Old 06-07-2005, 05:21 PM   #46
factory racer's Avatar
what fuel would you guys get first between O'Donnel, Sidewinder, or Blue Thunder Race Forumula??????? and why would you put them in that order?
and what types of problems are you talking about with the Rossi engines have problems with OD fuel...i no many people running OD in there Rossi's and dont have anything bad to say about them......
thanks
Mike
factory racer is offline   Reply With Quote
Old 06-08-2005, 06:06 AM   #47
Registered User
Run the O'Donnel, its a little more expensive but it is definately worth the extra money. There is nothing wrong with Sidewinder or Blue Thunder, however, it comes down to personal preference. When I ran the O'Donnel I noticed more power on a big track, and the engine's piston and sleeve are still spotless after over a gallon of fuel.
Just my $0.02
2quick4you is offline   Reply With Quote
Old 06-08-2005, 06:17 AM   #48
mtx3novapro's Avatar
What would be the best fuel to run in a Novarossi NS15S5 for a big track and is there any better 15's then the NS15S5 it's for my MTX-3
mtx3novapro is offline   Reply With Quote
Old 06-08-2005, 06:42 AM   #49
Davidka's Avatar
Trader Rating: 77 (100%+)
I've had great luck with the Byron's ($22.99 for 1 gal. of 30%). I left my buggy engine all winter with just a few drops of after run in the cylinder and the internals were spottless this spring. The areas of an engines internals that you should be liikong at are the bearings. If you leave unburnt fuel in the crank case of any engine, no matter what kind of fuel, rust will start forming on the bearings.
Old 06-08-2005, 07:08 AM   #50
would my motor take 30% nitro with out hurting it im only racing it on 20% and im in the top ten in sydney
Old 06-08-2005, 07:09 AM   #51
it would get to hot on 30% wont it
Old 06-08-2005, 09:45 AM   #52
why would u recommend me gettin OD instead of Sidewinder or Blue Thunder??????
Old 06-10-2005, 11:27 AM   #53
duneland's Avatar
Originally Posted by Artificial-I
Interesting never heard od has problem with rossi motors. Maybe thats why I had some trouble with mine.
I think im going to buy some maxy tommorrow. Im going to be taking the car out to a track here in florida as well. Should be fun.
Had a black magic that would get to 265 deg without clearing out on O'donnel. Made great power well below 200 on Race BT (same day). Rossi engine has VERY close tollerances, might be a factor. I sold lots of Rossis too, all drivers using O'donnel had troubles...
duneland is offline   Reply With Quote
Old 06-10-2005, 02:13 PM   #54
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Wow so the race BT was running a lot better below 200 and @ 260 with the OD it still wouldnt tune out?
I was having this sort of issue. Real bad idle , always flaming out. Couldnt get a good rip until the car was basically on its way to overheating.
Artificial-I is offline   Reply With Quote
Old 06-13-2005, 09:49 AM   #55
duneland's Avatar
That's right! I have never seen such a difference in tune (one fuel vs. another). Most engines won't show such a big difference.
Old 06-14-2005, 04:32 AM   #56
asw7576's Avatar
Originally Posted by evlhdlts
theoritically yes. you know how experienced racers clean the little burrs and polish their motors to get the maximum horsepower. well, with all the gunk in there, it should limit the power of the motor. the color becomes a build-up over time from my experience. but with the odonnel you don't get any build-ups. it just makes motor maintenance easier.
Yup, O'donnel.
Old 06-14-2005, 04:38 AM   #57
asw7576's Avatar
MAX P7 .15 7 ports
RB .15 Evolution
O'donnel 25%, Tornado 25%, doesn't matter.
Old 06-14-2005, 03:05 PM   #58
so you guys are saying that OD is worth the couple extra bucks...........???????????
Old 06-14-2005, 03:08 PM   #59
Derby Bros Racing's Avatar
yes it is.
Derby Bros Racing is offline   Reply With Quote
Old 06-14-2005, 03:09 PM   #60
ok thanks a lot guys
***Byron Fuel*** GRide Nitro Off-Road 28 07-24-2008 10:54 AM
***Byron Fuel*** GRide Nitro On-Road 4 07-23-2008 09:12 AM
O'Donnell vs Byron vs Sportswerks straightaway Nitro On-Road 20 01-12-2007 11:57 PM
Byron Fuel kissmypaint Electric Off-Road 5 01-17-2004 06:07 PM
