Old 11-03-2009, 02:35 AM   #1
Mind_Reader7's Avatar
Default Servo's aren't responding?
Hi guys, I got my first nitro buggy, and I've searched up on them a fair bit. However, the steering/throttle seem to work, however upon starting the engine, they do absolutely nothing, and won't do anything even once I turn the engine off. After leaving the car, and the control turned off for about 10 mins, they work again until I start the car again. I checked to see if everything is plugged in right, all the batteries are brand new.
All it really says on it is AM T-07 27-125mhz.
What could the problem be? I'm assuming faulty parts.
Mind_Reader7 is offline   Reply With Quote
Old 11-03-2009, 02:41 AM   #2
Pattojnr's Avatar
Trader Rating: 19 (100%+)
are the batteries rechargable ?
and is the kit an RTR ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-03-2009, 02:46 AM   #3
What is RTR?
And they're not rechargeable, but they're brand new Energizers.
Old 11-03-2009, 02:50 AM   #4
Jonnokurt's Avatar
Lol alex you noob.
Rtr = ready too run!
are the batteries in your transmitter case charged and is the red plug plugged into the B port on the transmitter?
Jonnokurt is offline   Reply With Quote
Old 11-03-2009, 02:52 AM   #5
No freakin way man, awesome.
The batteries are fine. I'll take a look, and see if it's plugged right, gimme 2 mins.
Old 11-03-2009, 03:00 AM   #6
Jonnokurt's Avatar
Lol man I just fried the bearings in my clutch I was so lookin fowards too racin now I gotta order parts wich will most likely take 2 weeks!
Old 11-03-2009, 03:09 AM   #7
Soz to hear that. I just unplugged/replugged it all, same prob. Should I contact the seller, and ask for a new servo kit?
Old 11-03-2009, 03:18 AM   #8
Pattojnr's Avatar
try each servo one at a time.
and on different channels. try to isolate which channel, or if it is a reciever problem, or servo problem
Serpent - Walter RC
Old 11-03-2009, 03:27 AM   #9
Jonnokurt's Avatar
Yeah what he said, they're prob cheap shit servos aswell man. I had simmilar problems. I had a bit of moisture in em and they sizzled.
Old 11-03-2009, 03:44 AM   #10
What's the thing that the servo's/battery box connect to? I think it's fucked. I had moderate success on each channel, sometimes it would work, sometimes it wouldn't, put them both together, it now works sometimes, but not other times. I'll try and contact the seller tomorrow, and ask him for a partial refund, or a new r/c kit.
Old 11-03-2009, 04:15 AM   #11
Pattojnr's Avatar
that would be the reciever. remove the crystall from it and refit it, it may not be seated properly. this comunicates with the transmitter.
Serpent - Walter RC
Old 11-03-2009, 04:32 AM   #12
Hey guys, it seems to be working. I didn't do the crystal thing, however I will try it tomorrow. I managed to run it for half an hour, starting and stopping it, and it seems fine. However I'm still going to just test it a bit around the house before I take it out.
Old 11-03-2009, 04:55 AM   #13
Pattojnr's Avatar
ur driving the car in teh house ?
maybe just , you arent married ?
Serpent - Walter RC
Old 11-03-2009, 08:14 AM   #14
Lol, Driving it in the house would be awesome as. I meant outside the house lol. I guess I'll perform the break in around the house (get around 5 tanks through) before I take it out, to make sure the servo's ain't gunna cut out. This engine probably isn't going to last as long as it should, seeing as having the servo's act up made it EXTREMELY hot (I couldn't throttle it down). However, I love learning, so I'll be doing mods here and there, make it look sexy.
What are some sites I should buy equipment off? In the coming weeks I hope to have replaced the R/C kit, and the shell (the body is fluro green).
Old 11-03-2009, 06:32 PM   #15
garen's Avatar
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
