Old 04-18-2004, 08:57 PM   #121
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally posted by AMGRacer
Hmmm that could explain it. I will recheck it when I get home tonight.
Anyways I have not run the tires yet. First impression of the "rubber" is that it seems to be similar to the so called "Japanese Rubber". Ie. very closed cells compared to the more open celled Ellegi and FAST. I have heard from others (Sparksy you reading this ), and somewhat unscientifically found myself that this "Japanese" rubber works better on dustier surfaces. Do you guys have any insight into this?
It might explain it, but it doesnt excuse false advertising... oh wait, I didnt see the "est " 12%. I assume est = estimated.
;D
AMG, not sure if I should comment on the Japanese v conventional rubber while I'm in such a shit stirring mood... But the jap rubber did work better on dusty than the equivolent shore rating of a conventional tire. Also wears better on rough tracks. For me, Japanese rubber (the 2brands I have used are speedmind and active) is much better for carpark tracks that are tipically rougher and not as clean as a permanent facility.
I have no idea about these Mono tires as they are not available here. So I dont know how similar they are, good or bad.
sparksy is offline   Reply With Quote
Old 04-18-2004, 09:05 PM   #122
sparksy:
We've weighted Mugen fasttires for mtx-3 against our tires. It was a 42F tire, it was around 13%-14% heavier.
Anyways, our tires have more foams on them. Around 2mm in the front and 3mm in the rear.
We hope you get a chance to run them, we are sure you will like them.
MonoTuning
monotuning is offline   Reply With Quote
Old 04-18-2004, 10:03 PM   #123
Send a message via AIM to Johnnytc3
so are you saying your tires are around 66-67 mm out of the box?
Johnnytc3 is offline   Reply With Quote
Old 04-18-2004, 10:14 PM   #124
Johnnytc3:
We are not sure the exact diameter of Ellegi tires, but when compare to Ellegi multi-spoke, our tire is about 2mm more in the front and 3mm in the rear.
Aaron
Old 04-19-2004, 12:43 AM   #125
wild gopher's Avatar
Trader Rating: 39 (100%+)
do these tires fit the MTX-3? I am currently running fast tires (the ones for mtx-3) and wanted to start trying new tires but my LHS told me mtx-3 needs a special 2* offset. Any comments?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 04-19-2004, 12:58 AM   #126
wild gopher:
They fit MTX-3 perfectly, you just have to adjust the pivot balls alittle.
MonoTuning
Old 04-19-2004, 01:11 AM   #127
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default Guys
Don't worry if this tires are heavier or ligther than the competitors. Just try it, and you will like it.
If you like it, and this are heavier or ligther than others, doesn't matter
Walter Diaz
wad is offline   Reply With Quote
Old 04-19-2004, 04:54 AM   #128
AMGRacer's Avatar
OK for the record on the front tire:
42 front Mono - 2mm more tire - 27g
42 front Ellegi - 21g
Works out to 24g more rotating mass when used at full size. Not necessarily a problem but I just thought I would point it out.
AMGRacer is offline   Reply With Quote
Old 04-19-2004, 06:39 AM   #129
sparksy's Avatar
Not a problem as I rarely run my tires at out of the box heights, but to claim to be 12% lighter and not be, regardless of diameter is a bit crappy.
AMG, can you true a pair down to the same size as a pair of elligi and weigh them?
Old 04-19-2004, 07:06 AM   #130
stefan's Avatar
Send a message via AIM to stefan
I'll weigh them tonight, but anyways, I like how they handle:
stefan is offline   Reply With Quote
Old 04-19-2004, 07:15 AM   #131
stefan's Avatar
Old 04-19-2004, 08:35 AM   #132
Regional Moderator
kumpol's Avatar
another one....
kumpol is offline   Reply With Quote
Old 04-19-2004, 09:01 AM   #133
stefan's Avatar
Thank you Kumpol, highly appreciated
Old 04-19-2004, 01:00 PM   #134
AMGRacer,Sparky:
We think we will have to prove it to you by using our very accurate digital balance!!! What kind did you use???
Will show some prove soon
MonoTuning
Old 04-19-2004, 01:02 PM   #135
stefan's Avatar
I have labratory scales that are exact down to 0.001 grams
R/C Car Tuning Lesson 1: Tires artwork Colorado Racing 14 11-21-2014 08:43 AM
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
1/8th tires/wheels GREAT DEALS!! dylanj R/C Items: For Sale/Trade 1 09-14-2005 03:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
