hobao hyper gpx4 breaking in prob
iv just purchased a hyper gpx4 and got it started for the first time but when i hit the throttle the wheels wont move. The belts look to be on fine everything looks fine but cant figure out wat the problem is.
is yr engine enaging the clutch?
rtr hyper gpx4
if the clutch is not enganging how do i fix it
when u throttle, do you see your engine clutch bell spinning?
remove engine and make sure u could spin the clutch bell without any binding.
next check your clutch settings, either yr spring too hard or preload too much or clutch gap too large...
