Old 09-24-2009, 07:53 PM   #1
Default Ofna DM1 with LRP .30x what pipe
I just put an LRP .30x that is the competition non pull start with 7 ports in my OFna DM1. I just broke it in and without a full race tune this engine is awesome.
I would like to get a race pipe for it instead of the pipe that I'm using from the original Force 28 engine.
Will be used for club racing medium to long tracks. The engine has plenty of low end, so if I improve anything it should be the mid and higher rpm range.
What are your suggestions.
jim
authorjim is offline   Reply With Quote
Old 09-24-2009, 08:43 PM   #2
Gonzo RR's Avatar
How about a JP4
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 09-25-2009, 01:44 AM   #3
3-172IN MTN's Avatar
Send a message via MSN to 3-172IN MTN
I think an 086 is the way to go.....
si vis pacem, parra bellum
(If you wish for peace, prepare for war)
3-172IN MTN is offline   Reply With Quote
Old 09-25-2009, 08:58 AM   #4
Trader Rating: 18 (100%+)
Default DM1
jim
I would say either a 2052, or a 2015.
I am using a 2052 on my DM1, and it pulls all the way through the end of the straight.
A 2015 pipe will give you more top end over the 2052 though.
I use three 2015 pipes on my 1/8th scale cars, and the top end is great
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 11-27-2009, 08:59 AM   #5
Default thanks
Sorry that I did not get back sooner. Too many posts on too many forums to keep up.
thanks for all the help. I will be making a winter project of LRP's in my DM1 and GT2 for the winter, new pipes, upgraded brakes, Ipanema tranny in the GT2, suspension tweaks on both and new bodies.
Jim
Old 11-27-2009, 02:27 PM   #6
CurveTracer's Avatar
Hey brc358,
Will the 2052 and 2015 exhaust pipes work well for both .21 and .30 size engines?
I thought the .28/.30 sized engines needed larger exhaust systems than the .21's.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 11-27-2009, 03:02 PM   #7
Default DM1
Originally Posted by CurveTracer View Post
Hey brc358,
I run the 2052 pipe in my modified Pico in my DM1, but a very good friend of mine runs a 30 engine, and he also uses the 2052.
The 2015 will give more top end, while the 2052 will give more torque.
He told me that he is changing from the 30 back to a modified 21 though, so he will most likely use the the same 2052, or use a 2015.
So I was going off of what I know he uses.
The 30 size engines are beasts for sure, but they cant hang with some of the high reving modified 21s. They run out of power about 3/4 down the back straight, but the torque is great.
nearest barstool
Old 12-10-2009, 10:55 AM   #8
Suspended
If you are interested in higher acceleration and top speed check out the graphite GT2 chassis at www.maxvelocityracing.com. There is a whole graphite kit for the GT and GT2
GT Speed Freak is offline   Reply With Quote
Old 12-10-2009, 06:31 PM   #9
Excuse my ignorance but what brand or where can I get those pipes?
jneg is offline   Reply With Quote
Old 12-11-2009, 07:56 AM   #10
The pipes are NovaRossi brand. You could begin your search with your favorite retailers.
Old 01-04-2010, 05:56 PM   #11
513ATFLANAGAN67's Avatar
Trader Rating: 11 (92%+)
THE OFNA 095 PIPE IS A GOOD CHOICE ITS DESIGNED FOR THE DM 1 I HAVE TWO OF THEM AND ITS THE PIPE OF CHOICE CRAZY FROM TOP TO BOTTOM ALSO PRICED REASONABLY 50.00 TO 60.00
513ATFLANAGAN67 is offline   Reply With Quote
Old 01-04-2010, 06:07 PM   #12
Trader Rating: 93 (100%+)
Default Pipe
I would run the 2052 with a jp racing conical short header. The header being the key to more rpm and overall hp. You should find the header on ebay. It makes the big engines into screamers.
latemodel13 is offline   Reply With Quote
Old 01-07-2010, 05:00 PM   #13
Default DM1 pipe for LRP engine.
Through some dealings I got an 086 pipe cheap. Any other opinions on that?
Jim
Old 03-19-2012, 12:11 PM   #14
Default answer and question
i am running the same set up and i have the ofna 086 pipe it is a great budget pipe makes a lot of power but i also have a question.
i have been have ing pronlems with blowing my spur gears everytime i run the car.
.30dm1 is offline   Reply With Quote
Old 03-19-2012, 09:20 PM   #15
Send a message via Yahoo to dasmurf93
+1 on the ofna 095. It looks exactly like the original but instead of a silicone coupler it uses the gasket and spring type.
Run the same motor and the 095 pipe. I use mine for drag racing at 150 feet I hit about 55 60 mph.
dasmurf93 is offline   Reply With Quote
