avatar
http://rcmarket.com.hk/product_info....oducts_id=7912
RC MARKET is offline   Reply With Quote
Old 03-16-2010, 04:02 AM   #48
rawi's Avatar
Default EVO2 WC Vs Shimo Edition
What are the different between this two model?
JBRCC
rawi is offline   Reply With Quote
Old 03-16-2010, 12:04 PM   #49
RC MARKET's Avatar
LF Shock , 3D Smaller Clutch , Pinion gear , Brake disk , Rear upright ...
Old 03-19-2010, 01:56 PM   #50
kyosho_ken's Avatar
Lightbulb bearings/ final drive gear ratios
I have the shimo and in my first "real" race with the car, I had two front outer hub bearings that partially seized up and the other metal shield came out. And broke one of the rear adjustable blades, not bad. Considering I was rear ended in the straight during practice at 45 mph or better by an eight scale twice. I ordered new ceramics from acer. I'll see what they do.
I am still trying to find out the Final drive ratios for the shimo. Does anyone have a clue what formula or numbers to start with or where to get them? I want to get the best results out of my foams between qaulifiers and mains. I recently used an equal 58mm front and rear with the 26t middle pulley gear. I was told to run 2mm higher in the rear than the front. I was getting 4 min run times from my max power .12 rr3. I am trying to figure is it my motor or my stock setup. I am using the stock clutch gears of 17 and I think 23 on a mid- sized semi technical track. I want to get the nova 353 racer .12 after I get a handle on this new car.
kyosho_ken is offline   Reply With Quote
Old 03-20-2010, 07:03 AM   #51
Dru Garcia's Avatar
Send a message via Yahoo to Dru Garcia
It was your motor.
I heard it at the start of your qualifier, but didn't get the chance to make any adjustments.
Ceramics are a great investment.
At the Fort I run 17/22 and 55/59 with 58 front and 60 rears.
This is what my RR3 likes, so it may work for you as well.
See you next time.
Desoto Racing
www.skyrocketbatteries.com
Dru Garcia is offline   Reply With Quote
Old 03-20-2010, 07:07 PM   #52
kyosho_ken's Avatar
Cool It will come back, hopefully
Originally Posted by Dru Garcia View Post
It was your motor.
See you next time.
My wife and I am going to try and hit Homestead up next. I learned a little about this car and what I need to have a better strategy. peace.
Old 03-20-2010, 08:06 PM   #53
Dru Garcia's Avatar
I've been to this track a few times, but it's a new track with a 300' straightaway and since the driver's stand has been moved, it has changed everything. We will be driving in the same track the world 1/8 scale will be running in 2011. It's going to be a blast!
We will be there starting Friday, just to make sure all the minor stuff is worked out before qualifiers.
Hope you make it down.
Desoto Racing
Old 03-21-2010, 09:47 PM   #54
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Had a good test of the car for the first time this weekend at the RCX challenge. My car was absolutely great. Most competitive I have ever been. There was still a something to improve as I could lose the rear of the car on corner exit if I didn't roll the throttle, but even with that small issue, the car was simply awesome.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-22-2010, 09:14 AM   #55
rmdhawaii's Avatar
That's great!
Are you running it stock out-of-the-box or have you got any upgrades? How about springs, shock oil and diff oil? What body?
Thanks in advance!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-22-2010, 09:19 AM   #56
OLDSKL's Avatar
Thats a damn good looking car!
OLDSKL is offline   Reply With Quote
Old 03-22-2010, 09:45 AM   #57
YBSLOW's Avatar
Originally Posted by rmdhawaii View Post
That's great!
Thanks in advance!
I pitted for him over the weekend and can say he was using almost the kit setup from what he told me as far as springs and oil go.
He uses all of the YBSLow liteweight drivetrain parts like titanium 2spd and midshafts.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 03-22-2010, 10:12 AM   #58
That's great!
Thanks in advance!
Brad is pretty much correct.
I am running the stock shocks, springs and pistons but ran 500wt oil. Kit diff oils (50k/front 20k/rear)
Other hopups include: Yblslow drivetrain parts (titanium). I use titanium ball studs and ball ends.
I use the Kyosho APP brake pads as well as the Kyosho titanium pillow balls and Kyosho titanium screws on the top half of the car. I used the older rear shock tower. All my diffs use Kyosho titanium bevel shafts. I also used the new Shimo clutch and adjusted it to my liking. (had to run the spring looser than the kit suggestion)
For the body, I run only Protoform bodies. I ran both the R5N as well as the Stratus. I did set TQ with the R5N in round 1. I ran the Stratus in rd2 and 3 and decided to use the stratus in the main event. My car was the car great in the main but I was stupid and left a wheel nut loose and lost a rear tire 8 mins in while leading. Lost 5 laps because of that and ended up about 1 3/4 laps down in second place at the final tone.
Old 03-22-2010, 12:07 PM   #59
rmdhawaii's Avatar
Thanks for the info guys.
Too bad about the wheel nut Scott. Were you using the Kyosho nuts or the serrated Mugen nuts?
Old 03-22-2010, 11:04 PM   #60
I use the Kyosho serrated wheel nuts (part number 1175)
