European 2wd 1/8th pan car on-road Classic class >
Like Tree28Likes
Old 06-25-2019, 09:52 AM
  #4276
Trader Rating: 17 (100%+)
Originally Posted by Farmer_John View Post
Yes, nitro pancar will be offered as a provisional class. Iíd love to see a good show put on by the class.
Wouldnt it be fitting to to be able to have a national champion once more in the founding class of our sport.
Both Contact and Matrix do 50s. I heard an unsubstantiated rumor at last years GLC that hot race does also.
If if you canít hunt some down, it simply means somebody in the Midwest is hoarding them all 😱
I can understand that it is hard to keep stocking the 45/50s front tires as these are only good for 2WD pan....I have been using the open on road set up F32 R37 for the 2WD and adjust my driving style and use up all my tires inventory but this setup is just not as good as the 45F 35R setup that I think is the fastest.............also, just it is not happening in US, I can't seems to find any dealer stock any of those tires. I have to look over Europe to place order.
Solara is offline
Old 06-25-2019, 10:11 AM
  #4277
jetnjme's Avatar
found these at wallace...
p-one
Farmer_John likes this.
jetnjme is offline
Old 06-25-2019, 10:14 AM
  #4278
jetnjme's Avatar
amain has some....
they have 45 and 50/s
contact 45
jetnjme is offline
Old 06-25-2019, 02:34 PM
  #4279
Those are their last pair.................
Solara is offline
Old 06-27-2019, 10:03 AM
  #4280
John....do you know ROAR has any "Spec" about this 2WD pan car class..? Like fuel to run or engine to use...? Since this is a PROVISIONAL CLASS, I am hoping they are simply using the MWS rule and not really forcing to use the 1/8th OPEN rule onto the 2WD....just wondering.
Solara is offline
Old 06-30-2019, 12:38 PM
  #4281
Farmer_John's Avatar
p-one
Makes sense. Wallace carries WRC, who offer a pancar.
Farmer_John is offline
Old 07-03-2019, 03:46 PM
  #4282
Even though there hasn't been a "national" 2wd champion crowned in a while, ROAR still includes it in their handbook under specifications beginning on page 71. They're actually more lenient than what we run (such as a maximum carb bore of 9mm. Local and MWS rules state a 6mm restrictor on 5-7-9 port engines), but most of the specs are already being followed.
Here's a link to the rule book. http://www.roarracing.com/downloads/..._Rule_Book.pdf
jetnjme likes this.
Old 07-08-2019, 09:49 AM
  #4283
Awesome thank you
Solara is offline
Old 07-31-2019, 07:52 AM
  #4284
Do you guys use some kind of tyre additive on your cars?
I'm a little curious about it but i don't know what kind of product i have to choose...
Agro_pelo is offline
Old 07-31-2019, 02:29 PM
  #4285
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
I use Zac traction Compound depending on tire condition. I also like to get the tire warm with a hairdryer as i treat them. This is similar to the Capricorn tire applicator.
1/8 IC Fan is offline
Old 08-01-2019, 12:51 AM
  #4286
thank you for the answer.
I have to treat the front tires too?
Old 08-01-2019, 04:12 AM
  #4287
1/8 IC Fan's Avatar
Depends on if you are pushing a lot. You can also play with either only coating the inside or outside section. To play with grip levels. Keep in mind rim material also affects tire feel, i.e. carbon wheels are harderwhile typical "Opaque" white wheels are softer.
Old 08-01-2019, 05:05 AM
  #4288
Ok i get it. I'll buy a tire additive and make some tests.
I'll leave a video where you can see my Mantua model intrepid running with other cars
Old 08-12-2019, 07:02 PM
  #4289
Default Mantua
If you come the Nationals in Toledo, there will be at least 2 of us running Mantua cars. That in itself could be fun!
Das 1/8th Mopar is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
