Old 09-25-2009, 01:51 PM   #1
Default Best nitro to use on nitro 4 tec 3.3 HELP!!
Hi
i have a nitro 4 tech 3.3 im currently running 30% sport blue thunder nitro and does any one know a better nitro that will make my car run better if so can you plz tell me the name, the % etc.. also would i have to do anything speacial to my car. What i am going to do is im going to make the oil run out which i have in the my car already and put the new oil in, would i have to do something more than that if so let me know.
thanks
imran is offline   Reply With Quote
Old 09-25-2009, 02:06 PM   #2
Gonzo RR's Avatar
Byron gen 2 30% or 33% 4 sure!!! try it and post what difference you notice!
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 09-25-2009, 04:04 PM   #3
any other suggestions?
Old 09-25-2009, 05:24 PM   #4
Send a message via Yahoo to motojon
PowerMaster 20%-30% and shim the head accordingly
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 09-25-2009, 06:24 PM   #5
Yeah...if you switch to a higher nitro content fuel, you may have to add a shim under the cooling head. This is usually the case, but not always. It is also a good idea to go throught the engine break process again when switching to a higher or lower nitro content. if you just use a different brand but same nitro percentage then its not necessary, but can't hurt it either.
Kyo83 is offline   Reply With Quote
Old 09-25-2009, 09:52 PM   #6
Gonzo RR's Avatar
+2
I broke in my 3.3 engine with 20% after a gallon I switched to 30% shims under cooling head are stock I probably ran about 3 gals of 30% or more and now I'm using 33%
