Old 09-18-2009, 10:47 PM   #1
Default Oiling the bearings?
What lube is recommended for oiling the bearings? will castor oil work?
AdrianOngs is offline   Reply With Quote
Old 09-18-2009, 11:17 PM   #2
kidsid99's Avatar
Trader Rating: 53 (100%+)
I believe that castor oil is a little thick. You would probably need to get some real light bearing oil from your LHS. The lighter the oil the better they spin but you will have to maintain them.
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 09-19-2009, 08:01 AM   #3
Trader Rating: 18 (100%+)
Default oiling the bearings
I used to always clean my cars with a nitro spray after a full day at the track.
The nitro spray will wash away the lube in the bearings though.
A friend of mine showed me this new silicone based spray from Home Depot.
I cleaned the cars with some Simple Green/denatured alcohol, and lightly sprayed the inside and out side of the bearings with this new silicone spray, and the bearings are like new. It takes just a very small amount of this spray to work, but it works amazing.
So now all I do is spray the cars down with the Simple Green mixture, use a compressor to blow them off, and then lightly spray all of the bearings with the silicone spray.
Be sure and do not spray any one way bearings, because they will not work if they are lubed.
One good thing about this spray is it will not collect dirt or gum up the bearings.
If you try this, be sure and get the silicone based spray.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 09-19-2009, 09:15 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
I use this:
http://www.the-border.com/product.ph...9&cat=0&page=1
I fill it up with WD40 and throw the bearings in for an half hour. WD40 will clean and lubricate the bearings.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-19-2009, 09:16 AM   #5
why wont the one way work after lubing it?
Old 09-19-2009, 09:35 AM   #6
Default oiling bearings
You have to use an oil made for one-way bearings.
Serpent makes a good one. Use this Only for the one-way bearings, and treat the other bearings with the silicone spray, or if you take the bearings out, clean and lube them with a light oil.
But the one way bearings will not catch if they are lubed with any type of lube other than a one way lube
nearest barstool
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 08:35 PM
Help my find the cause of my slow truck Gold-Anodized Rookie Zone 10 01-24-2008 11:28 AM
How do you remove the Bearings? Bighomedog11 Electric Off-Road 9 01-11-2007 06:43 AM
Cleaning ball bearings D_o_S Electric On-Road 35 12-13-2006 06:35 AM
Cleaning Metal Shielded Bearings... DOMOisCOOL Electric On-Road 7 08-18-2004 09:35 AM
