Old 02-12-2004, 11:48 PM   #1
Default Two easy newbie questions to answer...
1. I've always thought a full turn on a needle is like going around a clock once, 360 degrees, correct?
And
2. The spit test, do you do it on the top of the cooling head, or the glow plug part? Cause the glow plug is a lot hotter.
3. What do you use for after-run?
Prozak is offline   Reply With Quote
Old 02-13-2004, 12:04 AM   #2
icon's Avatar
Send a message via AIM to icon
1. for the most part, you are correct; one full turn is 360 degree. but it can be for clockwise and counterclockwise
2. i think most people use the heatsink head. my suggestion is save up some money for a temperature gun; the onboard units are cheaper but the temp guns are not that much more expensive and much more accurate and convenient. just remember that the temp gun is a guide for the ballpark running temp. actual running temp depends on various condition related factors.
3. hobbico and pacer makes afterrun. but for the money go with marvel mystery oil. just as good and much more bang for the buck.
icon is offline   Reply With Quote
Old 02-13-2004, 12:08 AM   #3
Thanks for the response =)
Old 02-13-2004, 12:28 AM   #4
icon's Avatar
No prob :-D.
A couple misc questions someone can answer. TechWun Electric Off-Road 2 07-16-2007 12:50 AM
TRAXXAS NITRO SPORT...CAN U ANSWER MY QUESTIONS khanzie Electric Off-Road 2 04-25-2007 02:51 PM
Really Easy Questions Dante Sly Rookie Zone 6 03-16-2005 08:31 AM
Nitro Questions, See If You Can Answer Any LosiFromHell986 Electric Off-Road 6 08-02-2003 07:40 PM
