Old 10-28-2009, 09:09 PM   #1
Questions?? my V1 RRR evo WC only locks rear wheels when breaking, is that normal.
Hi,
After essembling the kit, i was tesing the brakes and only the rear locks. the front wheels roll forward freely. Is this normal?? If not what do you think I have done wrong??
nara is offline   Reply With Quote
Old 10-28-2009, 09:33 PM   #2
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
are you using a oneway up front? if so then its normal
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 10-29-2009, 06:55 AM   #3
I think so. but wouldnt it make it much harder to drive. specially when bracking. how can I change this to normal.
Old 10-29-2009, 08:05 AM   #4
JLock's Avatar
You would have to replace the one-way in the front to either a solid spool diff or a gear diff in order to get the braking action that you desire.
JLock is offline   Reply With Quote
Old 10-29-2009, 08:17 AM   #5
a oneway can be normal, adjust your brakes and your corner entry points if your track has enough traction a oneway can be very easy and fast to drive but don't let the rears lock. the straight you will need some braking unless you have a sharp 180 then more and then less for the infield so you will have to feel the brakes from the radio because the car isn't carrying as much speed.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
