Old 11-06-2009, 03:22 AM   #1
Default hobao hyper gpx4 breaking in prob
iv just purchased a hyper gpx4 and got it started for the first time but when i hit the throttle the wheels wont move. The belts look to be on fine everything looks fine but cant figure out wat the problem is.
gandgedwards is offline   Reply With Quote
Old 11-06-2009, 06:21 AM   #2
NitroWD's Avatar
is yr engine enaging the clutch?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 11-06-2009, 10:43 AM   #3
Was this a Kit (you build it) or a RTR (Manufacture pre-built)?
at any rate check clutch system. Make sure all screws are secure, but not binding and that clutch spring is not broken/damaged
Kyo83 is offline   Reply With Quote
Old 11-06-2009, 12:52 PM   #4
rtr hyper gpx4
Old 11-06-2009, 01:09 PM   #5
if the clutch is not enganging how do i fix it
Old 11-07-2009, 09:34 PM   #6
keavze's Avatar
when u throttle, do you see your engine clutch bell spinning?
remove engine and make sure u could spin the clutch bell without any binding.
next check your clutch settings, either yr spring too hard or preload too much or clutch gap too large...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
