Old 03-26-2004, 04:33 AM   #76
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Originally posted by BaxterC
Well, I( have just had an idea, in the port in the crank, one could add a similar type of system, BUT, one would have to have only maybe 2 blades or fins, but at the right angle as not to slow the mixture...
This would help with two things, one, it will help get the mixture out of this port, and it will help with mixing the ... mixture more. this could work very nicely... but remember that it will just get the fuel through the crank and get it into the area under the piston (cant remember what it is called) Any ideas, but please note that I am not talking anything more than moving the fuel through, there will be no real boost in pressure, but it may get more into the cylinder, but you will need a GOOD exhaust or you may not accomplish anything.
no negative intentions,... but this was what the creator of the turbo kits intending to do (and me trying to pass this message to this thread) pushes more air up to that point,... it doesn't have to blow that hard and create more compression,... again like it was mentioned earlier,... comp. increase in boosting combustion chamber is actually a side effect,... the main intention was to create more energy by burning more air/fuel mix in that chamber... IMHO bigger bang created by lower comp. is good compared to same bang w/ higer comp.... results are the same,... but side effects are different
like mentioned in baxter's post,.. : "there will be no real boost in pressure" ,.. this is very good, as long as it delivers more air/fuel through that transfer port
just my 2 cents
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 03-26-2004, 04:45 AM   #77
Default Re: Re: hey baxter,..
honestly, I didn't even check, I got the pic from rcnitro's site as I want to show the turbo scoop, I didn't even see the newspapers...
Your Gallant, is it a Mitsubishi? we have one or two Gallants here but different countries have different names for cars.... Our Opel is Brittains Vauxhaul and our VW Polo is Europes Skoda and such...
naaahh,... I was only kid you about that ... no newspapers and all under the engine, hahaha... (no bad feelings, pls)
Galant is always for a Mitsubishi Galant (I'm pretty sure about this) but I guess you won't find any matching breed for mine, hehe... genetically enhanced...
kind of like an ugly duckling,... on steroids and viagra
HPI Racing Bali
Team HB Bali
Old 03-26-2004, 04:46 AM   #78
BaxterC's Avatar
just my 2 cents
This is an idea... how about you shape the piston that when the mixture comes in, it is 'pushed' to the top of the cylinder, which forces the exhaust gasses out, BUT, there is a limit to the pressure though.
you couldn't use the exhaust gasses to turn the turbo though as this has multiple pressures, back and forth...
Remember that if the compression in the cylinder is too high, you get preignition which is VERY bad for the little monters, which I suppose we are already on the limit. and I can tell you that there is already some pressure in the motor in order for it to run...
BaxterC is offline   Reply With Quote
Old 03-26-2004, 04:50 AM   #79
BaxterC's Avatar
Default Re: Re: Re: hey baxter,..
hehehe,... got an eye for detail,... heheheheheheee...
I can tell you I have not seen one like that... genetic modification is bad, but I will let you off this time as power and speed is the way to go...
Old 03-31-2004, 07:35 PM   #80
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
Does anyone know exactly what that car is on the first page with the rotary engine? Or where i could find more info about it?
RCNitroDude999 is offline   Reply With Quote
Old 04-02-2004, 08:29 PM   #81
Default Fuel Injection for r/c
http://www.bannedrc.com/forum/viewtopic.php?t=2478
not sure if it really works on 1/10 car, but as always, "it could be done" . OS has an EFI system for their larger engines currently... but these things are too expensive to start with (checked for the airplane, costing around 1000 bucks,... I can get a Motec ECU (for full scale) in that price,... phew,... I start to feel that this hooby IS getting too expensive for me
HPI Racing Bali
Team HB Bali
Old 04-03-2004, 03:15 AM   #82
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default Re: Fuel Injection for r/c
i am glad you realised it at the early part of your RCing... and if you have been in RC for a long time.. at least NOW you realised it!
i like to FUEL INJECTION and never thought that could be done in RC! what a wonderful world!
now we have something to talk about!
mop
mop_iko is offline   Reply With Quote
Old 04-20-2004, 07:20 PM   #83
HELLION's Avatar
Default Mop man!
