Old 06-06-2005, 02:18 PM   #31
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Maxy is $21 per gallon of 20% here and odonnel is $26 per 20%. Its the highest priced fuel on my lhs shelves.
Everyone else is around $21 or so @ 20%.
Artificial-I is offline   Reply With Quote
Old 06-06-2005, 02:20 PM   #32
performula's Avatar
Where at in Florida?
performula is offline   Reply With Quote
Old 06-06-2005, 03:05 PM   #33
YBSLOW's Avatar
Default Coke or Pepsi?
This is a funny question. You are going to get 1,000 different answers/opinions and most off them are not well informed.
My opinion is O'Donnell because he is a great guy and supports racing like no other.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-06-2005, 03:59 PM   #34
Derby Bros Racing's Avatar
i vote Odonnel. i've been using it for 4 years (i've tried several others along the way) and i just had better luck with odonnel fuel.
byron is ok but it has more oil that gunks the motor. also, the container is clear and the fuel gets bad pretty quick. as long as the fuel is fresh, it's ok to use it but like i mentioned, they get bad pretty quick. you will notice this with the color. byron is only good when it's light yellow. once it gets darker, it's bad. proof can be seen by opening your motor after using a gallon of byron. it will be really black and dirty inside.
odonnel is a cleaner burning fuel. and it doesn't have any dye for coloring. color is only used for trademark and also to help see how much fuel is in the tank easier. but color is another additive that, in my opinion, gunks the motor. even orion went from colored to clear fuel
Derby Bros Racing is offline   Reply With Quote
Old 06-06-2005, 04:17 PM   #35
impalabob64's Avatar
Send a message via AIM to impalabob64
Default fuel
i tried whitelighting ,30% with 8% oil in my jp that i run on my fw05r ,ballistic had to retune ,got no hotter than 220. amazing hp. if you find it try it
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 06-06-2005, 04:29 PM   #36
EdwardN's Avatar
I vote for O'Donnell. Been using it for more then a year, probably 40 gallons or so, all engines are always clean-no rust, no built ups, no need to use after run oil, even we accidently left fuel for 2 weeks in the tank, later on the track, started engine-no problem-run perfect. O'Donnell all the way!!!!!
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-06-2005, 05:17 PM   #37
onnetz's Avatar
I like and use O'Donnell but dont agree with not using after run oil..
I believe any type of left over fuel in an engine will gunk it up and make it much harder to turn over.
onnetz is offline   Reply With Quote
Old 06-06-2005, 07:17 PM   #38
Regional Moderator
daniz24's Avatar
Anyone have tried Runner Time fuel?
daniz24 is offline   Reply With Quote
Old 06-07-2005, 07:19 AM   #39
trashcar's Avatar
TOP GUN I can't believe you as a builder could say after run is not necc. especially with high percentage OD fuel.While OD is excellent fuel nothing but flushing and protecting engine internals will minimize the corrosive effects of nitromethane or prevent the water absorption of alcohol.Heck PARIS always advised never return fuel exposed to humidity in your track bottle to your supply bottle.
trashcar is offline   Reply With Quote
Old 06-07-2005, 12:01 PM   #40
EdwardN's Avatar
Sorry to say, but this is exsactly what I am doing, I never use after run oil (I guess O'Donnell is using very pure Nitormethane which contain no acide), if fuel left in the tank, I am very often reuse it week later, I am too leasy to drain the tank. I have never had chemicaly damaged parts in my engines.
I don't recomend to do it, I just say what I do and how O'Donnell doesn't affect my engines, I am very please with O'Donnell fuel quality-the best I ever try since I am in the RC cars.
Edward
Old 06-07-2005, 03:36 PM   #41
factory racer's Avatar
does the stain on the piston and sleeve make a difference in performance????OD burns clear i gues or yellow and sidewinder burns a pinkish colour and blue thunder a blue......does it matter if it turns a colour on the piston and sleeve or all the internals on the motor?"???
factory racer is offline   Reply With Quote
Old 06-07-2005, 03:48 PM   #42
theoritically yes. you know how experienced racers clean the little burrs and polish their motors to get the maximum horsepower. well, with all the gunk in there, it should limit the power of the motor. the color becomes a build-up over time from my experience. but with the odonnel you don't get any build-ups. it just makes motor maintenance easier.
Old 06-07-2005, 04:11 PM   #43
duneland's Avatar
Oil content for Blue thunder is 10%. Race BT is 7% castor and 3% synthetic.
RaceBT is a very good fuel except for the staining!
Some engines won't run well on O'Donnel (Rossi for example).
Sidewinder is VERY different from Blue Thunder.
I like Mugen fuel. No staining, good tuning, good protection.
Oil content for Mugen is as follows; 20% has 12% oil, 30% has 11% oil and 40% has 9% oil. According to the labels..
duneland is offline   Reply With Quote
Old 06-07-2005, 05:12 PM   #44
Send a message via AIM to ole69
I use O.D.'s 30%,no prob's here
Not that I do it often
But at times I have dumped the fuel out,no after run oil
And the car started on the first pull a week or two later
I've only used OD nothing else 20% and 30%,cars idle smooth and no real staining
ole69 is offline   Reply With Quote
Old 06-07-2005, 05:16 PM   #45
Moderator
Interesting never heard od has problem with rossi motors. Maybe thats why I had some trouble with mine.
I think im going to buy some maxy tommorrow. Im going to be taking the car out to a track here in florida as well. Should be fun.
***Byron Fuel*** GRide Nitro Off-Road 28 07-24-2008 10:54 AM
***Byron Fuel*** GRide Nitro On-Road 4 07-23-2008 09:12 AM
O'Donnell vs Byron vs Sportswerks straightaway Nitro On-Road 20 01-12-2007 11:57 PM
Byron Fuel kissmypaint Electric Off-Road 5 01-17-2004 06:07 PM
