Old 08-14-2010, 06:08 PM   #166
hmmm what else can i do my rrr..
lower top deck?
cut through the chassis and dump the fuel tank (the bulb) on its ass and run a really flat lipo?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-14-2010, 06:09 PM   #167
Originally Posted by kyosho_ken View Post
Is there a shock rebuild kit for shimo's coated shocks. The part # in the exploded view shows part 126 x2 shock cap-mount to be W5106 which I ordered. they were actually for the old style rrr shock bodies/caps.in the manual is shows the W5106 to be the exploded parts #118 x2 they fit my rrr's evo fine, but wont snug up when I put the collar on. I tried the old blue collars on my new shocks, and still, they don't match up. Any Clues. I don't think they listed parts for the new shocks. thanks..
i totally missed this post. i didnt know the shimo shocks were so different.
i thought they were the same just valvet coated and has a screw on bottom cap instead of being held on by a e-ring.
Old 08-25-2010, 03:51 AM   #168
Originally Posted by Brian Bosley View Post
only the car with the white wheels is new, the other car even has our bumper (which I have yet to figure out why they molded a new bumper with that raised section unless maybe it funnels air from below? or is it a fw06 thing maybe?) one of those pictures clearly shows him using a regulator so you can assume lipo for weight and the receiver on the pipe side with the antenna.
i found one of those spare bumpers laying around from a Vone S
gunna put it on
Old 08-25-2010, 07:32 AM   #169
gunna put it on
yet another example of the fact that kyosho has made most of the parts you will ever need for the future, it is just up to you to go back to the 90's to find them.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-25-2010, 07:54 AM   #170
kest's Avatar
Trader Rating: 1 (67%+)
+1
K..Y..O..S..H..O..I..S..H..O..B..B..Y
JBRCC
BCRT
kest is offline   Reply With Quote
Old 08-26-2010, 02:55 AM   #171
blown sv's Avatar
Originally Posted by nitro ho View Post
Hi guys, quick question for anyone who knows.
What`s the difference between the regular rear hubs and the sr rear hubs?
Thanks guys
not sure if anyone has answered this for you, the SR hubs are 2mm offset , the work really well with the shimo adjustable wheel hexes
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 08-26-2010, 05:20 AM   #172
has anyone thought about cutting there topplate in 2?
im tempted to do it.
Old 08-26-2010, 07:21 AM   #173
if you need more steering try it, shepherd v10 is one of the more recent cars to come with a top deck similar in design out of the box
Old 08-26-2010, 08:03 AM   #174
if i had a spare i would. once its cut there is no going back.
Old 08-26-2010, 12:29 PM   #175
you can try taking out the screws, especially the back ones in the front bulkhead. its a step in the right direction and works for me on some tracks, sometimes you can just loosen them as well to create flex.
the bulkhead is basically sturdy enough by the shape of the front diff and front shock tower.
Old 08-26-2010, 07:01 PM   #176
blah, gunna try cut it.
anything to help increase traction.
Old 08-28-2010, 10:19 AM   #177
Acting Bad's Avatar
Default Shimo setup
Has anyone seen or know what setup Shimo was running at the 200mm worlds in Houston/Porter TX? If anyone can get that information and post it I would be very appreciative.
Acting Bad is offline   Reply With Quote
Old 08-28-2010, 06:20 PM   #178
the story was 600wt stock pistons, medium blues. high front RC, layed down shocks, 2nd to lowest rear rc, 2mm shim on the sr hubs, usual long low camber link.
there are too many things about that car to really know the setup though, you have to have that top deck on top of anything else that was shimmed in some way that we don't know. he didn't speak enough english (maybe he was just busy) to really get solid details. just basic stuff that you already know.
Old 08-29-2010, 12:27 PM   #179
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I was also told by Adrien that Shimo's setup was very hard to drive.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-29-2010, 01:35 PM   #180
MikaR's Avatar
Interesting.. thanks
After this result (no WC) or just in general.. Do you guys expect a new car coming out in 2011 or just some new parts like the ones that we saw being used in the WC by Adrien and Shimo ?
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