Mop Man Is it true while making love to your girlfriend you screamed out serpent instead of another girls name just kigdding
HELLION is offline   Reply With Quote
Old 04-21-2004, 12:37 AM   #84
mop_iko's Avatar
Default Re: Mop man!
YO! da hellion!
nice body!
OI.... i will make sure i will say the right name..... not serpent! LOL...
do u have something to share with us.... about the engine stuff... not girls...
girls can wait........
mop
Old 04-21-2004, 02:41 AM   #85
EdwardN's Avatar
BLAH, BLAH, BLAH, BLAH, stop talking, go racing!!!!!!!!!!!!!!!
BTW, tutbo scoop wasn't implemented on our engine to be a turbine, it was implemented for following at some point conrod is shading hole on crncshaft and traping partly mixture there. So I belive OPS made those cuts to let fuel come ut of trap. Chamfer is working much better then scoop ( tested on engine).
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 04-21-2004, 09:26 AM   #86
here comes,... the 24/7 racer among all of us,...
and btw, we were talking about a "tubine" yes,... not turbo scoop inside a Hyper .21 8 ports engine,... I think most of us already know what a turbo scoop was developed for (and wasn't really interested in, cuz it's common already),.. just wondering why the Hyper 8 ports got a turbine in it....
man,... I just don't get it,... if you wanna race don't go to a forum,.. can't race in it we just want to share what we found along our path,...
if any part of my 2 cts are hurting your feelings,... sue me,...
btw,.. any of you guys manufacture your own rc stuff?! I'm currently making metal tuned pipes and manifold for specific engines and track conditions, my own metal ring gear for FW05R, and metal 0.8 pinions too cuz it's quite hard to find them around,.. so I make them instead, hehehe...
HPI Racing Bali
Team HB Bali
Old 04-21-2004, 09:35 AM   #87
Default Re: Re: Mop man!
Originally posted by mop_iko
YO! da hellion!
nice body!
mop
nice indeed,...
while talking about bodies,.. ahem,... which color is your fav color for a competing car,... I'll paint my car pink this time,... just for the heck of it,.. and if I'm lucky enough this week,.. they'll have a pink car in the O-range circuit hall of fame, hehehe.... I'll use GQ's bright orange rims with it for the maxy flashy effect
HPI Racing Bali
Team HB Bali
Old 04-21-2004, 10:35 AM   #88
BaxterC's Avatar
Default Re: Re: Re: Mop man!
nice indeed,...
Pink is good, if you like that sort of thing, I like the bright colours too so you can see it on the stand, but I like metallic blue with a bright orange stripe on the side over the top at an angle so I can see it and for effect. I have also got silver on mine, on the bonnet and the roof.
Old 04-21-2004, 11:46 AM   #89
HELLION's Avatar
Default Pink?????
I paint most of my bodies I race with candy blue with hot pink flames and always paint the wing hot pink! It really helps me see it when I race which is a good thing cause I hate it when I'm driving the wrong car LOL
Old 04-21-2004, 07:34 PM   #90
Default Re: Pink?????
monster wing!!!!! ,..... hehehehe,.....
HPI Racing Bali
Team HB Bali
BMI Racing Discussions protc3 Team and Company Discussions 10674 02-05-2017 07:24 PM
Crawler / climber discussions Frost Malaysian R/C Racers 40 02-09-2007 11:37 AM
Boca Bearing's Lightning Ceramic Bearing Upgrade Findings Mr. Shookie Electric Off-Road 0 06-05-2006 11:19 AM
Discussions with UCHEATULOSE !! lmunno Florida Racing 5 04-12-2004 08:34 PM
