Old 09-12-2009, 07:56 AM   #1
Default Differences between On-Road engines and Off-Road engines
My question pertains to the difference between on and off road engines. What's the real difference between them? Can you run an off-road engine in a on-road car? What problems might I encounter?
I ask this because I run an OFNA DM-1 and I need to pick up an on-road engine of the .28 size to run in the stock GT class with the Kyosho GT's. I predominately run 1/8 scale off road buggies and use RB and Novarossi engines. I could choose to rebuild my RB WS7II (.21) and run the open class or just pick up a new .28 but I don't know what the real differences are between a .21 and .28 engines.
Thanks for your insight.
MiniMeRCRacing is offline   Reply With Quote
Old 09-12-2009, 08:07 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Nothing really in terms of construction and materials. The main difference is timing. On road engines have a lot more timing in them for high rpm HP. Yes you can run offroad motors in onroad. They just won't have the top end that good onroad motors will.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-12-2009, 08:08 AM   #3
JRGTR's Avatar
Send a message via MSN to JRGTR
I think the difference is the internal tuning of the engine(construcction) I guess the off road engines have moore torque than rpm's and on road engines have moore banance of rpm's and torque but I can be wrong
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 09-12-2009, 11:03 AM   #4
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Stick with the Ofna force 28 the car comes with that motor is plenty fast. Just get a JP3 pipe.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-12-2009, 11:17 AM   #5
Old 09-12-2009, 04:16 PM   #6
Correct me if i'm wrong,but is'nt there a difference in the crankshaft lenth/diameter like sg and something else?
p1pioneer is offline   Reply With Quote
Old 09-12-2009, 05:02 PM   #7
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Nope...
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-12-2009, 05:09 PM   #8
wingracer's Avatar
There used to be two different cranks. Standard threaded cranks and SG pilot shaft cranks. Onroad went SG first but now everyone uses SG cranks.
Team Shepherd USA
Old 09-12-2009, 05:12 PM   #9
thank you! dude i know nothing about off road anything.
Old 09-12-2009, 05:32 PM   #10
J.Gonzalez's Avatar
I am curious to find out if their is any difference on the mold for the case offroad vs onroad engine.
Novarossi has two a couple of different cases in the plus 21 series. Seems to be bearing size but I am curious if they are also molded different internally. I would think for a practice engine using onroad internals and crank and offroad case with the large oversized bearings would yield a good workhorse practice engine.
Offroad cases are a dime a dozen on ebay and almost never find onroad cases.
J.Gonzalez is offline   Reply With Quote
Old 09-12-2009, 05:47 PM   #11
wingracer's Avatar
What bigger bearings? The biggest bearing I know of is the rear bearing for the Nova onroad motors. The only difference is most Nova offroad motors use a 14mm crank while most factory Nova onroads use a 14.5mm crank, though tuner motors like Max and RB still use 14mm cranks. In 14mm versions you have 25.4 and 25.8mm bearings.
Team Shepherd USA
Old 09-12-2009, 06:24 PM   #12
Trader Rating: 14 (100%+)
Default mabry modified engines
More HP,More acceleration,More torque,if thats what you are looking for MABRY MODIFIED is the place. I offer you Custom OR Drag Modification for a fraction of the price that top level modders cost,"you know who they are".My cuts are precision cuts by measurement not by sight for maximum preformance. I have modified engines from Traxxas,OS,Picco, HPI, Novarossi,Losi,Sirio,Axial, , , and more. You will receive crank porting & polish, sleeve porting and polishing along with high quality silicone fuel ramp added to your crankshaft if necessary."My Silicone is not that cheap high temp rtv gasket maker that some modders use'
Heres a videos of my work goning up against a top level modders. MOTOR IS A NOVAROSSI 359 RACE WITH A DRAG CUT!!!!!!!!"http://www.youtube.com/v/f4eu6FbeUt8&hl=en&fs=1&"></param><param YOU WILL KNOW MY CAR 1/8 MUGEN MRX 3"http://www.youtube.com/v/0KtOixxuet8&hl=en&fs=1&"></param><param
270453587585 EBAY ITEM #
If your engine not listed contact me i prefer for you to give me a call for piece of mind. I like to hear people voice before i deal with them too Thanks Call&Email [email protected] or 7578391595
For Faster Response On Sale or Trade Items Email [email protected]
vaboy10211 is offline   Reply With Quote
Old 09-12-2009, 06:42 PM   #13
What? There's no such thing as "fast enough". That's just patently heretical. I'm going to have to revoke your guy-card for saying that! All jokes aside though, you are right and I have heard good things about OFNA's .28 engines and I am talking nitro engines here in case I didn't specify earlier (since motors are to electric what engines are to internal cumbustion).
I'm leaning towards a Jammin .28 which since that's from the racing side of the OFNA house is probably the same basic .28 Force engine your referring too except for some tweaking.
Thanks for chiming in my friend.
Old 09-12-2009, 06:58 PM   #14
wingracer's Avatar
Actually, the Jammin is probably a Picco while the Force is probably SH.
Team Shepherd USA
Old 09-12-2009, 08:10 PM   #15
J.Gonzalez's Avatar
I guess I was wrong. I thought the front bearing on the kangroo was much larger than front bearing on the 35plus21.
Do you happen to know if the case are any different internally? Sure are alot of offroad cases on ebay usually brand new with new bearings.
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4621 12-02-2017 09:30 PM
Tamiya TA05MS academygaz Electric On-Road 1401 01-15-2016 06:00 AM
Power House RC Engine Performance and ColdFusionFuel Q&A TVMRocket69 Offroad Nitro Engine Forum 1880 10-22-2014 05:22 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 04:59 PM
Brushless Masters please step inside Nostrixoxide Micro and Mini Scales 31 01-10-2009 09:41 AM
PICCO P9R EVO2 16skyline Nitro On-Road 15 12-27-2008 11:17 PM
CEO Power mods , anyone done the engine mod? atebit Nitro Off-Road 39 03-15-2008 02:25 PM
