Old 08-29-2010, 04:03 PM   #181
Originally Posted by MikaR View Post
Interesting.. thanks
After this result (no WC) or just in general.. Do you guys expect a new car coming out in 2011 or just some new parts like the ones that we saw being used in the WC by Adrien and Shimo ?
they are weird about releasing expensive parts individually, like chassis and top decks. i could see that being an entire kit for the top deck but i could see it as an option too.. or not at all. the basic evo2 wasn't an upgrade really, the evo2 wc was good because of the cvds and other evo wc type upgrades, shimo was some more new stuff..
I think Swauger said it best at the event, most of the manufacturers are going to offroad because the money is there. Serpent, the most onroad company of all time has an offroad car and electric stuff. Mugen pushed the mtx5 back despite the worlds to release the mrx5 for next years event.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-30-2010, 03:07 AM   #182
MikaR's Avatar
Right, thanks
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 08-30-2010, 03:50 AM   #183
Originally Posted by Brian Bosley View Post
yet another example of the fact that kyosho has made most of the parts you will ever need for the future, it is just up to you to go back to the 90's to find them.
yes, even the diffs are the SAME.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-30-2010, 07:50 AM   #184
in kyoshos defence, i will admit that the front diff has two different casings. i think one is slightly wider from 10+ years ago :P
Old 08-30-2010, 07:57 AM   #185
gears are the same.
im rebuilding a vones
anyway i got a nice carbon camber plate made up. gotta dremel the plastic ear away now.
can also see the xray diff :P
Old 08-30-2010, 08:50 AM   #186
tried it, i still have a few. it's ok, not better than the plastic to me. the shim on the hub is just as effective
Old 08-30-2010, 07:26 PM   #187
someone pm'ed me and said
I cut mine last weekend and it was what I was looking for.
Lots of steering. I did notice the rearend was very loose after the modification. I laid the rear shock in 2 holes and it was money.
It did wear rear tires more though.
Old 08-30-2010, 08:48 PM   #188
Default Shimo
Hey guys thinking bout my sedan for next yr.. Wanted to ask how do you like the car?? Does it hav enough steering out the box is there anything else you need with the car? Will you get another one next yr
younghovaa is offline   Reply With Quote
Old 08-30-2010, 08:57 PM   #189
kai888's Avatar
Trader Rating: 17 (100%+)
oops got confused
kai888 is offline   Reply With Quote
Old 08-30-2010, 10:33 PM   #190
RRR Shimo Edition
Pretty much a hopped up evo 2.
pretty much the car is ready to go out of the box and no mods are needed.. all the mods are already done in the shimo edition.
just comes down to the set up of the car.
Old 08-30-2010, 11:54 PM   #191
MikaR's Avatar
thanks for posting. will think of doing this, too
Old 08-31-2010, 01:46 AM   #192
im thinking of trying it to.. but how much difference can it make as the bulkhead is already pretty regid being held on by the shock tower etc?
never the less, increasing flex seems to be the easy way out, cant you adjust the shocks, dampening, etc to get the same effect?
im thinking of cutting mine and instead of running the top peice, run a rod/turnbuckle (kind of like a strut brace).
Old 08-31-2010, 07:37 AM   #193
a lot, i often run without front screws for more flex (just the ackerman bolted down)
Old 09-01-2010, 02:48 PM   #194
afm
afm's Avatar
Default NT1 Diffs on 3R
Can you fit NT1 diffs as a direct bolt on on the RRR???, Im aware that the front pulleys are the same but not the rear ones, right??, but what about bearing size and widht?, do I need to change CVDs or dogbones??. If they do fit, can I use two front ones, and adapt a 42T pulley to thr rear one??
The best option would be to fit the front NT1 and the rear from Serpent 733 which has ame pulley size, but not sure if it will fit the RRR because it seems to be to narrow..
AFM
afm is offline   Reply With Quote
Old 09-01-2010, 02:56 PM   #195
lil-bump's Avatar
Trader Rating: 83 (100%+)
AFM
LIL Jason I believe has already done this. He's got a 3R with Nt1 diffs front and rear with Serpent shocks and a Capricorn clutch
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
