Old 02-06-2004, 06:53 PM   #1
Ducati-Rider's Avatar
Default Thunder Tiger Parts? = Stock NTC3 .12 Motor
I'm sure you guys have long replaced your stock NTC3 motors for the high zoot screamers. Does anyone know if you can replace the stock pull start rear motor plate with a Non-Pull start plate.
I've gone to a starter box, and when you lower the motor with lower motor mounts, the pull start plate drags the ground and needs to be replaced with a closed end unit.
Also does any know or have a larger cooling head for the .12.
I would think some aftermarket source should make something.
I run on a small tight track, and find the stock motor adequate while I focus on driving and keeping off the boards. I'm just trying to make the most of what I have.
thanks in advance
Ducati-Rider is offline   Reply With Quote
Old 02-10-2004, 10:41 PM   #2
Trader Rating: 22 (100%+)
Here is the backplate. It works on the Associated .12 and .15 (same block)
I still run the Associated .12 on a small track. It is a very dependable engine for small track racing. You can also get a O'Donnel racing head for it here!
Hope this helps!
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 02-10-2004, 11:26 PM   #3
spawn's Avatar
You will also need to trim off the little metal piece at the end of the crankshaft. Its the little metal piece that connects to the pull start. I think you may be able to get the instructions from AE website. Anyway I like have the pull starter, pretty convenient.
spawn is offline   Reply With Quote
Old 06-21-2016, 03:37 AM   #4
Default thunder tiger R21
Hi guys I have a thunder tiger R21 moter I started it yesterday and when I took it out for a spin it made a loud pooop noise and then disasembled the motor and saw my glowplugs spring broke of and the piston seased and the conrod broke .so I just want to know how much wil I pay for new piston sleve and conrod and must it be thunder tiger spares pls ppl I have a race for the week end don't know what to do
jakes01 is offline   Reply With Quote
Old 06-21-2016, 09:00 AM   #5
Trader Rating: 14 (100%+)
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Thunder Tiger EB4 - S2 Parts rustygun Australia For Sale/Trade 2 06-26-2008 06:07 AM
Thunder Tiger EB4 - S2 Parts rustygun Australian Racing 3 06-07-2008 08:02 AM
THUNDER TIGER EB4 S3 PARTS NIP. LOT EZRC R/C Items: For Sale/Trade 0 01-29-2008 07:13 PM
Where to get Thunder Tiger Parts ? nikkor Singapore R/C Racers 1 10-14-2005 03:21 PM
Thunder tiger pro 15 motor HELP Raw40 Nitro On-Road 7 06-19-2002 01:07 PM
