Old 11-28-2009, 05:17 AM   #1
azcau's Avatar
Default Corner Weights for 1/8th Scale
Can anyone tell me how the corner weights should be divided up. I measured mine today and got the following:
LR: 736gm LF: 531gm
RR: 635gm RF: 592gm
Seems a bit odd to have a 100gm (about 15%) difference between the rears doesn't it?
Mugen MRX5/Novarossi/GRP/Spektrum/RB Fuel
www.MRCCR.com
azcau is offline   Reply With Quote
Old 11-28-2009, 06:04 AM   #2
azcau's Avatar
Shoulda mentioned it's an MRX4R
www.MRCCR.com
Old 11-28-2009, 08:24 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-28-2009, 11:43 AM   #4
wingracer's Avatar
Trader Rating: 24 (100%+)
You have some crossweight in it (tweak), adjust your collars a bit to even it out.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-28-2009, 12:08 PM   #5
DS Motorsport's Avatar
From my own experiences i learned that measuring corneringweights for an rc car doesn't work.
Every time i lift the car and place it back i get different readings from the scales. It's almost impossible to balance the car. And when you have the car close to a good balance and then check it with the normal tweak method or tweak board, it;s not even close to a balance.
And before you start tweaking a car by using scales you have to balance the chassis on a set of pins, and make sure you are using matched springs.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-28-2009, 12:26 PM   #6
Send a message via Yahoo to sheeley
I would disconnect my sway bars first, then tweak with shock collars, then tweak with sway bars on(one at a time). On my tweak board I can remove the rear shocks and set the chassis flat on the board while I first tweak the front of the car to make sure the chassis will be level. You can have the car balanced with the chassis at a angle.
This is just how I tweak my car.
sheeley is offline   Reply With Quote
Old 11-28-2009, 12:53 PM   #7
wingracer's Avatar
It works perfectly, just takes some care and proper methods. See the post between for some details.
Team Shepherd USA
Old 11-28-2009, 03:02 PM   #8
I know the proper methods, setting up racing cars is my job.
The problem is that i don't get results which i trust. If i put the car on the scales ten times in a row, 5 times i will get 30 gr on the LF and 5 times 50 gr on the RF. If i got an imbalance on the same side during every measurement but only the amount would fluctuate i would just take the average of the measurements but this isn't the case.
The only thing that i could think of is that my problem lies in the scales, i bought some cheap 9 dollar scales.
P1-RC.com
Old 11-28-2009, 03:48 PM   #9
wingracer's Avatar
That's probably it. I get some fluctuations but usually not more than just a few grams.
I too prefer the more traditional methods of tweak set-up for the most part but I really like to use scales for the initial set-up of a new car or after a major rebuild. There are some things it will tell you that nothing else will.
Team Shepherd USA
