Old 02-24-2004, 11:51 AM   #1
IDrinkNitro's Avatar
Default Is ABS radio feature helpful with front one way
Would like to hear all opinions on this please. I am getting ready to buy new radio system, should I make sure to get one with ABS? Thanks in advance
IDrinkNitro is offline   Reply With Quote
Old 02-24-2004, 11:54 AM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Is ABS radio feature helpful with front one way
i thought you ask this question already in this other forum
http://www.rctech.net/forum/showthre...threadid=33868
Old 02-24-2004, 12:10 PM   #3
yes I did and I received one answer, yours No offense I would like to get some other opinions on it as well
Old 02-24-2004, 12:22 PM   #4
Super Moderator
Marcos.J's Avatar
no problem i just wasnt sure i didnt want to repeat the answer, by the way the abs helps a great deal with the one way ,i always use it. good luck
Old 02-24-2004, 12:29 PM   #5
Francis M.'s Avatar
You could get the same effect by adjusting your endpoint so
the brakes won't lock up and this method should use less of
your batt than activating the abs on the radio.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-24-2004, 12:33 PM   #6
Thanks for your input, I appreciate it
Old 02-24-2004, 02:08 PM   #7
Francis is right. The ABS is hard on the battery and the servo. You're much better off just adjusting the endpoints.
tekrsq is offline   Reply With Quote
Old 02-24-2004, 02:15 PM   #8
Francis M.'s Avatar
marcos is full throttle your local track if so your a lucky guy
from the pics i saw it is very nice.
Old 02-24-2004, 06:35 PM   #9
I've been wondering about the RX pack runtime thing myself as I was wanting to try my JR R-1's ABS features on my sedan with a oneway....with an 1100 mAh RX pack and the current drain of the average servo & reciever setup you should have plenty of runtime. Calculate a middle of the road average and at best your draining 800-900 mAh out of your RX pack at any given time....this should mean that you have about 70-75 minutes worth of juice which should be plenty for most races.
SteveG is offline   Reply With Quote
Old 02-24-2004, 10:38 PM   #10
Super Moderator
Marcos.J's Avatar
yes it is my local track and i also helped build it , and paint.
Old 02-24-2004, 10:40 PM   #11
Super Moderator
Marcos.J's Avatar
I have the R-1 and i have a 700mah battery on my serpent 710 and i can get 3 qualifiers and a 20 minute main using the abs without recharging.
Old 02-24-2004, 11:19 PM   #12
InitialD's Avatar
What servos are you running? Digital or analog?
Old 02-25-2004, 07:40 AM   #13
Super Moderator
Marcos.J's Avatar
hi-tec, analog
Old 02-25-2004, 07:48 AM   #14
InitialD's Avatar
hi-tec, analog
That would explain the good receiver pack runtime.
Old 02-25-2004, 10:31 AM   #15
ziggy12345's Avatar
For front one way adjust your system so that when the throttle is released the brake is just off. Then use the brake trim while racing to apply drag brake (slight brake with throttle at neutral)
The amount of drag brake can be adjusted while driving with the brake trim.
I find that it allows the car to dive into the corners and take a tighter initial line
Cheers
ziggy12345 is offline   Reply With Quote
XB-8TQ front shock bodies, radio box,... K.Copeland R/C Items: Wanted to Buy 0 08-30-2007 02:07 AM
Avatar help please - other thread not helpful LadiesFirst R/C Tech Site Forum 3 06-25-2006 06:50 PM
A helpful link.. Crashhole Buyer/Seller dispute and Feedback discussion forum 0 01-23-2006 11:15 PM
IT Very helpful and cool person AAA+++++ k.O. Buyer/Seller dispute and Feedback discussion forum 0 03-30-2003 09:52 PM
Looking for helpful people/place to help solve my V1S problems Entropy Singapore R/C Racers 5 02-18-2003 02:45 AM
