Loose Exhaust Header... Recurring
Just a quick question, I have a Kyosho V-one S, standard GS-15R and exhaust/header. I am having problems with the exhaust header. It keeps coming loose, I have cleaned all grease/fuel, etc. that gets to it when it is loose, applied loctite after loctite and it still manages to make its way loose after every time i take it out!!
I'm thinking that it could be my gasket, but if you have any other ideas it would be greatly appreciated ... i got the need 4 speed !!
Um, is it stripped? That's about the best I can do as far as figuring what the problem is.
But to fix it, you could get longer manifold screws and put a jam nut on the opposite side of the manifold and it will be secured from both sides.
That'll cost you like $6-7 at your Local hobby shop.
Re: Loose Exhaust Header... Recurring
uB3r_V-one-S;
Exhaust leaks in R/C cars are usually caused from something moving too much. Usually loose bolts/weak springs or poor quality gaskets are the culprits.
With side Exhausts, a warped Manifold will eat gaskets. Make sure the flange side is flat and true.
Buy some quality gaskets, tighten evenly and use a drop of threadlock on the threads. A thin coating of RTV on the gasket may help also.
Thanks...
Allright guys thanks a heap, when i get the chance to actally get around and fix the problem i will post up a reply to let you's now how it went, or what the problem was exactly.
Cheers
DB
Cheers
DB
