Old 10-01-2009, 02:50 PM   #1
The Pope NJ's Avatar
Trader Rating: 1 (67%+)
Default RS4
Getting a used RS4 needs a motor and radio. any advice on the motor and any good hopups or things I should know.
Speeds just a matter of money; How fast you want to go?
Home site www.HPISavageForum.com
Youtube user: ThePopeNJ
The Pope NJ is offline   Reply With Quote
Old 10-01-2009, 03:56 PM   #2
Before the tsunami of replies start, I suggest you elaborate more on what the car has already and what you are planning to do with it ie...drag race, parking lot bash/race, club race, etc. Pictures are always a good way of letting know what your car has and/or needs even if you don't know yourself.
with that said....I'll start off with saying which generation RS4 is it.
Get the Picco JL EvoRed dot .12 engine, you can't go wrong with this engine and it has a new low price.
http://www.kamikazetoysandhobbies.co...p?prod=51124-3
Kyo83 is offline   Reply With Quote
Old 10-01-2009, 04:02 PM   #3
Well I will get pics as soon as it gets here it is on a usps truck somewhere right now. I like the motor as I am a picco or novarossi guy. I am just going to parkinglot bash with it right now as I know of no places nearby that race them. I will most likely use a dx3s for the radio. I know it has a two speed in it and I think it is a race 2 or something like that. Thanks for your help guys I am a MT guy but I wanted this to play with and for 25 bucks how can you say no.
Old 10-01-2009, 04:12 PM   #4
Colors_By_Dave's Avatar
Trader Rating: 84 (100%+)
Depending on which generation car it is, it may have fixed length "dogbones" instead of threaded turnbuckles for camber and toe. I had both fixed and adjustable versions of the car and the adjustable car was able to be set to minimize tire wear, and improve handling.
Got Paint? Got MicroHoles? Got custom masks?
Colors By Dave - I love to paint
Colors_By_Dave is offline   Reply With Quote
Old 10-01-2009, 09:42 PM   #5
fastharryDOTcom's Avatar
It was called a racer 2....it was the last version of the Rs4 series and had a host of goodies on it. Post a pic when you get it, lets take a look...
and we would stick with a lower HP motor....These chassis's were designed with 1 hp motors in mind....
You can see our racer 2 chassis's here..
visit fastharry.com We are always updating the site with new cars and cool rc stuff.
old user name "fastharry"Posts: 2,845 Original join date 2001..HPI Challenge Winner.
fastharryDOTcom is offline   Reply With Quote
Old 10-02-2009, 07:28 AM   #6
JLock's Avatar
Fastharry,
Don't forget that whatever engine they get, it should be a threaded shaft one. Remember, the car was set up for thread shaft use and if you use a SG shaft engine, you have to mod the car a little (because the SG shaft is short, thus making the alignment of the clutchbell and transmission gears off by a bit).
JLock is offline   Reply With Quote
Old 10-02-2009, 09:05 AM   #7
PrimeAKF11's Avatar
Where in South Jersey are you located? There is an AWESOME onroad track located at New Castle, DE, about an hour from cherry hill / voorhees area. (Check out www.bluediamondpark.com, or the blue diamond onroad thread in racing forums, http://www.rctech.net/forum/racing-f...e-all-out.html).
I am there every weekend and there's a few guys from South Jersey who is a regular as well.
If that's too much of a drive for you, there's an onroad racing program right AT south jersey. It is called SJCCR. Go to www.sixfoottiger.com, or PM user Ray Murray in this forum for further info.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 10-02-2009, 09:15 AM   #8
What could go wrong with using high horse power engines in the car? just wondering as i have one that i kind of want to make raceable-ish
Double D Donuts is offline   Reply With Quote
Old 10-02-2009, 09:25 AM   #9
PrimeAKF11's Avatar
My cousin used to race one with a Orion CRF motor until he switched to a G4S.
I've heard that bevel / ring gears can be a little on the weak side on earlier RS4-3's. Plus it is best to stay clear of other cars and the boards since the upper i-link / lower H arm configuration is inherently weaker than the pivot ball suspensions most nitro sedans use these days. Other than that... not much.
My cousin had used hot bodies centax clutch to fit his motor since the stock one was not designed for SG cranks. I think it can be found pretty cheap these days though.
Old 10-02-2009, 10:49 AM   #10
The older chassis and belts were designed to handle the higher torque of the newer more powerful engines. Like someone else mentioned already...the turnbuckles often came off and the dogbones would pop out. Mods can be made/addes to fix this, but as is, putting too much stress on the transmission and drive train(think stripped gears) with a more powerful engine would not be good for "ole bessy"
Old 10-02-2009, 10:52 AM   #11
Not sure if this company still makes upgrades for the RS4 2 but their site is still up:
http://www.megatech.com/hpi_nitro_rs4.html
They have/had a slew of purple goodness
Old 10-02-2009, 11:04 AM   #12
ouch, at those prices i dont think its even worth it...unless its also available somewhere else cheaper.
btw i have the older RS4-2
i never ever ever ever ever had any issues with my drive train or parts breaking. i only kept having the engine come loose, no matter how much i would lock tite it ( guess oil in there kept it from bonding)
maybe if i come into a used motor and pipe for it, i'll go ahead and give it a shot.
or what if i snagged my TRX 2.5 from my nitro rustler? would that be a drop in?
Old 10-02-2009, 02:13 PM   #13
Any .12 to .18 should be a drop in...but like the guys said it needs to be a standard style crankshaft, not the SG style or else you have some modding to do.
Old 10-05-2009, 08:12 PM   #14
yourstruly22's Avatar
Default rs4
Iv'e got rs4 1 and 2 racer that Iv'e been bashing and racing for years. One problem with these cars are that small rock will eat up your belts and gears also high hp engines will eat up the diff shaft
yourstruly22 is offline   Reply With Quote
Old 10-05-2009, 08:20 PM   #15
I would advise you to consider trying to get your money back. Those cars are discontinued and are very hard to find parts for. I've owned a HPI RS4-2 for 9 years and now I'm experiencing problems in finding the basic parts such as, belts, pulleys, gears and arms.
If you don't believe me here's some pictures of my smashed car ...
http://img2.imageshack.us/img2/5160/img2986rn.jpg
http://img2.imageshack.us/img2/5294/img2988b.jpg
http://img14.imageshack.us/img14/6/img2987m.jpg
You wouldn't mind selling your to me would you ...
Twisted_Metal is offline   Reply With Quote
HPI Electric RS4 MT Support Thread! beemerfan Electric Off-Road 618 11-06-2017 12:40 PM
Micro RS4 Thread thachowman Micro and Mini Scales 443 07-30-2013 06:53 PM
Tricked out RS4-2 racer FT jingo R/C Items: For Sale/Trade 13 04-04-2004 10:09 PM
