Old 06-14-2004, 08:21 AM   #16
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default i will post some pics....(cont again)
another one.... here goes your money....
dont forget the KEYWORD.... sacrifice....
mop
mop_iko is offline   Reply With Quote
Old 06-14-2004, 08:22 AM   #17
mop_iko's Avatar
emmmmmmmm.... more things to some... shucks!
mop
Old 06-14-2004, 08:24 AM   #18
mop_iko's Avatar
waaahhhhh.... how many more?
hold on pleaseeeeeeeee.
mop
Old 06-14-2004, 08:25 AM   #19
mop_iko's Avatar
sacrificeeeeeeee....
dont forget....
sacrifice what?
time
money
engine
your hand maybe...
mop
Old 06-14-2004, 08:26 AM   #20
mop_iko's Avatar
what else?
when can we start?
mop
Old 06-14-2004, 08:29 AM   #21
mop_iko's Avatar
most important tool to do a MOD....
in my case... just buy MADE IN CHINA DREMEL... hehehehe...
at least it can go 32000 rpm.... and it has speed controller for the rpm... from 5000rpm to the max 32000rpm.
THEN... lets get started....
when?
its up to you now...
mop
Old 06-14-2004, 08:50 AM   #22
teammpp's Avatar
I knew I was doing something wrong. I thought the best tools were the old stone age hammer and chisel
teammpp is offline   Reply With Quote
Old 06-14-2004, 08:58 AM   #23
mop_iko's Avatar
Default NEED YOUR HELP MASTERRRRRR....
DEAREST MASTER of ENGINE.... pls give some advice to me.... before i proceed with the SACRIFICING SESSION....
pleeaseeee.....
or anything you want to add from the things that i have posted.
mop
Old 06-14-2004, 09:15 AM   #24
Sow&Steady's Avatar
Originally posted by Grinder
I never modify JP's, nor do I modify engines like JP. My engines have completely different timing and other features that JP does not use. It takes a bit more than a few swipes with the dremel, and I don't charge $100.00. You race a JP at the winternats this year and we will see which is faster Don't get me wrong JP makes great engines, but they are more mildly tuned than mine. O.K enough with the engine talk lets race. See you at the Ft. Sunday.
Wow ... that was a bold open challenge. I would race you if I could (if you are over this side of the pond some time ...) and/or I would buy your engines if I could too.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-14-2004, 09:18 AM   #25
chinamonkey7's Avatar
J-tech have good mod engine, it did very good in F.L.
chinamonkey7 is offline   Reply With Quote
Old 06-14-2004, 09:23 AM   #26
mop_iko's Avatar
SOW... u back from travel eh?
how is your travelling went? cool?
missed your www.3hobby.com so much .....
mop
Old 06-14-2004, 09:29 AM   #27
teammpp's Avatar
Default Re: NEED YOUR HELP MASTERRRRRR....
pleeaseeee.....
mop
Wish I was a master. I leave that bit to the others on the forum (Motorman, Topgun, Grinder, etc). I am merely a intermediate student
You got it pretty well laid down. Be prepared to destroy several engines while experimenting. If you are planning on experimenting with your own cuts then i would suggest the following system.
Dont go banzai and digging in with the dremel. Use small gentle movements each time and only alter one thing at a time.
Take note if the change helped the performance or not. Then move onto the next modification. When the performance drops off then start with a new component and work back to the last step that worked. Then try something else. While learning you will most likely destroy several Sleeve's, cranks etc... Find a good online or off-line manual that explains the best rpm to have the dremel at for each type of modification and tool.
Old 06-14-2004, 09:30 AM   #28
EdwardN's Avatar
pleeaseeee.....
mop
What you put there is fairily right, beside where is explanation for one of the cuts was done on your pics. Any explanation? Anything? Very small one!!!!!
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-14-2004, 10:11 AM   #29
Sow&Steady's Avatar
mop
Not yet lah
Just couldn't stay away for the few minutes I had on line
Travelling is real bad ... tiring, smelly hotels etc. Can't wait to get back and continue assembling my car.
Old 06-14-2004, 02:53 PM   #30
revzalot's Avatar
I'm really interested in learning how to modify engines. How did you guys get started doing this stuff?
revzalot is offline   Reply With Quote
modifying motors compcast Rookie Zone 3 07-08-2006 08:25 AM
Modifying a 19 turn? 4ou Electric On-Road 2 06-19-2005 11:24 PM
Modifying Thread mafiaracers Electric On-Road 9 08-21-2004 04:10 PM
Engine Modifying Services eddiethefish Nitro On-Road 49 09-01-2003 11:28 PM
